Relying on Supplier Records for Material Traceability - Bar stock and forgings
dtr18c
I work for a company that does cnc machining on bar stock and forgings.
We are working towards ISO 9001:2008 registration and while discussing Identification and traceability management wants to rely on our suppliers to retrieve material certifications from. They think we should be able to contact our supplier with the PO# tied to the job number in our software and meet traceability requirements. (They don't want to have our own storage/retrieval system if possible) I think that our customer requirements should be considered and this is an excerpt from one of our customer's audit:
Is required product identification (including material certification and heat number, if applicable) maintained through all stages of production, assembly, and delivery?
Any thoughts about this?
Thanks.
SteelMaiden
Re: Relying on supplier records for material traceability
The standard says:
Where appropriate, the organization shall identify the product by suitable means....
Where traceability is a requirment, the organization shall control the unique....
So, first you need to identify the requirements of your industry and your customers so that you can make an informed decision on how to handle traceability at your facility.
Big Jim
I really don't see how you can get out of keeping at least some traceability records. How can you expect a supplier to trace things once it hits your inventory? How will they know which work orders the material applies to? How will they know which customers the material will end up with?
You should be able to depend on your suppliers to maintain records to support their C of C and C of A, but that is about it.
Ted Schmitt
Welcome to the Cove !!!!
After you have done what Steel said :
The standard says:
I would not rely soley on my supplier to maintain all traceability records... I find it way to risky.... what if he messes it all up? what if he goes broke ?
dtr18c
Jim-
Just to clarify were not looking for our suppliers to be able to trace material (throughtout our shop/after it leaves our shop) after delivery that would be impossible. Our software provides event based records for that aspect as well as what work order and customer the material belongs to.
SteelMaiden-
Material certification and heat# need to be maintained throughout all stages of production.
What I am asking is if it would be considered acceptable per ISO 9001:2008 requirements for us to say that material certification etc are maintained by our suppliers and are retrievable by us by referencing the PO# (which is linked work order in our software)?
I believe my question concerns 4.2.4 Control of records:
We need to keep records to provide evidence of conformity to requirements (material requirements in this case). We get to establish the controls needed for storage/retention/retrieval/etc. With that said if we were to determine that our suppliers system is sutible for this would that be acceptable?
Ted-
I agree; during my discussion with management I brought up the failure modes of relying on our suppliers for these records like system failure/errors/etc. The response I got was "What if armageddon strikes?"
I personally think that we should maintain these records but am having a hard time selling this to management. Any advice?
Thanks for your help.
Ted Schmitt
What volume are we talking about here ?
How may bars / lots with the same traceabilities are you receiving per month ?
We also machine bar stock (brass, stainless etc)... we identify them with our traceability # (stamped at the end) and paint the end with corresponding color to identify the type of bar (304, 316, 410, 420 etc).
Then I have simple spreadsheet containing :
receiving date
Supplier invoice # and date
Supplier heat #
Supplier test cert #
The test cert I scan and maintain it as a PDF in the suppliers folder on the network.
I don´t see a "major cost" with this... and the benefits are greater..even if Armaggedon´s strikes...
SteelMaiden
:lmao:Having worked on the end of the spectrum where people think that since they got the certification from us to start with, so therefore, they can just call up at will and get another cert whenever you want....
Yes, you could do that, but I will be the first to say that the more often you call to get another copy of the cert, the less goodwill you will get from an already busy cert clerk.
Your requests will potentially be put in the c-list in the Franklin Planner, and your company will become the joke of the test report area. Readily available? What happens 1500 certifications later when the mill test clerk says "eh, he can wait, he does this on every order, so he can just cool his heels until tomorrow" when you have an auditor in your face today, or worse, your customer?:mg:
dtr18c
Maximum of 20 lots/500 bars per month.
Another question regarding product identification:
We use a bar coding system to track production. The operator enters the quantity good and quantity bad. I've seen a previous thread, elsmar.com/Forums/showthread.php?t=36302, where it mentions using a bar coding system to identify status of product.
What are your thoughts about using this type of system to identify product status?
If we do use this to identify product status then will all operators need access to the software or can they request status from a manager with access?
I know it wouldn't be too hard to add a simple "approved" or "rejected" stamp (or something similar) to identification tags but I just wanted to get your thoughts about using the bar coding method to identify status.
Thanks.
dtr18c
receiving date
Supplier heat #
One of our customers requires us to match parts to a time frame and lot of material. We have some parts where our customer provides the material (forgings) in bulk. We write the material lot# on our identification tags and these tags stay with material/parts through production and delivery.
Will the tags that ship with the material be sufficient?
(The bad thing about this is if the tag becomes missing or destroyed after shipping then the material traceability is broken)
Or should we be maintaining additional records associating material to job#'s?
Anybody care to share their practices for traceability?
John Martinez
If you are relying on your supplier in and of themselves, if they go out of business, you are .... (fill in the blank) with your customer.
As a third party or second party auditor, I would not accept this.
K Relying on mitigations implemented in non-medical device IEC 62304 - Medical Device Software Life Cycle Processes 5
L Relying on Suppliers - Most Quality and Warranty problems are caused by Suppliers Supply Chain Security Management Systems 5
B "Detection, NOT Prevention!" - Relying on Final Inspection Quality Manager and Management Related Issues 48
R Supplier/Vendor Surveys (360) Supplier Quality Assurance and other Supplier Issues 1
was named killer AS9100 Supplier Approval Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 10
B AS9100 8.4.1 Supplier Selection/Evaluation criteria and reevaluations AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
J Sub-supplier change from manual to automated process - same specs - Report to FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Supplier Audit Report - Template for second party audit wanted Lean in Manufacturing and Service Industries 1
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
Ed Panek Corona Virus impact on Supplier Audits and Received Parts ISO 13485:2016 - Medical Device Quality Management Systems 4
NDesouza Verification of Supplier RCCAs Nonconformance and Corrective Action 5
K Supply Agreement Regarding MDR 2017/745 - Manufacturer-supplier cooperation Other Medical Device Related Standards 0
L How to deal with an ISO 13485 Supplier Audit nonconformance ISO 13485:2016 - Medical Device Quality Management Systems 17
P Supplier Audits in the wake of COVID-19 ISO 14971 - Medical Device Risk Management 2
T Ideas for developing a Supplier Quality Management System, non automotive ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Vendor (Supplier) Evaluations and Reports Supplier Quality Assurance and other Supplier Issues 11
F Is there such a thing as 'Critical supplier' status under the Dept. of Health (UK)? Medical Device and FDA Regulations and Standards News 2
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G Supplier flowdown verification of tests and revisions Supplier Quality Assurance and other Supplier Issues 0
B Supplier of design and manufacture process ISO 13485:2016 - Medical Device Quality Management Systems 10
S Software for Supplier Charge back and internal PPM General Information Resources 2
R IATF/IAOB Red Supplier Pilot Program IATF 16949 - Automotive Quality Systems Standard 1
M Changing supplier of critical raw material (III class device) Other Medical Device and Orthopedic Related Topics 1
S VW Supplier Product Safety Representative (PSB) upgrade to PSCR VDA Standards - Germany's Automotive Standards 0
S Process Map for Supplier Process Maps, Process Mapping and Turtle Diagrams 5
D Licensee as a Supplier on the ASL Medical Device and FDA Regulations and Standards News 10
R Definition Key Supplier - Definition of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
M Risk Classification For Supplier - Clinical Research Organisation (CRO) Supply Chain Security Management Systems 3
shimonv Rigid rules for handling supplier audit findings ISO 13485:2016 - Medical Device Quality Management Systems 11
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
R AS9100 DELTA FAI - Sub-supplier for plating changed AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
P IATF 16949 8.4.2.4 Supplier Monitoring IATF 16949 - Automotive Quality Systems Standard 2
A Supplier Quality Standard vs Senior Management Direction Supplier Quality Assurance and other Supplier Issues 2
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
R Supplier evaluation and business needs in the context of ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 2
J IATF 16949 8.4.1.2 Supplier selection process IATF 16949 - Automotive Quality Systems Standard 4
Q Supplier audit question cataloque VDA Standards - Germany's Automotive Standards 0
Ed Panek Inactive key supplier question - We are not actively buying from them ISO 13485:2016 - Medical Device Quality Management Systems 2
Ajit Basrur Quality Agreement with supplier covering medical devices and consumer requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
K Supplier re-evaluation (API Q1) Manufacturing and Related Processes 8
C Approving AWS as a supplier (ISO 13485) ISO 13485:2016 - Medical Device Quality Management Systems 1
R Supplier related drawings and verification of process requirements - Source Inspection AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
Q AS9120 Vendor of ESD Monitoring Equipment needs to be in the Approved Supplier List? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
R Supplier Controls we can place on Single-Source Suppliers ISO 13485:2016 - Medical Device Quality Management Systems 2
N Declaration of Conformity for Product from Supplier ISO 13485:2016 - Medical Device Quality Management Systems 6
M Supplier selection criteria - Medical devices ISO 13485:2016 - Medical Device Quality Management Systems 3
Ed Panek Can a single supplier fit two or more categories for risk? ISO 13485:2016 - Medical Device Quality Management Systems 2
V Determining FDA 820 (registration) vs ISO 13485 - Supplier gives us the kit ISO 13485:2016 - Medical Device Quality Management Systems 1
G ISO 22442 Supplier Audit Checklist - Medical devices utilizing animal tissues General Auditing Discussions 0
