Repeat Major NC - What can happen during External Audit by Registrar
adaline
Our company is Certifiied to ISO 9001. Last external audit our registrar issued a major non-compliance to us. We fixed the issue and are now ready for another audit. We recently discovered we have the SAME issue and expect to get issued another major non-compliance. What happens when a company gets a double major? (or - is issued a major two times)?:thanks:
BradM
Re: Repeat Major Nonconformance - External Audit by Registrar
Hello there! Welcome to the Cove!
OK, please don't take this wrong, but... If you had fixed the problem the first time, how could you have the same issue? Are you sure you fixed it the first time, or is it a slightly different problem?
I'll be interested to hear from our road-warrior auditors. But.. I can't imagine that it would be good. Primarily, I would think an auditor would be keenly concerned why the root cause was not determined last time and the process improved. How is management responding to this?
Do you care to share a bit about the major NC? You can change whatever you wish to keep anonymity, or you can leave it vague if you choose. But some information surrounding your situation may be helpful.
Stijloor
Hello adaline,
Not good news.....A few questions:
  • How did Top Management respond to the first major NC?
  • Was the effectiveness of corrective action verified?
  • What have the internal auditors done between Major 1 and Major 2?
  • Have you had Management Reviews?
  • Was clause 5.6.3 considered?
I don't want to be negative, but it looks that your QMS is in serious disrepair and the CB may take action to decertify you. I hope for the best though....
Wishing you lots of strength.
Stijloor.
Sidney Vianna
Post Responsibly
There is no cookie cutter answer here. If the CB is serious, they will look very seriously about your root cause evaluation process that allowed a major problem to recur. But it will depend on the specifics of the case, the seriousness of the auditor and the management of your organization.
As usual, I recommend an open dialogue with the auditor from your CB. If the problem is really significant, both you and the auditor should be interested in putting it to rest. But there are many variables at play. Even the categorization of the finding is dependent on the qualifications of the auditor, responsible for reporting it. Without details, it is very hard to provide more advice.
Randy
NC against the Corrective Action process.....the evidence exists that it doesn't work...by your own admission.
How do you fix it? Can't tell ya because I'd be crossing the line into consulting.
All I can say is read the requirement for Corrective Actions and actually do it.
As to the "double-major".....possible suspension or revocation of your certificate, which is pretty standard for the the industry. And don't believe it won't happen, it does and there are fiscal horror stories that come out of that scenario.
atitheya
You probably carried out a "correction" after the earlier external audit. Root cause was not analysed and removed which resulted in repetition of the issue. Now that it has happened again, ACT NOW.
Analyse Root Cause, take corrective action by removing / repairing the cause, verify effectiveness of such corrective action essentially that it shall not happen again .
This is the least you need to do and DO THIS BEFORE YOUR DUE EXTERNAL AUDIT. Have a dialogue with your CB and ask for some time but only if you have to.
gpainter
I think that it depends on the issue, the registrar and the maturity of the QMS. The old one will be re-opened and if not fixed then suspension
DsqrdDGD909
Off topic - can one act as a consultant to one company but as an auditor to a different company, or is the rule you are either an auditor or a consultant?
Helmut Jilling
Auditor / Consultant
You can do both, but not for the same client. I think it is actually better, because it gives one broader experience and depth. Same registrars may prohibit it, but that would be an internal rule.
C Fact or fiction - Repeat minor becomes a major IATF non-conformance IATF 16949 - Automotive Quality Systems Standard 7
A Where are the rules for when a repeat minor nonconformance becomes a major? IATF 16949 - Automotive Quality Systems Standard 36
K Definition of Repeat Audit Findings Internal Auditing 11
B EMC Repeat Justification - Reducing NRTL testing required after modification of ME IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
P Do CQE exam questions repeat in next exams? Professional Certifications and Degrees 1
T Need to repeat IEC 60601-1-2 test agains ed3.0 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M How to document Risk Assessment on Repeat Business AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M ISO 10993 - Repeat tests necessary if colour changes slightly? Other Medical Device Related Standards 11
G AS9100 clause for Repeat Orders AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Repeat Medical Site Qualification Visits - Time between Visits US Food and Drug Administration (FDA) 2
J Repeat Visits By Same External Auditor for the Last 10 Years General Auditing Discussions 22
P How often do you have to repeat a Gage R&R study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
B Consequences for repeat nonconformances - Carelessness, lack of focus Nonconformance and Corrective Action 9
J Calculating Repeat Business for the purpose of quantifying a Quality Objective ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Define timeline for Major and Miner Audit finding General Auditing Discussions 4
Scanton Double Major for the same infraction? IATF 16949 - Automotive Quality Systems Standard 11
M Major vs. Minor for Internal Audits? Internal Auditing 10
W Major NCRs within AS9100 - What is the most frequent reason for Major NCRs? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Stefan Mundt AS9100D Major nonconformity due to recurrence of a NC during a subsequent CB audit. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
N Validation procedure, Major NC CAP - Equipment Validation process is not effective ISO 13485:2016 - Medical Device Quality Management Systems 5
I Is this a Major AS9100 QMS change - Quality Concerns AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K FAA Audit - Major nonconformity for lack of timely calibration of two devices EASA and JAA Aviation Standards and Requirements 5
Sidney Vianna Interesting Discussion Legal compliance as part of ISO 45001 accredited certification. Major OSHA penalties in the USA. Occupational Health & Safety Management Standards 15
Sidney Vianna Interesting Discussion How major corporations in the West keep failing to uphold their pledges of abolishing child labor in their cocoa supply chains Sustainability, Green Initiatives and Ecology 3
R Major nonformance finding was given during a closing meeting of a ISO9001 certification audit General Auditing Discussions 76
Y Informational Change control process - Major vs Minor change - Active class III medical devices ISO 13485:2016 - Medical Device Quality Management Systems 12
P Major Finding Elevation - Do I elevate this minor finding to a major one? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
J IATF 16949 registration - Major Nonconformance Finding IATF 16949 - Automotive Quality Systems Standard 9
Sidney Vianna Top 10 Major and minor NC's during IATF 16949:2016 Audits IATF 16949 - Automotive Quality Systems Standard 8
G AIAG FMEA - Major customers of the FMEA process FMEA and Control Plans 3
M New Medical Device Accessory with New Function - Is this a major change? Other Medical Device Regulations World-Wide 3
C IATF 16949 : 2016 - How put in place a Containment for this kind of Major NC IATF 16949 - Automotive Quality Systems Standard 14
A ISO 14001:2015 transition audit - Major NC due to the procedure and audit plan ISO 14001:2015 Specific Discussions 10
C How does a major NC for a support site affect our certificate? IATF 16949 - Automotive Quality Systems Standard 2
AlienraverX How to appeal a major audit finding ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
W IATF 16949 Clause 6.1.1 - My first Major NCR (Management Review) IATF 16949 - Automotive Quality Systems Standard 57
K Outsourced Major Processes - Working for Two Sister Companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T Non-addressed Minor Finding elevated to Major Finding Internal Auditing 37
B IATF 16949: Definition Major/Minor Non-conformity IATF 16949 - Automotive Quality Systems Standard 6
M Increase in Major TS16949 Audit Findings IATF 16949 - Automotive Quality Systems Standard 14
S Could I issue major finding for Inadequate Procedures Supplier Quality Assurance and other Supplier Issues 17
T Defining Major vs. Minor Changes to Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Is Failure to achieve a Goal a Major Non-Conformance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
C Notification to Customers regarding Major Audit Finding IATF 16949 - Automotive Quality Systems Standard 25
