Request: Bare Bones ISO9k2k DESIGN procedure and Forms - Metal Stamping (small)
tomvehoski
#11
Claes,
Most of my clients have a very straighforward design process, so we use a basic design plan form that records all of the inputs, outputs, reviews and so on. I also have some that do the full project management Gantt charting and so on. It all depends on the product being designed.
Where I would resist including design is the once a year type deal where someone drops by your welding shop and says I need a hook to pick up this part with a crane. Welder fabs a hook, they pick up the part to test it, it works and customer leaves with his hook in an hour. Technically this is design with inputs (pick this up), outputs (here is your hook), review, veriifcation and validation (picked it up, did not break). The missing link is documentation. I've seen this type design in a lot of small shops. I don't see much value in adding a procedure and documentation for it if it only happens very infrequently.
Tom
Bob_M
#12
tomvehoski said:
Claes,
Tom
Can you provide a sample of the very straightforward design process form?
We NORMALLY don't need the who Gantt chart and so on system (which is what we have - its overkill like I stated).
We don't do the one time design so that wouldn't be a problem here.
Past example of a "design" that I wish we had documented (for future reference). It was worked on just prior to creating our current documentation (we basically had none, but I still have most of the legal pads and notes I kept).
Customer asked us to take an exisiting roof gas exhaust assembly (ancient design - semi owned by us) and MODIFY it to meet a new/different application.
Customer provided basic input. I provided internal input and design/production needs. Sample/sketches were supplied to customer (several times). Final design approved by CUSTOMER and TESTED by customer.
I consider this a BIG design project (from our perspective). But it was minor in customer's eyes.
Customer provided input, we made some internal sheet metal design changes and new subcomponent. Customer approved FINAL assembled product. We approved subcomponents for fit and function. So WE designed this product internally.
This is NOT a normal thing for us. We may NEVER do something that major again for our current product lines.
Our standard "design" changes are material changes, fit and function, etc that are not REQUIRED by customer and/or no prints ever existed (mainly sheet metal parts).
So yes, I feel we need a design program to assist in TRACKING the changes made. But I want a simple and straightfoward paperwork trail that I MUST follow per an updated procedure.
Does that help or make it worse?
Yeah almost time to go home!
tomvehoski
#13
Bob,
I e-mailed you a sample since I'm not set up for attachments here (and not sure if you are).
Tom
Bob_M
#14
tomvehoski said:
Bob,
Tom
Thanks for the sample. It should get me going in the right direction.
It looks simple and straightforward. We currently have a form for EACH step and several checklist forms. Talk about overkill for a small company that barely designs anything.
Obviously each company would need to tweak it based on their system.
Bob_M
M Greenaway
#15
Tom
You are utterly wrong in what you say - you cannot, according to ISO9001, scope out of your certified system any activity you do which affects you ability to satisfy customers, whether the process is in the same building, across the road or in another country. Any certification body that grants a certificate under these circumstances is commiting gross mis-conduct.
Also the ISO9001 certificate applies to the QMS and the processes involved, it is not product specific, so to say that you are approved for the manufacture of blue paint is again misleading and incorrect.
But perhaps more importantly why would you not want to control a certain process, why scope it out ??
Craig H.
#16
Hi, all
I'm kind of late coming to this thread, but we do very little design and successfully completed our transition from ISO 9002:1994 to ISO 9001:2000. We did not exclude design. Instead, we have a 1-page procedure that states who has design input and final approval. Paper trail is provided by internal memos.
Its simple. Works for us.
Craig
M Greenaway
#17
Well done Craig.
Its not difficult to do is it !
Why make such a fuss to try and exclude design from your system (not that in reality you ever could).
Is it fear of designers, or the design process, or a feeling of inadequacy against these highly educated individuals ???
The design clauses are perhaps some of the loosest clauses you can find. You do not audit the technicality of the design itself, simply the management and control of the design process - its a piece of pizz.
Most external auditors swallow any old [email protected] from the design staff anyway so dont sweat over it.
J Supplier not responding to PPAP request APQP and PPAP 5
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
L Clinical research - Request from ANVISA ISO 14971 - Medical Device Risk Management 1
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
E Annual PPAP+ deviation request ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G IMS (Integrated Management System) 9001, 14001 & 45001- Request Assistance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
F ISO 13485 - EU countries that could request another audit ISO 13485:2016 - Medical Device Quality Management Systems 2
M Customers Request AS9100 certification - Small Company (less than 20 employees) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 9
O ISO 9001 new certification advice request - Develop a QMS from scratch ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Informational Draft standardisation request as regards medical devices in support of Regulation (EU) 2017/745 and in vitro diagnostic medical devices in support of Medical Device and FDA Regulations and Standards News 2
T NAFTA request for form with no part numbers showing Supply Chain Security Management Systems 0
R IATF Exemption Request Letter IATF 16949 - Automotive Quality Systems Standard 0
M 8.3.2.3 Development of products with embedded software - request for clarification IATF 16949 - Automotive Quality Systems Standard 1
W Part Change Request - Standard (OTS) electronic parts (resistors, capacitors etc.) IATF 16949 - Automotive Quality Systems Standard 3
C Supplier blowing off CAR request Registrars and Notified Bodies 14
S PPT for ISO13485:2016 Employee Training (Request) ISO 13485:2016 - Medical Device Quality Management Systems 0
D IMDS for machining - Can my customer request a IMDS number for a part? APQP and PPAP 2
E CAR (Corrective Action Request) Due Dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
J Class 1 Medical Device ECR (Engineering Change Request) Changes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M Is it ok to provide a different language upon request? EU Medical Device Regulations 25
B Supplier is denying visit request Supplier Quality Assurance and other Supplier Issues 52
B Request for Information; Application for Accreditation Japan Medical Device Regulations 0
S Engineering change order versus a design change request ISO 13485:2016 - Medical Device Quality Management Systems 1
L Quality Manual for a Quality Plan (Manufacturing secrets?) Request Misc. Quality Assurance and Business Systems Related Topics 1
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
R How many Corrective Action Request can be Issued by DCMA for a single issue? Nonconformance and Corrective Action 2
R DCMA QAR Request Supplier Data AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
J When to Initiate a CAR (Corrective Action Request) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Scheduling a Crisis Management Audit? Reasonable Request? Internal Auditing 2
S SCAR (Supplier Corrective Action Request) Timeliness & Issuance Supplier Quality Assurance and other Supplier Issues 3
I AS9100D - Interview Request - I'm doing research Misc. Quality Assurance and Business Systems Related Topics 1
G Should the Quality Department originate a Request for Deviation to the Customer? Nonconformance and Corrective Action 3
L Procedure Change Request Form - "ISO Procedures" Document Changes Document Control Systems, Procedures, Forms and Templates 5
B Should I Request/Submit a PPAP from/to a Supplier/Customer for only Repackaging Parts APQP and PPAP 7
Moncia Recalculating RPN (FMEA Risk Priority Number) - Customer Request APQP and PPAP 10
S Establishment Inspection Report - Request 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
I Request an FDA GUDID Account - Problems Other US Medical Device Regulations 3
M Request for clarification on TS 16949 Clause 5.6.1.1 IATF 16949 - Automotive Quality Systems Standard 5
M After I vent...what is it with all the tech file request? EU Medical Device Regulations 14
N How Can I Respond to this SCAR (Supplier Corrective Action Request)? Nonconformance and Corrective Action 15
Q Broken Request for Quotation Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A Supplier Audit Request - Made be laugh ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Inspector CA (Corrective Action) request Nonconformance and Corrective Action 12
W CE Mark for drone launcher military equipment at customer's request CE Marking (Conformité Européene) / CB Scheme 3
M Change request to migrate records between two mediums Quality Manager and Management Related Issues 2
T IMDS - MDS request for parts supplied to multiple customers RoHS, REACH, ELV, IMDS and Restricted Substances 15
Q How to handle customer request for changing specifications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Pancho "IRS" Request for recertification of foreign status [SCAM] After Work and Weekend Discussion Topics 6
Q Supplier Audit Corrective Action Request Responses Supplier Quality Assurance and other Supplier Issues 4
