Repeatability for an Electrical Screwdriver Torque
E
Ed-Bal
Hello to everybody:
Recently I was asked by the repetibility of a electrical screwdriver. I made a capability study (I calculate the Cm index), but I really don't know if it's valid or not.
Additional Information:
I work on a company where car door latches are produced. We use a small screw to fix a frameplate. On the drawing, the spec for the screw is: 0.70 +/- 25% Nm (0.525 - 0.875 Nm).
My problem started when I tried to obtain the repetibility of the screwdriver. With the use of a torque analyzer I got 30 readings taken directly from the screwdriver (I call to this dinamic torque), getting values similar to these: 0.95, 0.83, 0.92.
If I measured the torque applied directly on the screw latch (I call to this residual torque), I got values similar to these: 0.65, 0.70, 0.60.
As you see, the specification match perfectly for the torque found on the product, but not for the torque applied directly by the screwdriver.
So, I don't know if it's valid to calculate the average of the readings taken directly from the screwdriver and apply the % tolerance defined for the latch product (not for the screwdriver)? Once having the tolerance I could easily calculate a capability index.
As a second question, I don't know if 1.33 is the minimum value acceptable for Cm capability index or could be less?
I would appreciate all your point of views to clarify my doubts
Thanks & Regards
Eduardo
BradM
Re: Repetibility for an electrical screwdriver
Hello Eduardo!
My problem started when I tried to obtain the repeatability of the screwdriver. With the use of a torque analyzer I got 30 readings taken directly from the screwdriver (I call to this dynamic torque), getting values similar to these: 0.95, 0.83, 0.92.
You stated you took 30 readings, but you only list three above? Were the other readings identical to the above three readings?
Were you testing counter clockwise-torque or clockwise torque with the torque analyzer?
Now, these are some really basic questions, but did you assure to minimize distance, any wobbling and the like between your screwdriver and the torque analyzer? There are several factors that can contribute some pretty significant error.
How did you measure this? Did you estimate the counter torque it took to remove the screws in the latch? Did you apply the identical torque clockwise, then measure removal torque?
How many readings did you take with this application?
Sorry for the questions, but I was a little interested in your setup here, and from experience, torque can get tricky.
I know your question was specific about gauge R&R, and some of the other experts can help you with that. However, you might be interested in some of the other threads on torque. Here is one:
Verifying Applied Torque
Where one of the Covers talked about developing a relationship between applied and removal torque. Also, you can enter torque in the search, and there are several really good threads on torque, if you are interested.
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
R Clinical accuracy and repeatability of IR(infrared) thermometer, no maximum error criteria is recommended in ISO Other Medical Device Related Standards 11
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
G Is it common to do a repeatability check during calibration of an instrument? General Measurement Device and Calibration Topics 5
S "X-MR charts do not separate piece-to-piece repeatability of the process" Statistical Analysis Tools, Techniques and SPC 2
S GRR (Gage Repeatability and Reproducibility) for Material Strength Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Repeatability issue in Gage R&R study for inner diameter of a bushing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
B How to Demonstrate Stability and Repeatability in very Short Run Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R Repeatability in MSA - Is repeatability a measure of Location Error Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T Method Repeatability for MU (Measurement Uncertainty) Measurement Uncertainty (MU) 1
K Wilson Hardness Tester Model 525 Accuracy/Repeatability issues help General Measurement Device and Calibration Topics 4
B Repeatability vs. Instrument Specifications Measurement Uncertainty (MU) 6
J Repeatability Standard Deviation Formula in MSA 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Jerry Eldred New ILAC Requirements Regarding Repeatability - Your thoughts on this please Measurement Uncertainty (MU) 11
T Value of K1, K2, K3 in GR&R - I want to measure Repeatability and Reproducibility Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
C How to use GR&R for Machine Repeatability Study when there are no specs? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Weld Cell Repeatability Studies - Origin - The 'drilled hole panel' Methodology Manufacturing and Related Processes 3
M Minitab Type 1 Repeatability & GRR% of Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T Gage Repeatability for an Automated Leak Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S Weight Scale Gage R&R (Gage Repeatability and Reproducibility) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
U Gauge repeatability and reproducibility (Gage R&R) worksheets Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
M Determining Repeatability without Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 22
D Gage R&R Repeatability - How do I know my gauge is in specification Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
A Gage Reproducibility & Repeatability for POKA-YOKE (pass/fail) gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Gage R&R (Reproducibility and Repeatability) using Minitab 14 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
U Gage R&R (Reproducibility and Repeatability) Understanding for the Layperson Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
F How would you Verify Repeatability and Reproducibility of Measurement Systems? Quality Tools, Improvement and Analysis 5
S Operator Capability - Gage R&R Poor Repeatability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J Measuring Tape Repeatability and Accuracy - Types of tapes - ECIII, ECII and ECI Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Gage repeatability and reproducibility - GRP% Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
R How to Determine CMM Gage R&R - Accuracy, Repeatability, Reproducibility? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Y Product Stability (Machine Capability) vs. Equipment Repeatability (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
N Repeatability Variation and Constant d2* - What is d2* and how is it calculated? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Gage R&R - Repeatability and Reproducibility of a newly bought CMM machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
D Gage R&R (Repeatability and Reproducibility) for Dummies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 67
P Gage Repeatability (1x1x10) form - 1 part measured 10 times by 1 appraiser Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
P Gage R&R (Repeatability and Reproducability): What are the calculation restrictions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
D Determining Gauge R&R (Repeatability and Reproducibility) Interval Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Automated Testing Gage R&R (Repeatability and Reproducibility) Issues Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Courier Gage R&R (Reproducibility and Repeatability) - Automotive Requirements Basics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Gage R&R (Repeatability and Reproducibility) Study with one appraiser Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Gage R&R (Repeatability and Reproducibility) Destructive Test Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
K Repeatability after CMM repair work Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J What is an acceptable Gage R&R (Repeatability and Reproducability) system? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
L Bias, Stability and Repeatability - What is an acceptable percent % ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Marc Gage R&R (Repeatability and Reproducability) - Tolerance vs. Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
R Gauge Repeatability and Reproducibility (Gage R&R) on all shop floor gages? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
A Canadian Safety Labels for medical electrical equipment Canada Medical Device Regulations 0
D Electrical Medical Devices class I EU Medical Device Regulations 0
