Reliability issue - Frequent component failure of the product
I am new to reliability. I recently encountered during my current work : I have a frequent component failure of the product made in our plant. The component has 4 types: A, B, C & D.
The product is operating in various oilfield condition across the world, mostly in the USA. The 4 types of component could have different run life in various oil well conditions or operation conditions (e.g. high temperature, low temperature, sandy, high pressure, low pressure, depth of well, etc.). Now management require my reliability team to define a matrix as a guideline quickly to advise customer “under what parameters of well conditions should use what types of component” should be used based on the many failure reports worldwide retrieved from database.
Due to time urgency, I wonder anyone have advices, e.g. sensitivity analysis, DOE (may take long time for testing), and what software can be used. Thank you. Shang.
stevegyro
Mr. Shang,
Are A,B,C,D the same material alloy, geometry, and used in similar fashion?
The big challenge in determining failure factors in any industry, is in the eliminatation of ‘noise’ (unwanted, useless data).
Human factors, certainly in the oil field harsh environments, need to be accounted for carefully.
Unfortunately, people-money politics can sometimes occur. Parts ‘going missing’ or frequently breaking) for financial gain: IE Union leaders and supply companies usually have a relationship and (replacement parts) is ‘big business’. Added bonus - workers enjoy the over-time (paychecks) necessary to replace broken parts.
Mention of this is not to dis-trust the field workers, but if some crews have more breakage/part-failures than others, the ‘failure frequency data’ will not be fully representing the quality of the parts.
”All crews being equal”, a recommendation is to write down failure modes in several categories:
a. Design & as-built -Static: as-built (clearances too tight or loose; tolerance stack-up, interference/compression fit, and a few others)
b. Design & as-built -Dynamic: cyclic (in/out of balance; fatigue causes; Micro crack expansion to major crack. Heat generation from friction from FOD (SAND); Heat generation from cyclic strain on parts; internal heat/cracking From bending moments or shear.
c. Metallurgy design, and as received. Built-up and hidden stresses from heat-treat; from welding; from machining; from corrosion.
This collection of data is vital to begin solving whatever you wish to fix.
The good news is younger clerks or engineering interns can do a lot of the heavy lifting. It may seem like a goose-chase at first, but with the correct leadership, pays big returns and keeps your customer happy.
BR,
Stephen Giarratana
stevegyro
Also, it is almost impossible to solve all 4 problem areas simultaneously.
Unless part is same geometry/shape, material, and type of in-service use for the parts.
If the nature of failures is different between the 4 parts, i suggest choosing the ‘low hanging fruit’ (item/ process in field) the largest cost factor to your company, and most important- the satisfaction of your customer and the field workers.
Upon nailing the biggest failure item, your team will learn the process of RCA in a way that speeds up solving problems B, C, and D.
BR,
Stephen G.
Metrology Sr. Engr.
J Unfamiliar Reliability Term Reliability Analysis - Predictions, Testing and Standards 7
J Reliability or robustness Reliability Analysis - Predictions, Testing and Standards 23
Awais Forklift Reliability Analysis Manufacturing and Related Processes 6
M Reliability Testing - Weibull Analysis Help Reliability Analysis - Predictions, Testing and Standards 4
A Accelerated Reliability Demonstration Test Reliability Analysis - Predictions, Testing and Standards 4
L ISO 2859-2 LQL sampling plan linked to %confidence/%reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J 95% reliability for calibration frequency Calibration Frequency (Interval) 7
M How to Plan and Test the Reliability of Medical Devices Reliability Analysis - Predictions, Testing and Standards 1
L Reliability Block Diagrams (RBDs) helper for review. Reliability Analysis - Predictions, Testing and Standards 1
H Sample Size Calculation (Confidence Interval and Reliability) - Medical Devices Reliability Analysis - Predictions, Testing and Standards 9
K Taguchi Experiments for Factorial Design Analysis - Reliability of Minitab Results Using Minitab Software 1
J Calculating Reliability for Subsystems in Series Reliability Analysis - Predictions, Testing and Standards 15
N Reliability Testing of a Single-Use (Disposable) Medical Device Reliability Analysis - Predictions, Testing and Standards 4
R Regression for MTBF (Medical Device: Repairs vs Install Base) with Reliability Data Reliability Analysis - Predictions, Testing and Standards 16
A Demonstration Test Plan for Reliability of Big Equipment Reliability Analysis - Predictions, Testing and Standards 5
T Reliability calculation for repairable system Reliability Analysis - Predictions, Testing and Standards 14
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
G Metrology Laser Reliability General Measurement Device and Calibration Topics 2
S Reliability Software Recommendations Reliability Analysis - Predictions, Testing and Standards 4
D Cpk relation to Reliability Capability, Accuracy and Stability - Processes, Machines, etc. 4
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
M Defining Reliability and Confidence Levels Reliability Analysis - Predictions, Testing and Standards 8
R Standard for Reliability/Performance Test on a Electro Mechanical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T "Time of Demonstration" requirement for Reliability Test Reliability Analysis - Predictions, Testing and Standards 1
C Reliability Testing Protocol on a new Peristaltic Pump Reliability Analysis - Predictions, Testing and Standards 14
T Reliability Lifetime Requirement Demonstration Test Reliability Analysis - Predictions, Testing and Standards 3
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
A Repairable System Reliability Analysis: Uptime/Downtime Hours, Failure Modes Data Reliability Analysis - Predictions, Testing and Standards 2
D Reliability of an Attribute Inspection based on Historical Data Capability, Accuracy and Stability - Processes, Machines, etc. 8
S Reliability Calculation - MTBF/MTTF for Static Mounts of Rail Industry Reliability Analysis - Predictions, Testing and Standards 2
R Minitab - Reliability / Survival Distribution Analysis Using Minitab Software 1
C CRE (Certified Reliability Engineer) Exam 03/02/2013 Professional Certifications and Degrees 11
D Demonstration Reliability Test Formula with allowance for 'x' Failures Reliability Analysis - Predictions, Testing and Standards 6
R Military Land Vehicle Reliability with Only 1 vehicle & Only 1 Endurance Test Reliability Analysis - Predictions, Testing and Standards 5
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
J Relationship between Quality, Reliability, Price and Delivery Misc. Quality Assurance and Business Systems Related Topics 7
L Determining Cpk based on a given Sample Size, Confidence Level, & Reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
7 Is testing 99.7% reliable? Reliability Question Reliability Analysis - Predictions, Testing and Standards 3
J Reliability Centered Maintenance - Nowlan & Heap's AD-A066579 (1978) Reliability Analysis - Predictions, Testing and Standards 1
E Question on the Reliability of the Faroarm vs. Romer Arm Calibration and Metrology Software and Hardware 10
O Can anyone recommend appropriate standard for Reliability Testing of Cables Other Medical Device Related Standards 3
M ERTMS/ETCS RAM (Reliability, Availability & Maintainability) Requirements Specs. Various Other Specifications, Standards, and related Requirements 2
D Reliability Growth methodology (Duane, CrowAMSAA) - Test Planning Reliability Analysis - Predictions, Testing and Standards 5
F Reliability of a System - Estimation of R(t) having constant failure rate "Lambda" Reliability Analysis - Predictions, Testing and Standards 2
B Problem with Reliability and Availability Formula Reliability Analysis - Predictions, Testing and Standards 8
C Purpose of using different Distributions to solve Reliability Problems? Reliability Analysis - Predictions, Testing and Standards 2
C Reliability Calculation without Failure (Success Run) Reliability Analysis - Predictions, Testing and Standards 10
H What's the meaning of "a minimum 95% reliability target"? General Measurement Device and Calibration Topics 14
S Reliability Conference Suggestions Reliability Analysis - Predictions, Testing and Standards 5
Q Reliability of a Ferrite Inductor mounted on a PCBA Reliability Analysis - Predictions, Testing and Standards 1
