Removing the liner from disposable nicotine patch without using hand
apogee
I am planning a device which requires automatic removal of the liner from the nicotine patch without using hand or minimal usage of hand or using a autommatic device.
If you have come across anything similar or a solution to this problem, do let me know. Any help would be highly appreciated.
Warm Regards
Ashwin
Re: simple idea for removing the liner from the nicotine patch without using hand
I quit two weeks ago, using Chantix. So once you do get the patch off, switch to this pill. It works great. I tried the patch before and had no success.
If I remember correctly, It burned my arm somewhat. I dont' recall anything about what you're asking, sorry!
CarolX
I am still using the patch - I quit about 6 weeks ago - and removing the patch from the liner is no different than pulling a band-aid out of it's wrapper.
Good Luck!
ralphsulser
I quit 2 years ago yesterday. Doctor gave me a perscription for Welbutrin,
seem to help. Of course it helped that I was diagnosed with pneumonia at the time. That helps make a serious decision real soon. I have not been sick a day since. Used to get bronchitis every spring.
I had previously used patches, and nicotine gum.
Re: Removing the liner from disposable patch without using hand
Raplh,
How did that work with the withdrawal symptoms? This stuff has been great,
for me anyway. Also tried Zyban, it had some serious affects (pain) on my kidneys, had to quit it within a week.
So far no real drastic side effects from the Chantix.
You must have had a better brand than mine. There were no overlaps on the patch like on a band-aid on the patches I used. So there's idea one: add some area that is not stuck to the patch.
Here's another one for free: how about a nicotine free adhesive area on the edge that would allow you to stick the edge and then pull the backing off as you apply the patch to your skin? Similar to pulling one side off a band-aid, sticking it, and then pulling the other side off as you go (OK, so I've shamelessly ripped off the band-aid).
BTW, I have smoked for 21 of the 27 years since I turned 16. I quit cold turkey for 3 years in college (I had other things to spend money on). I quit cold again for 2 years in my early 30's. I used the patch to quit for a year in my late 30's and then again for 6 months a couple of years ago. Nicotine replacement stopped the physical symptoms but I've really become attached to the "take-a-break" ritual now that you can only smoke outside, 100 metres from the entrance, with nobody looking, and no snail darters or snowy egrets within sniffin' distance.
ralphsulser
Raplh,
The Welbutrin helped minimize and even out the withdrawel symptoms.
I didn't start on it right away, and got pretty cranky and short tempered.
It helped keeping me from a divorce too ;-)
CarolX
Ice - not really - I use the Walgreens brand. It is a round patch with about 1/4" area that is not "patch" just the skin glue.
FWIW - the "take-a-break" ritual - at 1 pack a day is about 1.7 hours wasted - standing around doing nothing but putting that darned poison into our lungs. :lmao: :lmao: :lmao: (part of my motivation!!)
Wes Bucey
As a former smoker, I wish you all luck and the patience to make the luck work.
It can be done. I quit a four pack a day habit cold turkey in 1980. Anybody says it's easy is lying to us or him/herself.
Jen Kirley
Quality and Auditing Expert
I used to smoke too. Quitting wasn't easy, but my mom would give me such a hard time (even by just imagining getting pounded by the waves of her disapproval) that I would quit before going to visit her for a couple of weeks. Thanks Mom!:lol:
Skooma Deburring and Tolerances - Is there a Standard for deburring or removing material? Manufacturing and Related Processes 3
V Removing final inspector for medical device manufacturing Lean in Manufacturing and Service Industries 4
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
D How to receive EASA approval for removing of engine QEC Kit EASA and JAA Aviation Standards and Requirements 1
Q Removing Inspection (Functional Tests) from a Process Step Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
P Removing Detection from DFMEA - Medical Device company using ISO 13485 FMEA and Control Plans 3
A Gage Block Repair - What type of stone is acceptable for removing burrs General Measurement Device and Calibration Topics 5
H Removing fixed effects (time demeaned variables) in Minitab Using Minitab Software 12
A Removing the effect of special causes on Xbar-R chart - Centerless grinding process Statistical Analysis Tools, Techniques and SPC 6
T Control of Forms - Considering removing forms from our procedures Document Control Systems, Procedures, Forms and Templates 7
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
T No Defined Shelf Life/Expiration Date - Disposable single-use, non-invasive, non-sterile Other Medical Device Regulations World-Wide 2
T 5ºC Storage Temperature Validation - Urology disposable devices EU Medical Device Regulations 3
T Must all Disposable Medical Devices be DEHP Free for MDR? EU Medical Device Regulations 1
S Scope change in Japan - Class I disposable medical devices Japan Medical Device Regulations 0
Y Shelf Life of Non-Sterile Disposable Drug Inhaler 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
P Single Use Disposable Dental Syringe - CE Marking Advice EU Medical Device Regulations 4
S IEC 60601-1 - Label Physical Requirements for Disposable (Single Use) Medical Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
N Reliability Testing of a Single-Use (Disposable) Medical Device Reliability Analysis - Predictions, Testing and Standards 4
B PPAP for Disposable Tooling APQP and PPAP 2
S Food Safe Ink for reusable and disposable gloves US Food and Drug Administration (FDA) 2
A Calibration of Disposable Weight Scales General Measurement Device and Calibration Topics 2
M Are disposable electrodes in the scope of WEEE Directive? Other ISO and International Standards and European Regulations 2
S Resterilization - Disposable devices Imported Legacy Blogs 0
S Resterilization of Disposable Medical Devices by a Distributor Other Medical Device and Orthopedic Related Topics 5
D Class II Disposable Medical Device Label Content Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
N Accelerated Aging Test for Disposable Protective Garment for Incontinence Other US Medical Device Regulations 1
T Do Disposable Electrodes need CT-Compatible Testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Disposable Loop Electrode - GMDN/or UMDNS code? Imported Legacy Blogs 3
M RoHS for Disposable Medical Device Assemblies RoHS, REACH, ELV, IMDS and Restricted Substances 1
L Predicate Device for 510(k) - Disposable vs Reusable 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Disposable Medical Device Sampling Plans per ISO 2859-1 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
F HACCP Certification for Single Use Disposable Food Contact Grade Gloves Food Safety - ISO 22000, HACCP (21 CFR 120) 1
B Blood Bag Classification - with Disposable Centrifugal Unit for processing blood EU Medical Device Regulations 4
C ISO17020 Required to ship disposable "coveralls/overgarments" into Egypt General Measurement Device and Calibration Topics 6
S Surgical Instrument Luminaries Standards - Single Use Disposable Surgical Instrument IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Ajit Basrur Manufacturing of sterile single use disposable devices in a single plant? ISO 13485:2016 - Medical Device Quality Management Systems 4
D Battery Powered Disposable Pump - What IEC 60601 testing is required, if any? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A Batch Processing Record for Medical Devices - Disposable Plastic Syringes Other Medical Device Regulations World-Wide 1
somashekar Waste Categorization - Medical Device (Disposable Sensor) Miscellaneous Environmental Standards and EMS Related Discussions 4
N RFID on a Medical Disposable Kit - Active Medical Device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
M Classification of a disposable Screen Pointer for use by surgeons on monitors? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
W Distributor Requirements for Sterile Disposable Medical Devices EU Medical Device Regulations 8
M Cleanroom Gowning Disposable Lab Coats - Class 8 Cleanroom ISO 13485:2016 - Medical Device Quality Management Systems 4
Jim Wynne We have entered the age of disposable laser printers After Work and Weekend Discussion Topics 23
