Reliability Prediction - Predicting the Reliability of an Inductor (Semi-conductor)
QE
Dear Coves.
can any one help me to point to the tool which can help me to predict the reliability of an Inductor (semi-conductor).
can weibull plot help ?
- QE.
brahmaiah
Re: Reliability Prediction
Dear Coves.
- QE.
Reliability is not a measurable characteristic.Therfore it can be designated as a Special Characteristic.All specicial characteristics are achieved by controlling the inputs and the manufacturing p[rocess.So you have to follow following procedure:
a) Document a process
b)Validate by trials and controlling inputs
c)Monitor the manufacturing process strictly to conform to the validated process
d)Maintain a log of the process details.
There is no other shortcut available for your problem.
V.J.Brahmaiah
Re: Reliability Prediction - Predicting the Reliability of an Inductor (Semi-conducto
QE,
Are you a manufacturer of or a purchaser of inductors? Are you trying to perform accelerated life testing to predict actual life, or trying to model the reliability of an assembly using the reliability of the inductor?
Please provide enough information for us to help you.
Likes: QE
QE
We are purchasing this inductor from the commodity market. I am intrested to predict failure rate which can help understand the liklihood of failure of this inductors and assist in a recall decession.
The inductor is used in a life saving device and it failed once and caused the device to fail.
QE.
QE,
Ideally, you get this direct from the supplier, but low cost suppliers may not test or have a clue.
Here are some resources that may help you.
A point of caution. External source of inductor reliability typically provide an average failure rate. As with any distribution, this is a point estimate and actual failure rates may vary dramatically. This may be the result of supplier to supplier variation, lot to lot variation, etc.
QE
Miner, appreciate your quick response.
1. can you please suggest if the paper is a published journal paper
2. CAN YOU ALSO SHARE THE SOURCE FOR THE TEST DATA SHEETS (PDF)
QE.
I found the paper through this website for NASA's Electronic Parts and Packaging Program.
The reliability tests were from a supplier called Sun Spark Technology. They are meant to illustrate what one supplier does for reliability testing, not to endorse this supplier or the tests.
And as always generalized and theoretical models typically model what happens when nothing goes wrong at the manufacturer or the assembler, etc.
Real life is often messy.
A parallel path is to understand the exact causal mechanism of your failure and determine how prevalent that mechanism is in your inductor, assembly and/or use conditions. Remember that sometimes subcomponents fail when the causal factor lies in the assembly or usage. Stress - Strength.
Knowledge of the actual details combined with the theoretical models may help you understand if this specific failure mode is at a higher level than what can be tolerated.
Remember statistics can only help interpret what has happened and help interpret what will most likely happen if nothing changes. But physics always trumps statistics...
W
w_grunfeld
QE,
You got some good advice, however you asked the wrong question. I don't undersatnd why are you concerned with predicting the failure rate of inductors in a generic way, your concern should be your specifc part's probability of failure in practical terms. First off, most if not all part manufacurers data sheet specifically includes a disclaimer that they are NOT INTENDED FOR LIFE SUPPORTING APPLICATIONS.
What you should do is contact several manufacturers of the part and ask for their FIT data , based on actual life testing, not prediction. Also note that published data is by industry standard given at 60% confidence level, so ask them if they are willing to share the number for 90 0r 95 % confidence. Second you should look to use premium parts , such as parts that are screened per MIL-STD-883, or even better MIL SPEC PARTS, not ommercial common stock, you'll have to pay a premium price of course.Thirdly, follow the advice you received on design factors that you can control : derating, thermal management, HALT,etc.
Last but not least you should ESS screen (HASS ) your final product. All of thee are practical measures to increase reliability.
M Searching data for a reliability prediction - Calculating failure rate of an MCU Reliability Analysis - Predictions, Testing and Standards 1
S Reliability Prediction of Complex Assemblies Reliability Analysis - Predictions, Testing and Standards 2
M Reliability Testing - Weibull Analysis Help Reliability Analysis - Predictions, Testing and Standards 4
A Accelerated Reliability Demonstration Test Reliability Analysis - Predictions, Testing and Standards 4
L ISO 2859-2 LQL sampling plan linked to %confidence/%reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J 95% reliability for calibration frequency Calibration Frequency (Interval) 7
M How to Plan and Test the Reliability of Medical Devices Reliability Analysis - Predictions, Testing and Standards 1
L Reliability Block Diagrams (RBDs) helper for review. Reliability Analysis - Predictions, Testing and Standards 1
H Sample Size Calculation (Confidence Interval and Reliability) - Medical Devices Reliability Analysis - Predictions, Testing and Standards 6
K Taguchi Experiments for Factorial Design Analysis - Reliability of Minitab Results Using Minitab Software 1
J Calculating Reliability for Subsystems in Series Reliability Analysis - Predictions, Testing and Standards 15
N Reliability Testing of a Single-Use (Disposable) Medical Device Reliability Analysis - Predictions, Testing and Standards 4
R Regression for MTBF (Medical Device: Repairs vs Install Base) with Reliability Data Reliability Analysis - Predictions, Testing and Standards 16
A Demonstration Test Plan for Reliability of Big Equipment Reliability Analysis - Predictions, Testing and Standards 5
T Reliability calculation for repairable system Reliability Analysis - Predictions, Testing and Standards 14
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
G Metrology Laser Reliability General Measurement Device and Calibration Topics 2
S Reliability Software Recommendations Reliability Analysis - Predictions, Testing and Standards 4
D Cpk relation to Reliability Capability, Accuracy and Stability - Processes, Machines, etc. 4
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
M Defining Reliability and Confidence Levels Reliability Analysis - Predictions, Testing and Standards 3
R Standard for Reliability/Performance Test on a Electro Mechanical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T "Time of Demonstration" requirement for Reliability Test Reliability Analysis - Predictions, Testing and Standards 1
C Reliability Testing Protocol on a new Peristaltic Pump Reliability Analysis - Predictions, Testing and Standards 14
T Reliability Lifetime Requirement Demonstration Test Reliability Analysis - Predictions, Testing and Standards 3
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
A Repairable System Reliability Analysis: Uptime/Downtime Hours, Failure Modes Data Reliability Analysis - Predictions, Testing and Standards 2
D Reliability of an Attribute Inspection based on Historical Data Capability, Accuracy and Stability - Processes, Machines, etc. 8
S Reliability Calculation - MTBF/MTTF for Static Mounts of Rail Industry Reliability Analysis - Predictions, Testing and Standards 2
R Minitab - Reliability / Survival Distribution Analysis Using Minitab Software 1
C CRE (Certified Reliability Engineer) Exam 03/02/2013 Professional Certifications and Degrees 11
D Demonstration Reliability Test Formula with allowance for 'x' Failures Reliability Analysis - Predictions, Testing and Standards 6
R Military Land Vehicle Reliability with Only 1 vehicle & Only 1 Endurance Test Reliability Analysis - Predictions, Testing and Standards 5
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
J Relationship between Quality, Reliability, Price and Delivery Misc. Quality Assurance and Business Systems Related Topics 7
L Determining Cpk based on a given Sample Size, Confidence Level, & Reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
7 Is testing 99.7% reliable? Reliability Question Reliability Analysis - Predictions, Testing and Standards 3
J Reliability Centered Maintenance - Nowlan & Heap's AD-A066579 (1978) Reliability Analysis - Predictions, Testing and Standards 1
E Question on the Reliability of the Faroarm vs. Romer Arm Calibration and Metrology Software and Hardware 10
O Can anyone recommend appropriate standard for Reliability Testing of Cables Other Medical Device Related Standards 3
M ERTMS/ETCS RAM (Reliability, Availability & Maintainability) Requirements Specs. Various Other Specifications, Standards, and related Requirements 2
D Reliability Growth methodology (Duane, CrowAMSAA) - Test Planning Reliability Analysis - Predictions, Testing and Standards 5
F Reliability of a System - Estimation of R(t) having constant failure rate "Lambda" Reliability Analysis - Predictions, Testing and Standards 2
B Problem with Reliability and Availability Formula Reliability Analysis - Predictions, Testing and Standards 8
C Purpose of using different Distributions to solve Reliability Problems? Reliability Analysis - Predictions, Testing and Standards 2
C Reliability Calculation without Failure (Success Run) Reliability Analysis - Predictions, Testing and Standards 10
H What's the meaning of "a minimum 95% reliability target"? General Measurement Device and Calibration Topics 14
S Reliability Conference Suggestions Reliability Analysis - Predictions, Testing and Standards 5
Q Reliability of a Ferrite Inductor mounted on a PCBA Reliability Analysis - Predictions, Testing and Standards 1
S Aerospace Standard - What document defines reliability concept AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
