Reliability calculation for repairable system
#11
What level of reliability (e.g., 80%, 90%, etc.) do you want to demonstrate and at what level of confidence?
tahirawan11
#14
Thanks for the demonstration plan and i can see theses plans are valid for 'zero failures' and during my test i do see some failures so i guess the 'testing time' should increase for a given sample size if I observe any failures during test?
Also does the 'testing time' represent the testing time for each sample or the sum of time for all the samples under test?
H Sample Size Calculation (Confidence Interval and Reliability) - Medical Devices Reliability Analysis - Predictions, Testing and Standards 6
S Reliability Calculation - MTBF/MTTF for Static Mounts of Rail Industry Reliability Analysis - Predictions, Testing and Standards 2
C Reliability Calculation without Failure (Success Run) Reliability Analysis - Predictions, Testing and Standards 10
D Validate 99.5% reliability 90% confidence - Sample size calculation Reliability Analysis - Predictions, Testing and Standards 4
Awais Forklift Reliability Analysis Manufacturing and Related Processes 6
M Reliability Testing - Weibull Analysis Help Reliability Analysis - Predictions, Testing and Standards 4
A Accelerated Reliability Demonstration Test Reliability Analysis - Predictions, Testing and Standards 4
L ISO 2859-2 LQL sampling plan linked to %confidence/%reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J 95% reliability for calibration frequency Calibration Frequency (Interval) 7
M How to Plan and Test the Reliability of Medical Devices Reliability Analysis - Predictions, Testing and Standards 1
L Reliability Block Diagrams (RBDs) helper for review. Reliability Analysis - Predictions, Testing and Standards 1
K Taguchi Experiments for Factorial Design Analysis - Reliability of Minitab Results Using Minitab Software 1
J Calculating Reliability for Subsystems in Series Reliability Analysis - Predictions, Testing and Standards 15
N Reliability Testing of a Single-Use (Disposable) Medical Device Reliability Analysis - Predictions, Testing and Standards 4
R Regression for MTBF (Medical Device: Repairs vs Install Base) with Reliability Data Reliability Analysis - Predictions, Testing and Standards 16
A Demonstration Test Plan for Reliability of Big Equipment Reliability Analysis - Predictions, Testing and Standards 5
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
G Metrology Laser Reliability General Measurement Device and Calibration Topics 2
S Reliability Software Recommendations Reliability Analysis - Predictions, Testing and Standards 4
D Cpk relation to Reliability Capability, Accuracy and Stability - Processes, Machines, etc. 4
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
M Defining Reliability and Confidence Levels Reliability Analysis - Predictions, Testing and Standards 3
R Standard for Reliability/Performance Test on a Electro Mechanical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T "Time of Demonstration" requirement for Reliability Test Reliability Analysis - Predictions, Testing and Standards 1
C Reliability Testing Protocol on a new Peristaltic Pump Reliability Analysis - Predictions, Testing and Standards 14
T Reliability Lifetime Requirement Demonstration Test Reliability Analysis - Predictions, Testing and Standards 3
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
A Repairable System Reliability Analysis: Uptime/Downtime Hours, Failure Modes Data Reliability Analysis - Predictions, Testing and Standards 2
D Reliability of an Attribute Inspection based on Historical Data Capability, Accuracy and Stability - Processes, Machines, etc. 8
R Minitab - Reliability / Survival Distribution Analysis Using Minitab Software 1
C CRE (Certified Reliability Engineer) Exam 03/02/2013 Professional Certifications and Degrees 11
D Demonstration Reliability Test Formula with allowance for 'x' Failures Reliability Analysis - Predictions, Testing and Standards 6
R Military Land Vehicle Reliability with Only 1 vehicle & Only 1 Endurance Test Reliability Analysis - Predictions, Testing and Standards 5
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
J Relationship between Quality, Reliability, Price and Delivery Misc. Quality Assurance and Business Systems Related Topics 7
L Determining Cpk based on a given Sample Size, Confidence Level, & Reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
7 Is testing 99.7% reliable? Reliability Question Reliability Analysis - Predictions, Testing and Standards 3
J Reliability Centered Maintenance - Nowlan & Heap's AD-A066579 (1978) Reliability Analysis - Predictions, Testing and Standards 1
E Question on the Reliability of the Faroarm vs. Romer Arm Calibration and Metrology Software and Hardware 10
O Can anyone recommend appropriate standard for Reliability Testing of Cables Other Medical Device Related Standards 3
M ERTMS/ETCS RAM (Reliability, Availability & Maintainability) Requirements Specs. Various Other Specifications, Standards, and related Requirements 2
D Reliability Growth methodology (Duane, CrowAMSAA) - Test Planning Reliability Analysis - Predictions, Testing and Standards 5
F Reliability of a System - Estimation of R(t) having constant failure rate "Lambda" Reliability Analysis - Predictions, Testing and Standards 2
B Problem with Reliability and Availability Formula Reliability Analysis - Predictions, Testing and Standards 8
C Purpose of using different Distributions to solve Reliability Problems? Reliability Analysis - Predictions, Testing and Standards 2
H What's the meaning of "a minimum 95% reliability target"? General Measurement Device and Calibration Topics 14
S Reliability Conference Suggestions Reliability Analysis - Predictions, Testing and Standards 5
Q Reliability of a Ferrite Inductor mounted on a PCBA Reliability Analysis - Predictions, Testing and Standards 1
S Aerospace Standard - What document defines reliability concept AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B Determining Statistical Confidence and Reliability Levels with Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
