Renaming CARs so that they do not seem negative
mguilbert
Good Afternoon All,
A little history we call CARs and PARs, CPARs. When we started our journey in ISO about ten years ago, CPARs were seen as a very negative thing. This mentality still exists within our organization. it has been very difficult to have facilities/departments issue CPARs against themselves. Recently it has been suggested to rename them. I am weary of this because most will see through this. We have tried to educate them on the purpose of CPARs and how they are used to improve our processes.
Question: Do you have any suggestion for other names for CARs and PARs that may not be seen as a negative but a positive?
Thanks,
P
PaulJSmith
Re: Renaming CARs
[sarcasm]Unicorns and Rainbows, perhaps?[/sarcasm]
Seriously, though, I think you have the right mentality. Re-educating your coworkers to the positive benefits of these processes will be much more effective in the long run than just a name change.
L
lfrost
Re: Renaming CARs
I would use "Improvement Opportunities" for your CARs. At my company we use "Action Request" as our CAPA system reports. It has helped in getting more activity with more "buy in" within the different departments.
Just a couple of ideas you might use.
We have been calling them Improvement Actions for as long as I can remember. As others have said this deludes nobody, but it does have one benefit: When I am auditing I can say that I am looking for good practices rather than faults (which as it happens is absolutely true). :cool:
/Claes
An interesting question and one I'm dealing with in my latest book on internal audits. It is correct, IMHO, to need to rename "Corrective Action Requests" to something more appropriate. The term comes from an external auditor's perspective and isn't always appropriate. I'd prefer they were called something like "Risk/Impact Report" or similar.
I'm not sure why a Preventive Action Request is a problem, except that preventive actions are part of a planning process, and not a "one time" request where a form needs completing - another corruption of the process! For example, performing an FMEA should be part of a process, not because someone filled out a PAR to suggest it is done!
The love of euphemisms is a hallmark of incompetent management. The belief that the essence of a thing will change when you change what it's called is almost always misguided. My guess is that the problem isn't what you call the CA process; it's that the process itself has a stigma that results from people being treating in a negative way when things go wrong.
Changing the name of something is fine if the reason for the name change is addressed, but otherwise it will most likely be futile.
Jen Kirley
Quality and Auditing Expert
I agree with Jim as I so often do, but let's consider what this means outside the sphere of internal operations.
Over the past 15 months I've had several clients who grappled with the difference between corrective action and preventive action. I found they had been doing many preventive actions but not giving themselves credit for them - their QMS/EMS/OHSAS did not recognize the good things (projects to save electricity, 5S to boost efficiency, facilities improvements to reduce emissions or leaks, etc.). Part of the reason why is how they defined the difference between corrective and preventive in their procedures, which are required for both subjects.
In both cases the group involved sets about changing something that does not perform as desired. The difference comes in how the thing to be changed is identified. Internal audits? External audits? Core team or management review of performance data? Management-by-walking-around?
I don't know how the OP's organization handles preventive actions now, but I suspect not everyone uniformly understands preventive vs corrective. A set of criteria should be defined and promulgated. I suggest that if no regulations have been broken or breached, no injuries sustained, no bad product reached customer, no internal audit or 3rd party audit or customer audit found the thing, it could be called a preventive action.
:2cents:
A QMS Overhaul - Reorganizing and Renaming Documents - Internal References Document Control Systems, Procedures, Forms and Templates 18
R Plan to Volvo Cars for capacity verification in Phase 3 of PPAP Customer and Company Specific Requirements 3
E Different types of Actions? CARs, OFIs or N/A ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Does ISO 9001 require CARs for all customer complaints? Customer Complaints 2
T Is it necessary to Audit our CARs and SCARs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D SDS (MSDS) for complex products such as a TV, computer, cars, etc Miscellaneous Environmental Standards and EMS Related Discussions 3
O Nonconformance for vague CARs and PARs Nonconformance and Corrective Action 5
Q ISO 9001/14001 QEMS multiple CARs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Linking CARS (Corrective Action System) with the rest of our system Nonconformance and Corrective Action 4
L How to deal with too many CARs (Corrective Action Requests), PARs (Preventive Action) Nonconformance and Corrective Action 25
N Combining Multiple CARs (Corrective Action Request) into One CAR? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
A Closing CARs (Corrective Action Requests) due to Process Change ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B How can I control CARs (Corrective Action Requests)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Stijloor Vilnius Mayor A.Zuokas Fights Illegally Parked Cars with Tank Coffee Break and Water Cooler Discussions 15
J Requirement of on-site follow up for Major CARs AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 11
A BMW recalls 350,000 cars World News 9
C Closure of CARs (Corrective Action Requests) and Audit Observations Internal Auditing 25
Marc China to build buses that cars can drive under World News 20
A Open CARs (Corrective Action Requests) and 8D Processes Nonconformance and Corrective Action 27
P Commute and Cars Opinion Coffee Break and Water Cooler Discussions 17
Q CAR?s Responsibilities? How the responsibility will be shared in CARs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
bobdoering As hybrid cars gobble rare metals, shortage looms World News 35
W GM to Import More Cars, UAW Angry World News 0
V AS9100B Time Limit? Time between your audit and when your CARs must be accepted AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
A Toyota to Recall More Than 1.35 Million Cars World News 0
Stijloor Deadly tension on the roads - Cars vs. Bikes Coffee Break and Water Cooler Discussions 35
E General Analysis of CARs (Corrective Action Report) Nonconformance and Corrective Action 5
Marc The 50 Worst Cars Coffee Break and Water Cooler Discussions 11
N Corrective Actions and ECOs - If an ECO addresses the issue, why do we do CARs ? Nonconformance and Corrective Action 16
U Material specification for brake discs for passenger cars, LCVs & HCVs Manufacturing and Related Processes 3
C Polluting cars face charge rise - London World News 11
Marc US domestic cars make gains in reliability World News 3
J The energy of the future for future cars .pdf file World News 3
P Indian Auto major Tata motors planning to launch 2200USD cars World News 3
T Why cars cost so much Misc. Quality Assurance and Business Systems Related Topics 20
V CAR NCMR Software - SQL based, just for NCMR's and CARs Quality Tools, Improvement and Analysis 2
B How can I ask a customer not to issue CARs for trivial issues? Nonconformance and Corrective Action 17
S TS 16949 Clause 8.5.2 Audit Nonconformance for not issuing internal CARs IATF 16949 - Automotive Quality Systems Standard 14
Marc Predictive Maintenance? GM pitches "smart" cars to cut back on discounts World News 2
M CARs (correction action request) vs. NCMRs (nonconforming material report) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Marc Experimental Hybrid Cars Get Up to 250 Mpg World News 17
Marc Electric cars as fast as a Ferrari World News 1
Marc Bill Gates Envisions Cars that Can't Crash World News 5
A AS9100 - FAA - Corporate - Authority to access company CARs and PARs? Federal Aviation Administration (FAA) Standards and Requirements 9
C Hybrid Cars - 100 year old idea World News 2
C Hybrid vehicles (cars) are getting Down Under Coffee Break and Water Cooler Discussions 27
R Stupid Responses to CARs - Long Term Corrections or Root Causes Problem Solving, Root Cause Fault and Failure Analysis 47
A Microsoft Controlled Cars Customer and Company Specific Requirements 7
B Judge Orders Ford To Recall Cars World News 1
D Hazard analysis for our medical device - Hazards seem to overlap 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
