Relationship between Diameter and Flow Rate & the Length
dbproject
I just need to ask a very specific question and hope to find an answer here at Cove
Is there a relationship between the flow rate and the length of the gas injector
Please,I need to know the relationship between the diameter, Flow Rate and length of the gas injector (Nozzle)
I really appreciate your help
G
GTJunghoon
Re: Relationship between Diameter and flow rate & the lenght
If you set the wide range of variables to constants and only vary the diameter, then you will observe a direct correlation between nozzle inner diameter and flow rate. The nozzle's cross-sectional area and pressure differentials are the largest factor that affects gas flow. I don't believe the nozzle length would be a factor at all, unless you're nozzles lengths are differing by hundreds of feet. Sorry, it's hard to provide any relevant details without knowing the specifics.
dbproject
Hello
thank you for your respond
Here's some parameter of the nozzle (diameter 0.7 MM & the distance between the hole edges 0.7 MM)
what I need to know the relationship between the flow rate, diameter and distance
G
GTJunghoon
I'll assume the simplest model possible and equate your nozzle to a cylindrical pipe.
You want to calculate the Reynold's number, which is based on the gas properties, gas flow, and nozzle radius. The Reynold's number will indicate if the flow is laminar (<= 2300) or turbulent (> 2300). It is difficult to predict behaviors of turbulent flows, while laminar flows can be modeled with Poiseuille's equation.
Simply, volumetric flow varies linearly with pressure differentials and tube lengths. However, volumetric flow varies with the fourth power of the radius. Flow will be increased by a factor of 16 if you double your nozzle radius while maintaining constant nozzle length and pressure drops. Flow will halved if you double your nozzle length while maintaining constant nozzle radii and pressure drops.
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Relationship between IEC 62304 problem resolution and ISO 13485 IEC 62304 - Medical Device Software Life Cycle Processes 8
C Understanding the relationship between 62304 and the MDD ER IEC 62304 - Medical Device Software Life Cycle Processes 7
T Relationship between ISO9001 and Lean Lean in Manufacturing and Service Industries 15
P The relationship between SPC and a Quality Management System Statistical Analysis Tools, Techniques and SPC 4
T Relationship between TS16949 and 5 Core Tools & relationship between 5 Core Tools IATF 16949 - Automotive Quality Systems Standard 5
N What is the relationship between a DFMEA and PFMEA? FMEA and Control Plans 1
Q What is the relationship between Standard Deviation and 6 Sigma? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Relationship between Quality, Reliability, Price and Delivery Misc. Quality Assurance and Business Systems Related Topics 7
D AIAG FMEA 4? Ed. Explanation: Relationship between PFMEA and Special Characteristics FMEA and Control Plans 8
S Relationship between Normal Distribution and AQL AQL - Acceptable Quality Level 13
D Relationship between IEC 60601-1 3rd Ed and IEC 60601-2-10 IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
S The relationship between IEC 60601-2-18 and IEC 60601-2-37 - Ultrasound Project IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Relationship between Crimping ID & Crimping Depth - Minitab usage Statistical Analysis Tools, Techniques and SPC 3
kedarg6500 Relationship between Cp and Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 4
L Arima Output - Relationship between my raw data and the residuals generated Using Minitab Software 1
C The relationship between OEM and the subcontracted manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Ajit Basrur Relationship between Blend Uniformity and Content Uniformity Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
D Relationship between ISO 9001:2000 and EFQM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L What's the relationship between LVD (low voltage directive) and MDD EU Medical Device Regulations 3
D The relationship between the FMEA and Control Plan FMEA and Control Plans 4
K Relationship between "Corrections/Removals" procedure and "Recall" procedure US Food and Drug Administration (FDA) 11
M Relationship between APQP and CM (Configuration Management) APQP and PPAP 11
S Relationship and Differences between ISO 16949 and ISO 15504 (SPICE) IATF 16949 - Automotive Quality Systems Standard 3
kedarg6500 Relationship between Cp & Cpk Statistical Analysis Tools, Techniques and SPC 5
M Relationship between quality assurance costs and failure costs Quality Tools, Improvement and Analysis 4
L Relationship between Calibration and a Gage R&R study? General Measurement Device and Calibration Topics 9
V Relationship between Severity and Class FMEA and Control Plans 3
D Relationship between ANOVA and measurement accuracy - Mechanical strenth of a closure Statistical Analysis Tools, Techniques and SPC 13
A ISO TS 16949 - Relationship between requirements and processes IATF 16949 - Automotive Quality Systems Standard 0
J FMEA - What is the relationship between Detection and Prevention? QP Newbie question. FMEA and Control Plans 12
J Relationship Between SAP and ISO9001:2000 Quality Assurance and Compliance Software Tools and Solutions 1
P The relationship between ISO 17025 vs. ANSI Z540-1 ISO 17025 related Discussions 2
L Is there any relationship between Cpk & Right First Time? First Pass Yield (FPY)? Capability, Accuracy and Stability - Processes, Machines, etc. 4
L 'Distributor' definition & MDR/MSR relationship EU Medical Device Regulations 3
S APQP Relationship Diagram APQP and PPAP 2
J CEN/TR 17223:2018 Guidance on the relationship between13485 and MDR.. worth the money?? ISO 13485:2016 - Medical Device Quality Management Systems 2
K Does OEM/OBL-Relationship need to involve an EU Authorized Representative? EU Medical Device Regulations 11
MDD_QNA What is the relationship with the CSA group? Canada Medical Device Regulations 10
T ITAR/EAR relationship and Flow Down to Suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C DFMEA vs. PFMEA Relationship: The cause in DFMEA becomes Failure in the PFMEA FMEA and Control Plans 2
J Responsibilities, Authorities and Relationships - What does Relationship mean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
5 ISO 13485 relationship to 21 CFR 820 ISO 13485:2016 - Medical Device Quality Management Systems 17
alonFAI Definition Failure Review Board and FRACAS - Relationship and differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
T Capability Level Relationship with ISO/IEC 20000 Achievement IT (Information Technology) Service Management 2
N Agile 9.3.1 Relationship Searches - Meaning of Message Manufacturing and Related Processes 1
C CRMs (Customer Relationship Management) to help achieve ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C ISO9001 and ISO 13485 Relationship? Can we do both effectively? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Relationship Pictures Coffee Break and Water Cooler Discussions 10
shimonv Operator vs. Manufacturer Relationship and ISO 13485 / CE Requirements ISO 13485:2016 - Medical Device Quality Management Systems 5
