Reliability Testing - Weibull Analysis Help
marcusja2002
Its been a long time since I've done any Reliability testing.
i know the formulas, I've just forgotten what each piece means.
I know I want with 95% confidence that my product will survive at least 132.5 hours before failure. How many hours do I need to run it in order to verify it will meet that?
I currently have 1 being tested, but I can throw more units at it to lower the number of hours needed to verify that.
Anyone with more statistical knowledge then I please help point me in the right direction.
Thanks in advance.
You will need to provide some additional information:
  • What distribution are you assuming? Weibull? What shape parameter? If you don't know the shape parameter, what is the failure mode? Is it wear out, random?
  • What reliability do you want to demonstrate at 132.5 hours? This is separate from the 95% confidence.
marcusja2002
What do you mean by shape of the parameter?
There is a material that will change shape depending on temperature. when above a specific temperature is completes a circuit. I need it to be able to at least make it 132.5 hours of sensing that temperature and completing the circuit. It can fail randomly.
I guess I would like it to have zero failures up to 132.5 hours.
If you assume that your failures follow a Weibull distribution, the shape parameter (beta), defines the type of failures seen. B < 1 indicates infant mortality failures, B = 1 indicates random failures due to over stress, and B > 1 indicate failures due to wear out.
When the material fails, why does it fail? Does the material age such that it no longer switches at the correct temperature? Does it fatigue and crack?
You need to define your requirement similar to: 95% reliability at 132.5 hours while operating at ## degrees C and cycling # times per hour with 95% confidence.
You need to assume something about how the failure times are distributed to answer your question. If we prove, for example, that only 1% of parts fail by 50 hours, how do we know what that means at 132.5 hours? We need to project reliability at one time to reliability at another, so we need to assume a life distribution, as Miner correctly stated above.
The basic concept here is that some failure modes get worse with age (to varying degrees), some actually get better with age (such as manufacturing defects), and by assuming a Weibull distribution and a slope of say 2, we're basically saying "I know it will get worse at this rate." That allows you to make the connection between, let's say, 99% reliability at 50 hours and 95% reliability at 132.5 hours (which would correspond to a Weibull slope of 1.7).
Here's a more thorough explanation of the different mathematical methodologies of reliability test design, with explanations as to why you need to assume the life distribution in this case.
Full disclosure: I work for the company that produces this wiki (ReliaWiki) and the software referenced in it (Weibull++).
N Reliability Testing of a Single-Use (Disposable) Medical Device Reliability Analysis - Predictions, Testing and Standards 4
C Reliability Testing Protocol on a new Peristaltic Pump Reliability Analysis - Predictions, Testing and Standards 14
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
7 Is testing 99.7% reliable? Reliability Question Reliability Analysis - Predictions, Testing and Standards 3
O Can anyone recommend appropriate standard for Reliability Testing of Cables Other Medical Device Related Standards 3
R Semiconductor Reliability Testing for System - Operating Life Test Reliability Analysis - Predictions, Testing and Standards 11
C Presentation on the concepts of reliability testing and calculations needed Reliability Analysis - Predictions, Testing and Standards 3
J Reliability or robustness Reliability Analysis - Predictions, Testing and Standards 23
S Reliability issue - Frequent component failure of the product Reliability Analysis - Predictions, Testing and Standards 2
Awais Forklift Reliability Analysis Manufacturing and Related Processes 6
A Accelerated Reliability Demonstration Test Reliability Analysis - Predictions, Testing and Standards 4
L ISO 2859-2 LQL sampling plan linked to %confidence/%reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J 95% reliability for calibration frequency Calibration Frequency (Interval) 7
M How to Plan and Test the Reliability of Medical Devices Reliability Analysis - Predictions, Testing and Standards 1
L Reliability Block Diagrams (RBDs) helper for review. Reliability Analysis - Predictions, Testing and Standards 1
H Sample Size Calculation (Confidence Interval and Reliability) - Medical Devices Reliability Analysis - Predictions, Testing and Standards 9
K Taguchi Experiments for Factorial Design Analysis - Reliability of Minitab Results Using Minitab Software 1
J Calculating Reliability for Subsystems in Series Reliability Analysis - Predictions, Testing and Standards 15
R Regression for MTBF (Medical Device: Repairs vs Install Base) with Reliability Data Reliability Analysis - Predictions, Testing and Standards 16
A Demonstration Test Plan for Reliability of Big Equipment Reliability Analysis - Predictions, Testing and Standards 5
T Reliability calculation for repairable system Reliability Analysis - Predictions, Testing and Standards 14
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
G Metrology Laser Reliability General Measurement Device and Calibration Topics 2
S Reliability Software Recommendations Reliability Analysis - Predictions, Testing and Standards 4
D Cpk relation to Reliability Capability, Accuracy and Stability - Processes, Machines, etc. 4
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
M Defining Reliability and Confidence Levels Reliability Analysis - Predictions, Testing and Standards 8
R Standard for Reliability/Performance Test on a Electro Mechanical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T "Time of Demonstration" requirement for Reliability Test Reliability Analysis - Predictions, Testing and Standards 1
T Reliability Lifetime Requirement Demonstration Test Reliability Analysis - Predictions, Testing and Standards 3
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
A Repairable System Reliability Analysis: Uptime/Downtime Hours, Failure Modes Data Reliability Analysis - Predictions, Testing and Standards 2
D Reliability of an Attribute Inspection based on Historical Data Capability, Accuracy and Stability - Processes, Machines, etc. 8
S Reliability Calculation - MTBF/MTTF for Static Mounts of Rail Industry Reliability Analysis - Predictions, Testing and Standards 2
R Minitab - Reliability / Survival Distribution Analysis Using Minitab Software 1
C CRE (Certified Reliability Engineer) Exam 03/02/2013 Professional Certifications and Degrees 11
D Demonstration Reliability Test Formula with allowance for 'x' Failures Reliability Analysis - Predictions, Testing and Standards 6
R Military Land Vehicle Reliability with Only 1 vehicle & Only 1 Endurance Test Reliability Analysis - Predictions, Testing and Standards 5
J Relationship between Quality, Reliability, Price and Delivery Misc. Quality Assurance and Business Systems Related Topics 7
L Determining Cpk based on a given Sample Size, Confidence Level, & Reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Reliability Centered Maintenance - Nowlan & Heap's AD-A066579 (1978) Reliability Analysis - Predictions, Testing and Standards 1
E Question on the Reliability of the Faroarm vs. Romer Arm Calibration and Metrology Software and Hardware 10
M ERTMS/ETCS RAM (Reliability, Availability & Maintainability) Requirements Specs. Various Other Specifications, Standards, and related Requirements 2
D Reliability Growth methodology (Duane, CrowAMSAA) - Test Planning Reliability Analysis - Predictions, Testing and Standards 5
F Reliability of a System - Estimation of R(t) having constant failure rate "Lambda" Reliability Analysis - Predictions, Testing and Standards 2
B Problem with Reliability and Availability Formula Reliability Analysis - Predictions, Testing and Standards 8
C Purpose of using different Distributions to solve Reliability Problems? Reliability Analysis - Predictions, Testing and Standards 2
C Reliability Calculation without Failure (Success Run) Reliability Analysis - Predictions, Testing and Standards 10
H What's the meaning of "a minimum 95% reliability target"? General Measurement Device and Calibration Topics 14
S Reliability Conference Suggestions Reliability Analysis - Predictions, Testing and Standards 5
