Reliability Prove-out, Pass-Fail Testing
JayGreen
I have only 15 samples of a fuse available. Each fuse is 6" long, containing a type of powder. The object is to prove with high reliability and confidence (~99%R/95%C) that the powder will burn continuously and not snuff or fizzle out.
To achieve this reliability and confidence is difficult. The only response seems to be pass/fail. Logistic regression seems a logical choice, but the independent variable may be difficult to decide upon (say, % binder, or amound of another ingredient). Even if the independent variable is determined, samples are limited to 15. With logistic regression, proving margin gets one the most bang for the buck, but replication at numerous inputs would be needed for most high reliabilities & confidence combinations.
DOE doesn't appear an option. I'd think the high reliability & confidence would be more difficult to prove out with multiple factors changing.
I see engineering confidence being shown, but not statistical confidence.
I know this is a bit vague, but I'd appreciate any ideas. There will likely be 1 or 2 input factors that can change.
More could be addressed (long term vs. short term lot production; homogeneity of the powder, more), but this seems enough for now.
Appreciate your input.
Marc
Fully vaccinated are you?
A quick "Bump". My Thanks in advance to anyone who can help with this one.
JayGreen
Thanks for the bump, Marc.:)
Sorry if my earlier note was a bit rushed and vague. What can be done in an experiment is not completely defined yet. Let me try and clarify a few things, though.
A total of 60 fuses will exist for qualification.
Two main objectives exist: (1) proving that the chosen powder (the composition chosen for qualification) will burn continuously/uniformly and not snuff; (2) determine a model to predict the fuse burn time with a precision of +/-10%.
I’d have to say that requirement #1 is more of a continuous burning. As the powder will be inside a metal tube, the uniformity of the burning would be difficult judge. It should be more of a judgment of whether it’s continuous or not (and no snuffing seen).
The non-snuffing requirement is new. Originally, there was only the objective to model burn time. 45 fuses have already been dedicated for modeling the burn time (the experiment’s target is a certain # of minutes +/- 10%). These 45 fuses will all be made of the powder composition that is eventually chosen. Each of these 45 fuses will have the same powder composition (binder, ingredients, homogeneity – should be as all will be made from one lot). Based on the historical variability of other powders (which are most likely more variable than the powder we’re testing), this 45 run test matrix will give adequate precision. There are only two factors involved in this 45 run experiment: temperature and conditioning time. The response here is certainly a variable one (burn time).
There shouldn’t be any reason why these 45 fuses can’t also be used to prove that the powder will burn continuously/uniformly and not snuff.
The response for the snuffing prove-out, though, is likely a pass/fail response (snuff / no snuff). I’d like to have a critical Y which is variable for acceptance/failure. Chances are slim, though. This will be discussed early this week and confirmed or not, but my hopes are not high.
15 additional fuses will be available that can be 100% dedicated for determining if the powder will burn continuously and not snuff. It may be advantageous to change a powder ingredient (if one is thought to be correlated to the chance of snuffing) in the testing of these 15 fuses. This is something that should be discussed early this coming week with the team involved. If an ingredient is changed, then it seems that these 15 additional fuses would become separated from the first 45 fuses due to the composition of the 45 fuses being the same, while the composition of the additional 15 fuses would be mostly different (vs. the 45 fuses).
If a single factor can be used, then possibly enough margin can be shown via logistic regression to show a high reliability of not snuffing with this ingredient/factor in a certain range. Not sure yet if a correlation like this exists – again, a discussion for early this week.
The fuse is actually about 6 inches in length (sorry – rushed and poor typing earlier). One of the criteria for success will be the continuous and complete burn of a fuse’s powder. Since a fuse would need to burn completely, I don’t see our being able to split a fuse into multiple fuses (as shorter fuses would not prove a full 6 inch burn).
Hope this clarifies things a bit better. I’d like to have 60 samples which I could test in a logistic regression manner with only one factor. That might get me to the reliability I want (not considering lot to lot variation). Not sure that this scenario will exist, though.
I appreciate your input,
Jay
J Unfamiliar Reliability Term Reliability Analysis - Predictions, Testing and Standards 7
J Reliability or robustness Reliability Analysis - Predictions, Testing and Standards 23
S Reliability issue - Frequent component failure of the product Reliability Analysis - Predictions, Testing and Standards 2
Awais Forklift Reliability Analysis Manufacturing and Related Processes 6
M Reliability Testing - Weibull Analysis Help Reliability Analysis - Predictions, Testing and Standards 4
A Accelerated Reliability Demonstration Test Reliability Analysis - Predictions, Testing and Standards 4
L ISO 2859-2 LQL sampling plan linked to %confidence/%reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J 95% reliability for calibration frequency Calibration Frequency (Interval) 7
M How to Plan and Test the Reliability of Medical Devices Reliability Analysis - Predictions, Testing and Standards 1
L Reliability Block Diagrams (RBDs) helper for review. Reliability Analysis - Predictions, Testing and Standards 1
H Sample Size Calculation (Confidence Interval and Reliability) - Medical Devices Reliability Analysis - Predictions, Testing and Standards 9
K Taguchi Experiments for Factorial Design Analysis - Reliability of Minitab Results Using Minitab Software 1
J Calculating Reliability for Subsystems in Series Reliability Analysis - Predictions, Testing and Standards 15
N Reliability Testing of a Single-Use (Disposable) Medical Device Reliability Analysis - Predictions, Testing and Standards 4
R Regression for MTBF (Medical Device: Repairs vs Install Base) with Reliability Data Reliability Analysis - Predictions, Testing and Standards 16
A Demonstration Test Plan for Reliability of Big Equipment Reliability Analysis - Predictions, Testing and Standards 5
T Reliability calculation for repairable system Reliability Analysis - Predictions, Testing and Standards 14
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
G Metrology Laser Reliability General Measurement Device and Calibration Topics 2
S Reliability Software Recommendations Reliability Analysis - Predictions, Testing and Standards 4
D Cpk relation to Reliability Capability, Accuracy and Stability - Processes, Machines, etc. 4
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
M Defining Reliability and Confidence Levels Reliability Analysis - Predictions, Testing and Standards 8
R Standard for Reliability/Performance Test on a Electro Mechanical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T "Time of Demonstration" requirement for Reliability Test Reliability Analysis - Predictions, Testing and Standards 1
C Reliability Testing Protocol on a new Peristaltic Pump Reliability Analysis - Predictions, Testing and Standards 14
T Reliability Lifetime Requirement Demonstration Test Reliability Analysis - Predictions, Testing and Standards 3
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
A Repairable System Reliability Analysis: Uptime/Downtime Hours, Failure Modes Data Reliability Analysis - Predictions, Testing and Standards 2
D Reliability of an Attribute Inspection based on Historical Data Capability, Accuracy and Stability - Processes, Machines, etc. 8
S Reliability Calculation - MTBF/MTTF for Static Mounts of Rail Industry Reliability Analysis - Predictions, Testing and Standards 2
R Minitab - Reliability / Survival Distribution Analysis Using Minitab Software 1
C CRE (Certified Reliability Engineer) Exam 03/02/2013 Professional Certifications and Degrees 11
D Demonstration Reliability Test Formula with allowance for 'x' Failures Reliability Analysis - Predictions, Testing and Standards 6
R Military Land Vehicle Reliability with Only 1 vehicle & Only 1 Endurance Test Reliability Analysis - Predictions, Testing and Standards 5
J Relationship between Quality, Reliability, Price and Delivery Misc. Quality Assurance and Business Systems Related Topics 7
L Determining Cpk based on a given Sample Size, Confidence Level, & Reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
7 Is testing 99.7% reliable? Reliability Question Reliability Analysis - Predictions, Testing and Standards 3
J Reliability Centered Maintenance - Nowlan & Heap's AD-A066579 (1978) Reliability Analysis - Predictions, Testing and Standards 1
E Question on the Reliability of the Faroarm vs. Romer Arm Calibration and Metrology Software and Hardware 10
O Can anyone recommend appropriate standard for Reliability Testing of Cables Other Medical Device Related Standards 3
M ERTMS/ETCS RAM (Reliability, Availability & Maintainability) Requirements Specs. Various Other Specifications, Standards, and related Requirements 2
D Reliability Growth methodology (Duane, CrowAMSAA) - Test Planning Reliability Analysis - Predictions, Testing and Standards 5
F Reliability of a System - Estimation of R(t) having constant failure rate "Lambda" Reliability Analysis - Predictions, Testing and Standards 2
B Problem with Reliability and Availability Formula Reliability Analysis - Predictions, Testing and Standards 8
C Purpose of using different Distributions to solve Reliability Problems? Reliability Analysis - Predictions, Testing and Standards 2
C Reliability Calculation without Failure (Success Run) Reliability Analysis - Predictions, Testing and Standards 10
H What's the meaning of "a minimum 95% reliability target"? General Measurement Device and Calibration Topics 14
S Reliability Conference Suggestions Reliability Analysis - Predictions, Testing and Standards 5
Q Reliability of a Ferrite Inductor mounted on a PCBA Reliability Analysis - Predictions, Testing and Standards 1
