Reporting As Found data - Actual before values or test points necessary?
Hi everyone,
I'm currently in a battle with our Ireland counterparts on the reporting of as found data. The conversation center around a company, Coherent, who manufactures Radiometers that we use in our process.
Their paperwork consists of 2 sheets: the actual calibration certificate, and a service report that has the received information if the unit was found out of tolerance during the check. They simply report the error on this sheet:
Out of published specifications by +.5% at 10600nm
Our Ireland counterparts insist on having actual before values or test points used in the calibration. We have not required this because it costs an extra $125 per unit, and it will only show 3 points used for the calibration. If the sensor is a 0-3 watt, then the calibration points would be 1, 2, and 3 watts.
I have always accepted the simple statement above (out of published specifications), because the error can be determined: .5% of 3w = 0.015w.
Thoughts?
Charlie
Jerry Eldred
Re: Reporting As Found data
There are many schools of thought about this (and I have been exposed - I think - to most of them). First, I should mention that although I have worked in many labs, my present lab requires ALL data.
Here are my views on some of the schools of thought:
OOT DATA ONLY SCHOOL: I have always said that in most cases (my opinion, based on many years of user interface) that when you give a user full data, there is often the implicit (yet incorrect) inference that the instrument is calibrated to the data not specs (remember - incorrect). Some users perceive you are certifying their accuracy to the data points. For example, at 1 volt, the meter reads 1.002 versus a spec of +/-0.01. That 1.002 is only what it read on that standard at that time of calibration. They forget about meter drift and instability as well as uncertainty of the standard, and presume the "1.002" is exact. Then (and I have seen this many times) they compare readings between to of the same model meters, and think you've done something wrong if they don't exactly match. For this reason, in many cases, I have reservations about full before/after data.
MEASUREMENT STANDARDS DATA SCHOOL: I do, however, believe there is great value to full data on measurement standards, as it is a useful tool in evaluating instrument drift, uncertainties, out-of-tolerances, etc. For the sake of time, I won't fully go into that one.
FULL BEFORE/AFTER DATA SCHOOL: Some applications necessitate full data on everything. There is the interval adjustment method that evaluates measurand drift to plot statistically the predicted interval. In product liability or government/ISO compliance circumstances, it can be useful to have full data to evaluate product test defects. There are ISO standards and other standards that implicitly or explicitly require data.
In your specific circumstance, my only thought would be, what do they want to do with the data? Is there a product test, process control, or quality assurance implication which needs to actually use the data points? The quality assurance implication could include an ISO or government regulatory implication.
Don't know how helpful the above has been. But hopefully I added some value.
BradM
Great post by Jerry.
For my own tirade.... (This is just my opinion only)
I am a great skeptic of calibration certificates that don't have any data on it. Sometimes, with no signature. I like to see calibration documentation showing this is what I found, here's what I did, and here's how it is returned to you. Maybe.... that gives me more confidence that a human being actually touched the instrument. I know, the competent lab thing. But still, that's just how I am. To me, a competent lab should have the evidence of what they found when they checked an instrument. Why should I have to pay for that data??:soap:
OK, back to reality. In general, I prefer to have data attached. First, I am always inquisitive as to the method certain instruments were verified. Next, as Jerry suggested, it gives me better information for determining if I have drift, to what magnitude, etc. Even if it is within tolerance, I would still like to know if the instrument was adjusted and at what point.
Sometimes when there is a problem, or I am dealing with highly technical individuals, they want to see the calibration certificate with the information on it. Showing them a sheet with no data does not go well sometimes, and they critique the calibration. Not that their critique is justified; I just don't want to have to deal with it!
As far as your calculation of OOT data (if you don't have the data), how do you know if it was just out 5%? Maybe it was out 12% I would think you would be interested in magnitude.
S Reporting REACH - Electronic components distributor REACH and RoHS Conversations 5
A OQ and reporting issues Qualification and Validation (including 21 CFR Part 11) 2
R Vigilance reporting to the country of the EU authorised representative EU Medical Device Regulations 2
M Is it Necessary to Use Health Canada Form when Reporting? Canada Medical Device Regulations 1
L Proof of Concept Studies - Do we need to comply with SAE reporting? Medical Device and FDA Regulations and Standards News 3
G ISO 17025-2017 Management Review reporting items - Inputs ISO 17025 related Discussions 1
A Medical device Reporting : Good Faith Effort for Additional information Other US Medical Device Regulations 2
B FDA-Medical Device Reporting (MDR )procedure compliant with 21CFR section 803 US Food and Drug Administration (FDA) 0
F Risk for Quality Assurance Department in a Hospital - Hospital Incident Reporting ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Differences in post market safety reporting for Combination Product Applicants Medical Device and FDA Regulations and Standards News 1
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
L Adverse Event Reporting New Zealand Other Medical Device Regulations World-Wide 11
M Informational New Zealand – Changes to Medical Device Adverse Event Reporting process Medical Device and FDA Regulations and Standards News 0
K Reporting a Change of Contract Manufacturer for a 510(k) cleared device Other US Medical Device Regulations 5
MDD_QNA How to deal with FDA after not reporting anything for several years Other US Medical Device Regulations 14
D Accident reporting categories Occupational Health & Safety Management Standards 1
T Trend Reporting under the EU MDR EU Medical Device Regulations 11
M Informational TGA – Medical device incident reporting (MDIR) guide Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final guidance – Postmarketing Safety Reporting for Combination Products Medical Device and FDA Regulations and Standards News 0
M Informational IMDRF proposed document – IMDRF terminologies for categorized Adverse Event Reporting (AER): terms, terminology structure and codes (Edition 4) – Anne Medical Device and FDA Regulations and Standards News 0
M Informational Health Canada – Mandatory reporting requirements for hospitals Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – Statement on agency’s efforts to increase transparency in medical device reporting Medical Device and FDA Regulations and Standards News 0
A Japan's Requirements for Reporting Medical Device Adverse Events Other Medical Device Regulations World-Wide 2
T Why do most companies have Quality reporting to Engineering or Operations and not to CEO? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
M Informational TGA – Medical device annual reporting – Sponsor obligations Medical Device and FDA Regulations and Standards News 0
Marc European universities dismal at reporting results of clinical trials - 2019 Other Medical Device Regulations World-Wide 0
W SOP for Vigilance reporting covering multiple requirements Document Control Systems, Procedures, Forms and Templates 3
M (How To) Getting Data From Vision Machine To Reporting Software Misc. Quality Assurance and Business Systems Related Topics 0
F Vigilance Reporting - Requirements for manufacturer Field Corrective Actions (FCAs) Other Medical Device Regulations World-Wide 5
S Legal Manufacturer FDA Reporting Obligations for Using New Contract Sterilization Site Other Medical Device Regulations World-Wide 0
Pmarszal ISO 19011:2018 - Risk Based Approach for planning, conducting and reporting of internal audits Internal Auditing 8
J MDR reporting and CAPA thoughts? Classifying Complaints on Risk 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
L Calibration Accuracy In Relation To Reporting General Measurement Device and Calibration Topics 1
S Adverse Event and Serious Adverse Event Reporting - Korea Other Medical Device Regulations World-Wide 4
R Reporting Profile of a surface with U modifier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Q U.S. Agents - Responsibility for reporting adverse events to the FDA Other US Medical Device Regulations 10
J Japan AE (Adverse Event) Reporting Requirements Japan Medical Device Regulations 5
S MDS (Material Declaration Sheet) Reporting for Volatile Solvent in oil RoHS, REACH, ELV, IMDS and Restricted Substances 1
shimonv Reporting Medical Device Changes with Annex V/VII EU Medical Device Regulations 1
L MDR (Medical Device Reporting) under 21 CFR Part 803 Other US Medical Device Regulations 5
Q Medical Device Reporting In US/ EU/ Canada Customer Complaints 6
N Notification of Changes to a Class I Medical Device - Reporting Requirements EU Medical Device Regulations 4
C Software for trending and reporting particulate testing Quality Assurance and Compliance Software Tools and Solutions 2
P Using Bugzilla as a Quality Reporting Tool Quality Assurance and Compliance Software Tools and Solutions 11
JoCam Incident Reporting MHRA (Medical & healthcare regulatory agency) EU Medical Device Regulations 3
A Reporting Corrective Action System Performance Metrics Quality Tools, Improvement and Analysis 1
S Medical Device Reporting SOP (Standard operating procedure) example Other Medical Device and Orthopedic Related Topics 1
V ICH Q3 - To "Include OR Not to Include" impurities below reporting threshold General Measurement Device and Calibration Topics 2
A What are the obligatory medical device reporting timelines for AIMD devices ? ISO 13485:2016 - Medical Device Quality Management Systems 2
