Repeatable method to measure a taper on a part
Tim Mosher
Hello, this is my first time in this forum, so please forgive any blunders I may make.
I am seeking advice on a repeatable method to measure a taper on a part. It is a 3 degree taper, and I must hold a .1043 to .1053 range when outside diameters are measured, over a 1.000 inch range. The diameter at the large end of the taper is .6880, in case this helps.
Optical comparators just are not cutting it, and neither is a sine bar technique, using a tenth dial indicator. I am by nature an ndt specialist, and dimensional is not my forte'. Any suggestions? I work for a very small company, so buying a cmm is out-lol
Thank you!--By the way-if anyone needs feedback on an ndt question, I would be glad to help
Thank you all for your replies. We came up with a different method of measuring this taper, and it seems to be working rather well. We manufactured an internal 3 degree taper to match the part being inspected.(Visualize it as a hollow cone)Then we wire-edm-ed slots the exact width of the blades of our digital blade mics, exactly 1 inch apart. We slide this cone over the part,then we simply take the diameters obtained with the mikes, and subtract the difference to get our tolerance reading. Our customer still thinks an optical comparator with auto edge detection is the correct method to measure this, but I have been reluctant to agree with him that his method is as repeatable, or as accurate, as ours, so, an R&R study is underway.(He refuses to perform one on his comparator for this part, but he IS the customer!)
[This message has been edited by Tim Mosher (edited 11 June 2000).]
[This message has been edited by Tim Mosher (edited 05 July 2000).]
Jerry Eldred
I'm not really a dimensional guru, so I will 'officially' pass on giving advice (don't want to give bad advice). My first thought was CMM. But you mentioned it was cost prohibitive.
I'll try to at least take a stab at a couple of thoughts (but PLEASE take these with a grain of salt).
My other thought was some sort of go-no-go fixture at uper and lower spec limits, and have a subcontractor measure a couple of standards with a CMM, and have that periodically calibrated.
I'm being deliberately vague because without seeing visually exactly what you are measuring, it is difficult to envision accurately your need. If there is something visual you could email me, I'd be happy to show it to some of our dimensional gurus and see what they think. email at: [email protected]
Tim Mosher
Thank you both for your replies.
I will seek to get permission to send a photo of the part to you Jerry. As this is a customer's part, and since it is a biomedical product,(they are a very proprietary lot-lol) I'm not sure I will have much luck.
Carl, I never thought about gage pins, but I will investigate this methodology further. Thank you.
[This message has been edited by Tim Mosher (edited 12 June 2000).]
Atul Khandekar
You could use something like a Tool Presetter instead of a CMM. Most tool presetters have an RS 232 compatible outputs. It is very easy to develop a small software program to acquire readings from the instrument.( Probe radius compensation etc etc handled through software) With these readings you can then do all kinds of statistical / graphical analysis.
The overall cost of this solution (presetter + computer + software) would work out MUCH CHEAPER that a CMM.
Hope this helps.
-Atul.
P
Paul Williams
You might try using thread wires. You would probably have to come up with a jig to hold the wire centerlines in a plane perpendicular to the centerline of the taper, and a micrometer type slide to index either the part or the wires along the centerline of the taper. You can then calculate the taper diameter based on the thread wire diameter and the geometry of the part. The jigs shouldn't cost more than three or four hundred dollars.
N Destructive/Non-Repeatable Measurement Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Manix MSA Study for Highly Repeatable Parts shows need for MS Improvement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Torque Wrench Calibration - Difficult time with repeatable measurements General Measurement Device and Calibration Topics 12
Q Sampling method for Distributor verification activities EU Medical Device Regulations 1
A Beginners help with ISO3951-2 Combined control s-method n>5 what is Phi ?? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S What is the best method to bond urethane foam to urethane foam? Manufacturing and Related Processes 4
R BS EN 12060:1998 - Zinc and zinc alloys Method of sampling Specifications Manufacturing and Related Processes 4
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
Pau Calvo How to motivate colleagues to use 8D method or similar Quality Manager and Management Related Issues 37
M Proper method to test flow of a regulator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Please share your method used for PEMS Validation IEC 62304 - Medical Device Software Life Cycle Processes 5
Y Post Market Surveillance Indicators and Analysis method EU Medical Device Regulations 1
silentmonkey Seeking efficient method to manage install base data Manufacturing and Related Processes 0
D 4M (Man, machine, method, materials) Management Manufacturing and Related Processes 3
Ron Rompen Measurement Method Challenge - Measure feature #91 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C FDA on changing acceptance criteria re: analytical method validation US Food and Drug Administration (FDA) 1
M Issuing NCR for improper method statement submissions Internal Auditing 10
F Irradiation Sterilization Validation Maximum Dose - VDmax 25 method (ISO 11137) EU Medical Device Regulations 2
I "Method" vs "Process" - Differences Document Control Systems, Procedures, Forms and Templates 33
P Test Method Validation for Tensile Strength Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
C ICP versus AA: How to determine appropriate specification for assay method verification Qualification and Validation (including 21 CFR Part 11) 1
I Flatness - Rectangular part using the three jack method Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
B AS9102 Supplier Flow Down Method AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
qualprod Qualitative or Quantitative? Risk method evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Ron Rompen Dual level holes - Measurement method suggestions wanted General Measurement Device and Calibration Topics 9
D Sampling method that is representative of the devices supplied by that distributor EU Medical Device Regulations 5
P Production Line Pump Cleaning Validation Method Question Qualification and Validation (including 21 CFR Part 11) 0
A Risks related to Method Validation and Stability Studies Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
qualprod ISO 9001 Risk control method - What could be the better way to control risks? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Ford Method - Position Capability with MMC Modifier Capability, Accuracy and Stability - Processes, Machines, etc. 14
J Inspection method for T10 Hex driver General Measurement Device and Calibration Topics 13
qualprod ISO 9001:2015 - Right method to address clause 6.1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Stakeholder analysis Method Six Sigma 1
T ER Checklist - Method(s) of conformity EU Medical Device Regulations 1
T ISO 17025 Method Verification - One sided “F” test or two sided “F” test ISO 17025 related Discussions 1
B Dosimeter Calibration Method General Measurement Device and Calibration Topics 5
A Test method for presence or absence of hexavalent chromium on a metal coating RoHS, REACH, ELV, IMDS and Restricted Substances 4
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
T Method to assess Measurement System of a Continuous Process Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G HPLC Method Equivalence between USP and EP Various Other Specifications, Standards, and related Requirements 1
S Test Method Validation or MSA for Batch Manufacturing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
