Reliability Growth methodology (Duane, CrowAMSAA) - Test Planning
doops
I am trying to implement Reliability Growth methodology (Duane, CrowAMSAA) in my company to help with field test sizing and test time.
I would like to know any other companies that use this methodology for test planning. Identifying companies and industries which use reliability growth models for test planning would help me sell this idea.
Thanks.
Sturmkind
Hi, doops!
All automotive and aerospace companies use this methodology or a variation thoughout the product development and product realization cycle. Specifically, automotive safety restraints (seat belts, air bags) have a target of 5 '9' reliability meaning 0.99999 reliability @ either 0.90 or 0.95 confidence. depending upon whether it is Design Reliability (generally .99999 @ 0.90 confidence with zero failures) or Process Reliability (generally .99999 @ .95 confidence with zero failures).
The initial DFMEAs & PFMEA's start with higher Risk Priority Numbers (RPN) since some performance test results are considered unknown or unproven so the detection and occurrence values will be higher, regardless of severity. Initial testing of small quantities without failure may allow the detection and/or occurrence values to begin to be reduced. A single failure should result in a design change of either product, process, or both. At program Milestone validation points, test quantities are increased as Start Of Regular Production approaches and successful testing is subtracted from the production life goal. After all, with vehicle life at ~20 years demonstrating .99999 @ .90C 230,259 OK tests. This quantity is feasible for something like number of landings on an aircraft carrier, but not so good for the carrier itself.....
Typical companies that use this are all OEMs, Autoliv, Key Safety Systems, Takata, TRW, and so forth.
doops
Hello Sturmkind!
Thank you so much for replying!
Just out of curiosity, would you please elaborate a little bit more on the reliability growth testing? Is the growth plan through several individual test phases, and they use reliability growth models to tie all the tests together?
For example, after test phase I, the article has 100 cycle MTBF. Fix failures. Phase II, initial MTBF is 150 cycles. Test. After Phase II, MTBF is 200 cycles. Fix, and continue until meeting reliability targets?
Is the reason for using reliability growth, because one single zero failure test would yield outrageous sample sizes and test times?
Using binomial equation, I calculate needing 23,026 samples with 10 lives to get R 99.999% & C 90% with zero failures.
Thanks again!
Sturmkind
There needs to be a growth plan associated with each response variable expectation.
Using a seat-belt system as an example there will be several key responses:
A) Ability to cycle 'x' times full extraction / retraction without exceeding 'y' Nm force in 'z' seconds.
B) Lock-up speed of the system in 'x' milliseconds upon impact at 'y' Nm force.
Those would be performance related.
C) Design to restrain a 95% adult with minimum neck/torso Nm force upon impact of 'y' Nm.
D) Lock-up speed of the system in 'x' milliseconds upon impact at 'y' Nm force with full system retention integrity. Meaning, upon impact the mooring bolts don't tear out of the floor, the seat-belt works as intended with the air bags, the seat integrity is maintained, the occupant is restrained without undue injury, and so forth.
Cyclic testing of A & B can start and continue as C & B are validated. C & B will have much smaller test sizes and a test plan with a flatter angle and larger confidence bands than A & B because the tests are destructive, and very expensive.
Does that help?
doops
I think I understand. I appreciate you taking the time to answer my questions.
Is the Duane, CrowAMSAA or another growth model used in the validation planning and tracking of reliability?
Thanks again!
Sturmkind
Statistical Steven may disagree with me but they are variations on a theme. If the results are within 5% of another then they are considered equivalent. The log/log model should be fine.
S Reliability issue - Frequent component failure of the product Reliability Analysis - Predictions, Testing and Standards 0
Awais Forklift Reliability Analysis Manufacturing and Related Processes 6
M Reliability Testing - Weibull Analysis Help Reliability Analysis - Predictions, Testing and Standards 4
A Accelerated Reliability Demonstration Test Reliability Analysis - Predictions, Testing and Standards 4
L ISO 2859-2 LQL sampling plan linked to %confidence/%reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J 95% reliability for calibration frequency Calibration Frequency (Interval) 7
M How to Plan and Test the Reliability of Medical Devices Reliability Analysis - Predictions, Testing and Standards 1
L Reliability Block Diagrams (RBDs) helper for review. Reliability Analysis - Predictions, Testing and Standards 1
H Sample Size Calculation (Confidence Interval and Reliability) - Medical Devices Reliability Analysis - Predictions, Testing and Standards 9
K Taguchi Experiments for Factorial Design Analysis - Reliability of Minitab Results Using Minitab Software 1
J Calculating Reliability for Subsystems in Series Reliability Analysis - Predictions, Testing and Standards 15
N Reliability Testing of a Single-Use (Disposable) Medical Device Reliability Analysis - Predictions, Testing and Standards 4
R Regression for MTBF (Medical Device: Repairs vs Install Base) with Reliability Data Reliability Analysis - Predictions, Testing and Standards 16
A Demonstration Test Plan for Reliability of Big Equipment Reliability Analysis - Predictions, Testing and Standards 5
T Reliability calculation for repairable system Reliability Analysis - Predictions, Testing and Standards 14
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
G Metrology Laser Reliability General Measurement Device and Calibration Topics 2
S Reliability Software Recommendations Reliability Analysis - Predictions, Testing and Standards 4
D Cpk relation to Reliability Capability, Accuracy and Stability - Processes, Machines, etc. 4
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
M Defining Reliability and Confidence Levels Reliability Analysis - Predictions, Testing and Standards 8
R Standard for Reliability/Performance Test on a Electro Mechanical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T "Time of Demonstration" requirement for Reliability Test Reliability Analysis - Predictions, Testing and Standards 1
C Reliability Testing Protocol on a new Peristaltic Pump Reliability Analysis - Predictions, Testing and Standards 14
T Reliability Lifetime Requirement Demonstration Test Reliability Analysis - Predictions, Testing and Standards 3
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
A Repairable System Reliability Analysis: Uptime/Downtime Hours, Failure Modes Data Reliability Analysis - Predictions, Testing and Standards 2
D Reliability of an Attribute Inspection based on Historical Data Capability, Accuracy and Stability - Processes, Machines, etc. 8
S Reliability Calculation - MTBF/MTTF for Static Mounts of Rail Industry Reliability Analysis - Predictions, Testing and Standards 2
R Minitab - Reliability / Survival Distribution Analysis Using Minitab Software 1
C CRE (Certified Reliability Engineer) Exam 03/02/2013 Professional Certifications and Degrees 11
D Demonstration Reliability Test Formula with allowance for 'x' Failures Reliability Analysis - Predictions, Testing and Standards 6
R Military Land Vehicle Reliability with Only 1 vehicle & Only 1 Endurance Test Reliability Analysis - Predictions, Testing and Standards 5
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
J Relationship between Quality, Reliability, Price and Delivery Misc. Quality Assurance and Business Systems Related Topics 7
L Determining Cpk based on a given Sample Size, Confidence Level, & Reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
7 Is testing 99.7% reliable? Reliability Question Reliability Analysis - Predictions, Testing and Standards 3
J Reliability Centered Maintenance - Nowlan & Heap's AD-A066579 (1978) Reliability Analysis - Predictions, Testing and Standards 1
E Question on the Reliability of the Faroarm vs. Romer Arm Calibration and Metrology Software and Hardware 10
O Can anyone recommend appropriate standard for Reliability Testing of Cables Other Medical Device Related Standards 3
M ERTMS/ETCS RAM (Reliability, Availability & Maintainability) Requirements Specs. Various Other Specifications, Standards, and related Requirements 2
F Reliability of a System - Estimation of R(t) having constant failure rate "Lambda" Reliability Analysis - Predictions, Testing and Standards 2
B Problem with Reliability and Availability Formula Reliability Analysis - Predictions, Testing and Standards 8
C Purpose of using different Distributions to solve Reliability Problems? Reliability Analysis - Predictions, Testing and Standards 2
C Reliability Calculation without Failure (Success Run) Reliability Analysis - Predictions, Testing and Standards 10
H What's the meaning of "a minimum 95% reliability target"? General Measurement Device and Calibration Topics 14
S Reliability Conference Suggestions Reliability Analysis - Predictions, Testing and Standards 5
Q Reliability of a Ferrite Inductor mounted on a PCBA Reliability Analysis - Predictions, Testing and Standards 1
S Aerospace Standard - What document defines reliability concept AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B Determining Statistical Confidence and Reliability Levels with Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
