Reliability Calculation without Failure (Success Run)
convivial
I would like to know the reliability of 20 samples. Assume there is no failure:
Reliability R(t) = ?
Confidence Level P = 80% (in every case)
Required test duration = 100 hours
Weibull paramete b = 2 (always remains 2)
I know I can use this formula: R(t) = (1 - P)^(1/(L)^b.n) where L = life time ratio
But before applying this formula I divide these 20 samples in to two groups having 10 samples each.
For first group (10 samples) I take Lifetime ratio (L) = 0.7, I apply the above formula and get R(t) = 65% (say)
For Second group (10 samples) I take Lifetime ratio (L) = 1.3, I apply the above formula and get R(t) = 70% (say)
Now I have got two reliabilities for these 2 groups. Can I combine these two reliabilities to get a final reliability? If yes, then how shall I combine these two? Shall I multiply or simple add these two?
Marc
Hunkered Down for the Duration
Any Reliability Engineers out there who can help with this? My Thanks! in advance!
Why did you divide the samples into two groups?
Are these from different time periods, suppliers, different components in series, in parallel?
The answer depends on your response.
convivial
Thanks for your reply!
No these are not components instead 20 identical systems. Therefore the concept of parallel or series does not apply here. Sometimes it happens that when you have to test them for a particular period of time and no failure occurs then you say ok I would like to test for a longer time to see whether if the samples still survive or not. E.g. if these survive then their reliability would increase.
In order to make the problem clear lets say there were 20 identical samples (not components) in a test chamber and first ten samples were tested for 100 hours (exactly equal to required test time) and were taken out but the remaining ten were tested for longer time say 200 hours.
I can calculate the reliability for each group of samples as shown in my first post but someone told me that in this case I need to find the total reliability i.e. have to combine the reliabilities of these two groups and here is the point where I don't know how to combine the reliabilities?
P.S. You can see the formula of calculating reliability of each group in the first post.
If you can attach or list the actual data, I can calculate this for you. This is just a censoring issue. The complete data set can be used.
convivial
The complete data is:
Group "A" Samples
1-10 80 hours
Group "B" Samples
11-20 200 hours
I want to find the total reliability
I performed a Bayes analysis with a Weibul shape parameter = 2. With zero failures, I had to perform a Maximum Likelihood estimate for the lower 95% confidence bound.
The Minitab analysis is attached. The asterices appear because there are zero failures upon which to estimate the values.
topguy
Could you kindly provide the step by step guidence on how to calculate in MINITab? thanks a lot
V
vida99
hi
could you please tell me where did you get this formula( R(t) = (1 - P)^(1/(L)^b.n) ).
im searching for it everywhere and i didnt find it.
thanks
The OP is no longer active on this forum.
I am not familiar with that approach. I did track it down to section 8.3, equation 8.5 in Reliability in Automotive and Mechanical Engineering: Determination of Component and System Reliability written by Bernd Bertsche and published by Springer.
H Sample Size Calculation (Confidence Interval and Reliability) - Medical Devices Reliability Analysis - Predictions, Testing and Standards 6
T Reliability calculation for repairable system Reliability Analysis - Predictions, Testing and Standards 14
S Reliability Calculation - MTBF/MTTF for Static Mounts of Rail Industry Reliability Analysis - Predictions, Testing and Standards 2
D Validate 99.5% reliability 90% confidence - Sample size calculation Reliability Analysis - Predictions, Testing and Standards 4
M Reliability Testing - Weibull Analysis Help Reliability Analysis - Predictions, Testing and Standards 4
A Accelerated Reliability Demonstration Test Reliability Analysis - Predictions, Testing and Standards 4
L ISO 2859-2 LQL sampling plan linked to %confidence/%reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J 95% reliability for calibration frequency Calibration Frequency (Interval) 7
M How to Plan and Test the Reliability of Medical Devices Reliability Analysis - Predictions, Testing and Standards 1
L Reliability Block Diagrams (RBDs) helper for review. Reliability Analysis - Predictions, Testing and Standards 1
K Taguchi Experiments for Factorial Design Analysis - Reliability of Minitab Results Using Minitab Software 1
J Calculating Reliability for Subsystems in Series Reliability Analysis - Predictions, Testing and Standards 15
N Reliability Testing of a Single-Use (Disposable) Medical Device Reliability Analysis - Predictions, Testing and Standards 4
R Regression for MTBF (Medical Device: Repairs vs Install Base) with Reliability Data Reliability Analysis - Predictions, Testing and Standards 16
A Demonstration Test Plan for Reliability of Big Equipment Reliability Analysis - Predictions, Testing and Standards 5
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
G Metrology Laser Reliability General Measurement Device and Calibration Topics 2
S Reliability Software Recommendations Reliability Analysis - Predictions, Testing and Standards 4
D Cpk relation to Reliability Capability, Accuracy and Stability - Processes, Machines, etc. 4
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
M Defining Reliability and Confidence Levels Reliability Analysis - Predictions, Testing and Standards 3
R Standard for Reliability/Performance Test on a Electro Mechanical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T "Time of Demonstration" requirement for Reliability Test Reliability Analysis - Predictions, Testing and Standards 1
C Reliability Testing Protocol on a new Peristaltic Pump Reliability Analysis - Predictions, Testing and Standards 14
T Reliability Lifetime Requirement Demonstration Test Reliability Analysis - Predictions, Testing and Standards 3
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
A Repairable System Reliability Analysis: Uptime/Downtime Hours, Failure Modes Data Reliability Analysis - Predictions, Testing and Standards 2
D Reliability of an Attribute Inspection based on Historical Data Capability, Accuracy and Stability - Processes, Machines, etc. 8
R Minitab - Reliability / Survival Distribution Analysis Using Minitab Software 1
C CRE (Certified Reliability Engineer) Exam 03/02/2013 Professional Certifications and Degrees 11
D Demonstration Reliability Test Formula with allowance for 'x' Failures Reliability Analysis - Predictions, Testing and Standards 6
R Military Land Vehicle Reliability with Only 1 vehicle & Only 1 Endurance Test Reliability Analysis - Predictions, Testing and Standards 5
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
J Relationship between Quality, Reliability, Price and Delivery Misc. Quality Assurance and Business Systems Related Topics 7
L Determining Cpk based on a given Sample Size, Confidence Level, & Reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
7 Is testing 99.7% reliable? Reliability Question Reliability Analysis - Predictions, Testing and Standards 3
J Reliability Centered Maintenance - Nowlan & Heap's AD-A066579 (1978) Reliability Analysis - Predictions, Testing and Standards 1
E Question on the Reliability of the Faroarm vs. Romer Arm Calibration and Metrology Software and Hardware 10
O Can anyone recommend appropriate standard for Reliability Testing of Cables Other Medical Device Related Standards 3
M ERTMS/ETCS RAM (Reliability, Availability & Maintainability) Requirements Specs. Various Other Specifications, Standards, and related Requirements 2
D Reliability Growth methodology (Duane, CrowAMSAA) - Test Planning Reliability Analysis - Predictions, Testing and Standards 5
F Reliability of a System - Estimation of R(t) having constant failure rate "Lambda" Reliability Analysis - Predictions, Testing and Standards 2
B Problem with Reliability and Availability Formula Reliability Analysis - Predictions, Testing and Standards 8
C Purpose of using different Distributions to solve Reliability Problems? Reliability Analysis - Predictions, Testing and Standards 2
H What's the meaning of "a minimum 95% reliability target"? General Measurement Device and Calibration Topics 14
S Reliability Conference Suggestions Reliability Analysis - Predictions, Testing and Standards 5
Q Reliability of a Ferrite Inductor mounted on a PCBA Reliability Analysis - Predictions, Testing and Standards 1
S Aerospace Standard - What document defines reliability concept AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
B Determining Statistical Confidence and Reliability Levels with Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Reliability Prediction - Predicting the Reliability of an Inductor (Semi-conductor) Reliability Analysis - Predictions, Testing and Standards 8
