Relationship between APQP and CM (Configuration Management)
monicafmz
I am doing my master´s thesis and I would like to know if there exists a way to stablish a relationship between configuration management and APQP. I am trying to propose an implementation of the APQP processes under a PLM solution, also taking into account the benefits of CM. At the moment I see both of these processes as parallel but not related to each other.
I haven´t found any information on this topic until now.
Marc
Configuration Management is a subset of the APQP process 'parts'.
What is a PLM solution?
Marc
If you look at MIL-HDBK-61A, Configuration Management has similarities to APQP. Configuration Management could be seen as a precursor to the APQP process as defined by the automotive folks at the AIAG (i.e.: Ford, GM and what was then Chrysler). But over time Configuration Management has dwindled in its breadth in what many companies actually use, while the APQP process has added some automotive specifics, which is why I said Configuration Management is a subset. One could argue that Configuration Management is more comprehensive than the APQP process and that some aspects such as the control plan and FMEAs (process, product, machine, etc.) are expected outputs by a different name.
If you currently have a documented Configuration Management system, you could superimpose the APQP system elements on them and see where they match up which would give you the similarities. Seeing as you are a student, you would match up the MIL-HDBK-61A 'full blown' CM system to the APQP system. You will see both are essentially a cradle to grave system, and both are intended to ensure consistency of a product's functional and physical attributes, as well as its design and operational aspects, remain the same over the life of the product.
Product Lifecycle Management is in much the same boat. There are common aspects.
When you look at the various systems, understand that there may be elements which are named differently but address the same goal.
When I said "Configuration Management is a subset of the APQP process 'parts'.", it would have been more accurate had I said the APQP process has elements of Configuration Management in it, and both are meant to achieve the same essential goal(s).
monicafmz
Thanks Marc,
I am sure this information will be very helpful. So, would you say it makes no sense to try to implement both processes (APQP & CM) at the same time? or would they complement one another?
Marc
Well, the thing is they're essentially the same thing. Variations on a theme, if you will. What you implement would depend upon the company specifics, including the product. If you're making medical devices, a full blown Configuration Management system more like MIL-HDBK-61A would be required. If you're injection molding rubber ducks for kids to play with in the bath tub, a very much less stringent process would do.
I can't say I would implement either in a company per se. The first thing I would do is evaluate the company, the product(s) and processes, and define the requirements. Then I would look at the requirements and design an appropriate system. The system would be a mix of different 'named' approaches, and consideration would be given to where similar parts of each have different names. An example is explosives. I've gone through quite a few 'Hazardous Operations Studies'. When I jump the fence to automotive, the closest thing is a Process FMEA. For all intents and purposes they are the same with the caveat that there are differences, most of which are subtle, which are specific to the different products and processes. For all intents and purposes though, both (in this case) are what we commonly call a Process FMEA (process failure modes and effects analysis).
The thing to remember is both are essentially a cradle to grave system, and both are intended to ensure consistency of a product's functional and physical attributes, as well as its design and operational aspects, remain the same over the life of the product. Neither in it's complete form is necessarily applicable to every company.
So - When you said "I am trying to propose an implementation of the APQP processes under a PLM solution, also taking into account the benefits of CM.", my first response *should* have been, "Have you defined the company, its products and processes?". Until then all you can do is guess and generalize.
Marc
APQP vs. Configuration Management
Configuration Management system from MIL-HDBK-61A:
The APQP process system (my interpretation):
The APQP process system according to the AIAG:
monicafmz
...The first thing I would do is evaluate the company, the product(s) and processes, and define the requirements. Then I would look at the requirements and design an appropriate system. The system would be a mix of different 'named' approaches, and consideration would be given to where similar parts of each have different names....
Hello Marc,
I can't really imagine how could I "design" a system. Are there methods to design such systems? What methods would you recommend?. I have read a lot of theory, about the concepts, the history, the reasons, the benefits, but I haven't found the part when it comes to the design and implementation. It all seems very abstract to me. I can't find the bridge that takes you from the theory to the "real" application of it.
I would be very thankful if you could "show me the light".
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Relationship between IEC 62304 problem resolution and ISO 13485 IEC 62304 - Medical Device Software Life Cycle Processes 8
C Understanding the relationship between 62304 and the MDD ER IEC 62304 - Medical Device Software Life Cycle Processes 7
D Relationship between Diameter and Flow Rate & the Length Statistical Analysis Tools, Techniques and SPC 3
T Relationship between ISO9001 and Lean Lean in Manufacturing and Service Industries 15
P The relationship between SPC and a Quality Management System Statistical Analysis Tools, Techniques and SPC 4
T Relationship between TS16949 and 5 Core Tools & relationship between 5 Core Tools IATF 16949 - Automotive Quality Systems Standard 5
N What is the relationship between a DFMEA and PFMEA? FMEA and Control Plans 1
Q What is the relationship between Standard Deviation and 6 Sigma? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Relationship between Quality, Reliability, Price and Delivery Misc. Quality Assurance and Business Systems Related Topics 7
D AIAG FMEA 4? Ed. Explanation: Relationship between PFMEA and Special Characteristics FMEA and Control Plans 8
S Relationship between Normal Distribution and AQL AQL - Acceptable Quality Level 13
D Relationship between IEC 60601-1 3rd Ed and IEC 60601-2-10 IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
S The relationship between IEC 60601-2-18 and IEC 60601-2-37 - Ultrasound Project IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Relationship between Crimping ID & Crimping Depth - Minitab usage Statistical Analysis Tools, Techniques and SPC 3
kedarg6500 Relationship between Cp and Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 4
L Arima Output - Relationship between my raw data and the residuals generated Using Minitab Software 1
C The relationship between OEM and the subcontracted manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Ajit Basrur Relationship between Blend Uniformity and Content Uniformity Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
D Relationship between ISO 9001:2000 and EFQM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L What's the relationship between LVD (low voltage directive) and MDD EU Medical Device Regulations 3
D The relationship between the FMEA and Control Plan FMEA and Control Plans 4
K Relationship between "Corrections/Removals" procedure and "Recall" procedure US Food and Drug Administration (FDA) 11
S Relationship and Differences between ISO 16949 and ISO 15504 (SPICE) IATF 16949 - Automotive Quality Systems Standard 3
kedarg6500 Relationship between Cp & Cpk Statistical Analysis Tools, Techniques and SPC 5
M Relationship between quality assurance costs and failure costs Quality Tools, Improvement and Analysis 4
L Relationship between Calibration and a Gage R&R study? General Measurement Device and Calibration Topics 9
V Relationship between Severity and Class FMEA and Control Plans 3
D Relationship between ANOVA and measurement accuracy - Mechanical strenth of a closure Statistical Analysis Tools, Techniques and SPC 13
A ISO TS 16949 - Relationship between requirements and processes IATF 16949 - Automotive Quality Systems Standard 0
J FMEA - What is the relationship between Detection and Prevention? QP Newbie question. FMEA and Control Plans 12
J Relationship Between SAP and ISO9001:2000 Quality Assurance and Compliance Software Tools and Solutions 1
P The relationship between ISO 17025 vs. ANSI Z540-1 ISO 17025 related Discussions 2
L Is there any relationship between Cpk & Right First Time? First Pass Yield (FPY)? Capability, Accuracy and Stability - Processes, Machines, etc. 4
W 17025 and NIST handbook relationship (need advice) ISO 17025 related Discussions 8
L 'Distributor' definition & MDR/MSR relationship EU Medical Device Regulations 3
S APQP Relationship Diagram APQP and PPAP 2
J CEN/TR 17223:2018 Guidance on the relationship between13485 and MDR.. worth the money?? ISO 13485:2016 - Medical Device Quality Management Systems 3
K Does OEM/OBL-Relationship need to involve an EU Authorized Representative? EU Medical Device Regulations 11
MDD_QNA What is the relationship with the CSA group? Canada Medical Device Regulations 10
T ITAR/EAR relationship and Flow Down to Suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C DFMEA vs. PFMEA Relationship: The cause in DFMEA becomes Failure in the PFMEA FMEA and Control Plans 2
J Responsibilities, Authorities and Relationships - What does Relationship mean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
5 ISO 13485 relationship to 21 CFR 820 ISO 13485:2016 - Medical Device Quality Management Systems 17
alonFAI Definition Failure Review Board and FRACAS - Relationship and differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
T Capability Level Relationship with ISO/IEC 20000 Achievement IT (Information Technology) Service Management 2
N Agile 9.3.1 Relationship Searches - Meaning of Message Manufacturing and Related Processes 1
C CRMs (Customer Relationship Management) to help achieve ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C ISO9001 and ISO 13485 Relationship? Can we do both effectively? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Relationship Pictures Coffee Break and Water Cooler Discussions 10
