We recently had an issue with a batch of parts. One critical factor, a mechanical strenth of a closure was out of specification. We worked on the issue and got the the overall average within spec We ship and certify the average so technically this is "OK". I pulled 240 parts from the next run, 30 per cavity (8 cavity tool), and ran the test again. ANOVA below to me indicates that cavity (part) A is higher than the rest, I did run some parwise comparisons and get the same result.
When I shared this with the production manager he told me that that there was to much variability in the test method to draw this conclusion. I thought that was the whole point of t tests and ANOVA to help ensure that the differnces seen were "real" and NOT due to measurement or other issues not related to the factors you are studying.
Am I off my rocker?
One-way ANOVA: opening force versus PART
Source DF SS MS F P
PART 7 1.0607 0.1515 2.42 0.021
Error 232 14.5474 0.0627
Total 239 15.6080
S = 0.2504 R-Sq = 6.80% R-Sq(adj) = 3.98%
The graph is not formating correctly so I will leave it out. But it shows that the A cavity is higher thn the rest although the CI do overlap.
Am I off my rocker?
Source DF SS MS F P
Total 239 15.6080
