Reply requirements to satisfy 21 CFR 820.198(e)
I
ISO tired
The FDA is very vague on when it is necessary to respond to a complainant under clause 820.198(e). Approx. 90% of our complaints concerning adverse situations, after investigation are usually because of Doctor misuse i.e. over bending, wrong size. Our inserts are very thorough about the device usage.
The problem is when you do reply to a complainant with the findings, the physician does not like the results, which leads to customer satisfaction issues.
Any thoughts if it is truly a requirement to reply to a complainant concerning your findings? Especially if there is no explicit request for the results.
MIREGMGR
Re: Reply requirements to satisfy 820.198(e)
21CFR820.198(e)(8) does say that if you do respond, you must keep a record of the response. Other than that, there is no requirement in 21CFR820.198 to respond to the filer of a complaint.
However, it's notable that you have had enough complaints to be able to characterize ~90% of them as due to doctor misuse. The FDA, it seems to me, is very clear in the overall context of the QSR that device makers are obligated to take action in response to complaints about adverse events in such a manner as to cause fewer adverse events in the future, whatever the basis for the complaints. See for instance Chapter 15 "Complaints" of "Medical Device Quality Systems Manual: A Small Entity Guide", which capsulizes the FDA's guidance stance.
Based on the sparse description of the situation that you've given us, my inference would be that in some manner, your Instructions for Use--which you describe as very thorough--are nonetheless not effective.
It's conceivable that at some point an adverse event might be reported to the FDA as a complaint, and they might decide to inspect you and review your complaint records...and perhaps based on numbers of complaints, your analyses of each one, and whatever changes have or haven't been made to change the factors found in your analyses to have been responsible, it's conceivable that they might deem your device to be not effective. Effectiveness of course is a cardinal mandate for devices, so that would lead to bad things.
Thus I would suggest that, while you aren't legally required to respond to doctors who complain to you, you might want to make changes and then do some documented A/B clinicals, iterating until you achieve a substantive improvement, so that you have evidence that you've addressed the situation.
(I'm also surprised that your sales/marketing people aren't screaming that something needs to be done to avoid future adverse event complaints and unhappy doctors, but that's an off-topic direction in this forum.)
yodon
I believe MIREGMGR nailed it. I just want to add that this also 'exposes' a possible weakness in your Management Review process. If these complaints are chronic and this information is not being raised and discussed at the management level, your quality system is probably not working as it should.
Ajit Basrur
How about additional labeling instructions on the insert / label - will that help you as Preventive Action ?
DeviceMaker
The only number raised is the 90%. If they have sold 100,000 units, with 10 complaints, 9 of them being doctor mis-use, I would recommend keeping the current instructions, etc... If they have sold 1,000 units with 100 complaints, 90 of them being doctor mis-use, I would recommend a change. All depends on the actual data. I know 90% seems high so it jumps out and makes people think that a reaction is needed, but it should only lead to further questions to get to the real numbers. I hope this helps. :2cents:
B How to reply NCR on ineffectiveness of corrective action during IATF external audit? This is repeated issue whereby some mistake was done. IATF 16949 - Automotive Quality Systems Standard 7
M Medical Device News EC – Commission reply to a Petition “For a Compensation Fund for PIP Breast Implants and CE” from the website change.org Medical Device and FDA Regulations and Standards News 0
I How to reply to customer 8D Fishbone related to a corrosion issue? Preventive Action and Continuous Improvement 7
I Corrective Action Reply to a Customer - Operator Error Nonconformance and Corrective Action 50
F Can we reply to a CAR (Corrective Action Request) without Root Cause? Problem Solving, Root Cause Fault and Failure Analysis 24
A If you use Magic Windows Professional SPC Software. Please Reply Quality Manager and Management Related Issues 1
U Response to FDA 483. Responded within 14 days and now waiting for reply US Food and Drug Administration (FDA) 7
F Multi-Level CA (corrective action) Process? Levels of investigation, reply deadline Nonconformance and Corrective Action 4
S Favour Friends-No reply QS-9000 - American Automotive Manufacturers Standard 0
N UNcertainty Queries !!!PLease reply ! Measurement Uncertainty (MU) 5
D What are the acceptance criteria/requirements for Stability Study? General Measurement Device and Calibration Topics 7
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 0
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J WAIVED ON Q1 - We Don't have to comply with FORDS customer specific requirements IATF 16949 - Automotive Quality Systems Standard 2
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
P Requirements for being an European Representative EU Medical Device Regulations 3
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
lanley liao How to understand correctly the requirements of API monogram products Oil and Gas Industry Standards and Regulations 0
A GPS Regulatory requirements? Manufacturing and Related Processes 6
J SSQR-01 Vision Requirements- Color Blindness AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
R Weld Penetration Standards and Requirements Manufacturing and Related Processes 2
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 0
L Requirements for Cables used for Low-Voltage DC Mains (12-36VDC) IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M AS9100D Registrar pre-audit requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
D LiPo battery minimum requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
V MDSAP Requirements for Device Designer Canada Medical Device Regulations 1
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
Le Chiffre Online training available for ISO/IEC 17021-1: Requirements for bodies providing audit and certification of management systems Training - Internal, External, Online and Distance Learning 3
S What are the International Forging Requirements for Nitrogen Strengthened Stainless Steel? EU Medical Device Regulations 3
R Components to a finished medical device, MDR requirements Other US Medical Device Regulations 1
S Distributor requirements in US 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K AS9100D 8.2.1 Review Requirements for Products and Services AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
F Environmental Requirements E-Lab General Measurement Device and Calibration Topics 0
T 21 CFR 820.20 - Quality Planning Requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Composites - Freezer sensor requirements Manufacturing and Related Processes 2
A Requirements for Contract Manufacturers Other Medical Device and Orthopedic Related Topics 3
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
M IEC 61010-1 requirements for motors Other Medical Device Related Standards 0
J Requirements for registering Alcohol Wipes (70% IPA) in Canada Medical Device and FDA Regulations and Standards News 4
Ed Panek IFU Contact Requirements - FDA and MDD/MDR US Food and Drug Administration (FDA) 1
N German National Requirements - Safety Officer/Authorised Rep Other Medical Device Regulations World-Wide 0
S Traceability of requirements to design and risk Design and Development of Products and Processes 3
F USB powered handheld medical device - Isolation requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Class I (exempt) testing requirements Other Medical Device Related Standards 0
