Rejecting a Supplier's Corrective Action Plan When It's Too Weak
GStough
Hi everyone, :bigwave:
I'm just wondering how others in the supplier quality field handle this situation. You have a supplier who is the sole source of a critical material (although others may be in the evaluation phase, they have not yet been approved), and the material you receive from them is consistently problematic. Their corrective action plan is to retrain the employees who caused the issue, and bloop, that you go, it's fixed...problem solved, right?
WRONG!!!! :frust: :bonk: :mad:
So, I need to reject this corrective action plan because we all know that it won't hold water and we will once again have a recurrence of the issue. How do others handle this kind of situation? You don't have another source (yet) that you can go to, so this one bad egg has you over a barrel, so to speak.
I look forward to hearing your responses.
W
Wilderness Woody
Depending upon the proprietary nature of their materials/processes, they may not be willing to disclose underlying details and are using the "retraining" as an overall cover. Repeated failures would judge their corrective action as ineffective, but it requires proof of failure, not just suspicion of future failure.
Given the "SOLE SOURCE" and "CRITICAL MATERIAL", you are in a bit of a tight position. Depending upon the relationship (contractual or casual) you may have options for site visits, require source inspection before product shipment or coordinate receiving inspection on your end for lot rejection.
If your supplier wants to continue doing business with you in the future, they should welcome discussions and offer of assistance from SQE's to really work through the issues and come to an understanding. Think of it as counseling for corporations rather than couples;)
However, if they care too little for your account and know they are on the way out as an impending divorce, then third party arbitration/mediation may be required until legal separation is complete:mad: and you can move on to a better supplier.
Rooster69
It's very frustrating Gidget. I have run into this quite a few times. Sometimes it's pure laziness on the part of the supplier other times it is a language barrier issue. Your statement about the response always being "retraining" sounds like laziness. After you receive this bogus response, I suggest you make contact with the supplier's Director of Operation as well as Director of Quality. Explain to them your purpose for the CAPA and what results you expect from the correction. I find that if I can get in touch with a supplier's quality team, things usually have a stronger root cause, immediate correction and planned corrective action. Or you can just let them know that you are in the process of qualifying other suppliers.
Rob Fulton
Mikishots
Three key events need to be in place, and the requirement of completing each needs to be communicated to the vendor:
1. Containment. What will the vendor do, right now, to control the symptom that you are reporting? It may include reviewing all WIP for your company, telling employees to "stop doing this/that" until a formalized correction is in place, whatever is necessary.
2. Root Cause analysis. Identify the issues and ask the vendor to determine why these problems are occurring. Lack of training/discipline is not considered root cause, because there is a reason why the training is only being provided reactively. This, compounded with the fact that the problems are repeat non-conformances, shows that their proposed methodology does not work.
3. Corrective action: The root cause needs to be addressed directly to ensure that these problems cannot happen again. What's happening with final inspection - are they also just as untrained as the production staff? Does final inspection or verification even exist? If it's getting past the operator as well as the inspector, it's not a matter of poor training - the process is broken.
Hope that helps.
GStough
Thanks, Rob. Unfortunately, though, there isn't a Director of Quality and the weak CAPA was provided by the Quality Manager.....
hogheavenfarm
You could 'force' the issue a bit by providing a 5-Y or 8-d form for them to fill out.
Its hard when the supplier holds all the cards. I have used PSI threats, and actual PSI requirements, as well as sample pieces, just to create some pressure.
Site visits may also work, if they will let you in, some places are so secretive that this is not possible, in that case you could call in the MR every time there is a problem.
Somehow you have to make it easier for them to do it the right way, or expect extra work or visits.
Curtis317
Another way to handle a rejected corrective action is to go to the plant and have them review it with you. Bring the purchasing manger who is responsible to the supplier. The highlights the problems and can lead to an effective corrective action.
misu183
Taken from my experience:
Additionally to the methods shown above I would recommend also regular conference calls (frequency 1, max 2 times a month) in order to open and develop a communication channel.
This way any initiated action will be followed up closely by both parties and you will see that shortly results will be effective.
Maintaining will be the most difficult task for the supplier and this is the reason of regular conf calls. Never give up this method.
Heads of Quality and Production teams must be involved and confronted with the facts each meeting.
Evolution of their initiated action must be evidenced in overviews updated by them before each discussion.
Monthly evolution with figures content must be provided to the top management of both parties.
As better communication is as faster you will see the improvements.
TPMB4
Not sure if it helps but one idea could be to insist on a representative coming to your site to 100% inspect their product you have in stock. Set it up so that first show of a reject piece on your site you insist on them coming down the next day (if close) or asap to sort through the rest of the stock on your premises. If they don't do that charge them for external inspection company to come in at their expense.
If not that then perhaps some other reasonable means of imposing a cost to them for poor quality (other than just ditching them which is not currently feasible). A supplier who finds it either expensive or a bit more of a hassle to not sort out quality issues properly usually makes the required changes. Might just lead them to ditch you as a customer though so a risk perhaps.
Tricky situation really. Whilst you might be working to ditch them they can just as easily ditch you, leaving you in a sticky wicket. Perhaps better to try communication and support them to do right. Although perhaps you could work out a way for doing both to some degree.
GStough
We are on JIT for inventory, so what we receive in is used right away. This particular item is of such construction that the defects are only seen as it is being filled (it's a type of container). Any testing that would need to be done would be destructive.
Thanks, everyone, for the input. :agree:
We are one of their biggest customers (if not THE biggest), so to ditch us would be of no benefit to them.
R Rejecting a Part when Dimension Feature is Basic Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
B Accepting/Rejecting Threads WITHIN Gage Tolerance General Measurement Device and Calibration Topics 2
B Customer keeps rejecting my Process Control Plan (PCP) FMEA and Control Plans 6
F Rejecting Customer Specific Requirements - Can we? Negotiating with Customers Customer and Company Specific Requirements 10
G Customer changed print without notice and is now rejecting parts - What to do? Manufacturing and Related Processes 11
J Supplier not responding to PPAP request APQP and PPAP 5
D Supplier audit Medical Device and FDA Regulations and Standards News 2
S Distinction between a critical supplier and a Virtual manufacturer EU Medical Device Regulations 2
John Broomfield Five ways to botch your supplier management program Misc. Quality Assurance and Business Systems Related Topics 7
C Supplier survey - 200 to 250 duppliers Supplier Quality Assurance and other Supplier Issues 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
U Approved Vendor (supplier) List Supplier Quality Assurance and other Supplier Issues 8
P Training department ideas and development for automotive supplier Training - Internal, External, Online and Distance Learning 6
B Software service provider as critical supplier ISO 13485:2016 - Medical Device Quality Management Systems 5
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Supplier protocol for the Quality Supplier Quality Assurance and other Supplier Issues 6
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 17
D Approved supplier list - Distributors question ISO 13485:2016 - Medical Device Quality Management Systems 6
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
E ISO 13485 QMS certification as a Supplier ISO 13485:2016 - Medical Device Quality Management Systems 8
G Supplier doesn't share drawings IATF 16949 - Automotive Quality Systems Standard 15
S Use of raw materials by two supplier CE Marking (Conformité Européene) / CB Scheme 2
D Are Supplier Quality Agreements Quality Records ? Other Medical Device Regulations World-Wide 9
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
G Supplier doesn't accept the complaints Supplier Quality Assurance and other Supplier Issues 20
K New supplier audit as per V3.1 by French Automotive OEM General Auditing Discussions 2
A ASL requirement when the supplier is certified for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
D Approved supplier list for R&D ISO 13485:2016 - Medical Device Quality Management Systems 5
M SemaTech SSQA Standardized Supplier Quality Assessment - my favorite tool ever Manufacturing and Related Processes 1
D Supplier Quality level category help - high level ISO 13485:2016 - Medical Device Quality Management Systems 6
J Supplier Controlled Shipping (GM CS1) Condition Manufacturing and Related Processes 3
L Supplier within the Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Supplier Quality - How to classify a supplier level Medical Device and FDA Regulations and Standards News 10
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
M How Supplier Capacity check is done by competitors Manufacturing and Related Processes 0
C One Time Service Supplier - Temperature and Humidity Testing Service ISO 13485:2016 - Medical Device Quality Management Systems 5
M Supplier Audits - Stop Wasting Everyone's Time! General Auditing Discussions 15
G Supplier management when the supplier is your headquarter IATF 16949 - Automotive Quality Systems Standard 3
V Supplier wants to perform pre-qualifications prior to every run instead of locking in parameters. Supplier Quality Assurance and other Supplier Issues 7
D Class 3 Device - Change of supplier of material Canada Medical Device Regulations 6
D List A IVD - Change to material supplier EU Medical Device Regulations 3
J Minimum Supplier Certifications for Food Supplements Food Safety - ISO 22000, HACCP (21 CFR 120) 4
R Supplier/Vendor Surveys (360) Supplier Quality Assurance and other Supplier Issues 1
was named killer AS9100 Supplier Approval Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
B AS9100 8.4.1 Supplier Selection/Evaluation criteria and reevaluations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
