Request: Procedures for BASIC in-house Calibrations - Small Company
Bob_M
Info First:
We are relatively small company that uses mainly Calipers, Micrometers, and Tape measures in the productions/receiving areas.
We have a very basic work instructions that tells me how to calibrate/verify these types of gages in-house. I also received some quick training on how to do them before our last quality manager left.
The procedure/work instructions overall are OK, but just barely.
With out BUYING more standards or going to more training (low $$ right now), can any one provide some other their procedures for calibrating there equipment in house?
Also what kind of standards/publications or training could I seek out?
Our program works so far, but I have no real training or background in this area, I'm a bit concerned about the long term for our company and MYSELF.
Thanks Bob_M
tomvehoski
What kind of inspections are you performing? How tight are your tolerances?
Basic checks on calipers and micrometers with certified gage blocks are usually sufficient. You don't need to spend a fortune to make sure your caliper is correct. Some things may not even need to be checked. If your receiving person is using a caliper to tell if a piece of bar stock is 1.25 or 1.5 OD, you don't need to calibrate that caliper.
Production gages may not need to be calibrated (at least not very often) if you use inspection gages for a final check. If everything goes through a CMM or other inspection later, you may determine that the risk of not catching a bad part in production due to lack of calibration is less than the cost it would take to calibrate every device.
I often rely on a single page form that shows where a caliper should be checked (i.e. 0, 2, 4, 6" +/-.0005) and records the actual readings before and after calibration.
It does not have to be fancy and expensive to work.
Tom
K
Ken K
One question...are you asking per ISO 17025 or QS/TS? Will make a difference in the answer to your question.
Bob_M
I'm asking for ISO9K2K (upgrading from 1994).
tomvehoski:
Most CURRENT tolerances are only 3 places (inches). Not very tight, but critical on a few parts/materials.
We do incoming material thickness/width inspections (most common type) with calipers and micrometers.
We do first piece, in-process, last-piece and final (when necessary), using mainly calipers, micrometers, and tape measures. NO CMMs. A few "fixtures" or go-nogo type gages.
I know we don't need rocket science quality calibrations, but I do want a program that will work for the long term (ie tighter tolerance parts in the future).
We/I check caliper/mics against (externally) calibrated gage blocks. I know this works, but SHOULD we be doing more/better?
K
Ken K
If you feel your current system works and your auditor feels the same, why do you feel you should be doing more/better?
If you feel you should be doing more, get a copy of the MSA manual. It will give you many idea's as far as things you could be doing.
Have you ever considered having an outside calibration lab do your calibrations and you concentrate on verifications? Might be an option.
Bob_M
I probably should have the MSA manual. (Adds to wishlist).
We send out some of less BASIC equipment, or stuff I have no personal idea how to calibrate/verify.
I'm asking for improvement suggestions, because I don't know if our programs is good enough. It may be good enough for now, but if I'm calibrating/verifying incorrectly, over time the equipment may not truely be in spec.
Besides, I want to be more educated if possible. For my current job and myself.
tomvehoski
It sounds like your calibration system is probably fine. You may want to look at the MSA manual to see if gage R&R studies or similar will be a benefit. From what I have seen it is usually more expensive to outsource basic calibration - $30-$40 per mic or caliper. As long as your gage blocks are NIST traceable, you should be fine.
If you want additional training, you might want to look at ASQ. Perhaps a Certified Mechanical Inspector or Calibration Tech would give you some additional ideas. Local sections offer refresher courses at relatively reasonable prices. I have not gone for either of these certificates, so I don't know everything about the body of knowledge.
If you have some money to spend, I would probably look at upgrading the equipment to something that can be more precise and/or efficient to use. I know we save a ton of time at one place I worked when we purchased an advanced digital height gage - cut inspection time way down. It might help you get those tighter tolerance part contracts if you can show that you have the technology to inspect tighter tolerances.
Tom
Bob_M
Tom
NOPE no money to spend at the moment.
We do have all digital calipers, some digital mics, digital height gage.
The gages are good enough for current product requirements. I just don't think my knowledge is enough, especially if we were to get higher-tech product lines or products.
*shrug*
K
Ken K
Our current cost for calipers and mics is $12.00 per gage per year. Digital height gage is not much more. Considering time spent verifying or calibrating it might be a wash. And the uncertainties will be calculated. A2LA accredited lab.
As far as training goes, Mitutoyo has seminars which are reasonably priced. The materials you receive are worth admission.
Have you checked for classes at a local Technical College?
I would definately get the MSA manual. Gage R&R's should give you an indication how good you system is.
AlbertPaglinawan
hello,
you might want to add the JIS Handbook Mechanical Instrumentation on your wishlist. we purchased a copy and it is great! it gives a detailed procedure in calibrating micrometers, calipers, gauges, etc. (ex, measuring method for parallel screw gauge). This really is a must for dimensional metrology. Unless there is an equivalent book in the U.S. (This book is from Japanese Standards Association translated in english)
cheers!
-jahar
L Procedure Change Request Form - "ISO Procedures" Document Changes Document Control Systems, Procedures, Forms and Templates 5
J Is DCR (Document Change Request) Needed for Initial QMS Procedures? Document Control Systems, Procedures, Forms and Templates 16
N Supplier Process Change Request Procedures, Forms and Flow Charts Document Control Systems, Procedures, Forms and Templates 3
W Engineering ECR (Engineering Change Request) and ECN (Eng Change Notice) Procedures Document Control Systems, Procedures, Forms and Templates 3
R Procedure Request for the six 'must have' documented procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A What specific Quality "Must have's" would you like included in a Request For Quotation? Customer and Company Specific Requirements 3
S F-108 Request for Expansion of Scope of Accreditation ISO 17025 related Discussions 2
I Request for information regarding remote medical monitoring software (its technical documentation and the IUD system) IEC 62304 - Medical Device Software Life Cycle Processes 2
H Ever given an Operations Manager an internal Corrective Action Request? Nonconformance and Corrective Action 5
G Notified body quotation request ISO 13485:2016 - Medical Device Quality Management Systems 2
Ed Panek Consultant Request SaMD AI "Expert" FDA US Food and Drug Administration (FDA) 2
somashekar Stage 1 Finding. Request views and comments ISO 13485:2016 - Medical Device Quality Management Systems 3
E DESIGN VALIDATION, USABILITY AND CLINICAL EVALUATION request Medical Device and FDA Regulations and Standards News 0
M Resume Review Request - Quality Assurance Career and Occupation Discussions 11
N API Q1, Management of Change & Document Change Request Oil and Gas Industry Standards and Regulations 4
Watchcat Change Request Documents - What's Typical These Days? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
Q Request Calibration Info Calibration and Metrology Software and Hardware 16
J Drawing Example Request: Inspection Section Plane of Aluminum Casting Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Reseller Request to Change UPC on Medical Device via Re-labeling Medical Device and FDA Regulations and Standards News 5
M Pre-Sub preparation (for de Novo request) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Supplier not responding to PPAP request APQP and PPAP 5
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
L Clinical research - Request from ANVISA ISO 14971 - Medical Device Risk Management 1
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
E Annual PPAP+ deviation request ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G IMS (Integrated Management System) 9001, 14001 & 45001- Request Assistance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
F ISO 13485 - EU countries that could request another audit ISO 13485:2016 - Medical Device Quality Management Systems 2
M Customers Request AS9100 certification - Small Company (less than 20 employees) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 9
O ISO 9001 new certification advice request - Develop a QMS from scratch ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Informational Draft standardisation request as regards medical devices in support of Regulation (EU) 2017/745 and in vitro diagnostic medical devices in support of Medical Device and FDA Regulations and Standards News 2
T NAFTA request for form with no part numbers showing Supply Chain Security Management Systems 0
R IATF Exemption Request Letter IATF 16949 - Automotive Quality Systems Standard 0
M 8.3.2.3 Development of products with embedded software - request for clarification IATF 16949 - Automotive Quality Systems Standard 1
W Part Change Request - Standard (OTS) electronic parts (resistors, capacitors etc.) IATF 16949 - Automotive Quality Systems Standard 3
C Supplier blowing off CAR request Registrars and Notified Bodies 14
S PPT for ISO13485:2016 Employee Training (Request) ISO 13485:2016 - Medical Device Quality Management Systems 0
D IMDS for machining - Can my customer request a IMDS number for a part? APQP and PPAP 2
E CAR (Corrective Action Request) Due Dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
J Class 1 Medical Device ECR (Engineering Change Request) Changes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M Is it ok to provide a different language upon request? EU Medical Device Regulations 25
B Supplier is denying visit request Supplier Quality Assurance and other Supplier Issues 52
B Request for Information; Application for Accreditation Japan Medical Device Regulations 0
S Engineering change order versus a design change request ISO 13485:2016 - Medical Device Quality Management Systems 1
L Quality Manual for a Quality Plan (Manufacturing secrets?) Request Misc. Quality Assurance and Business Systems Related Topics 1
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
R How many Corrective Action Request can be Issued by DCMA for a single issue? Nonconformance and Corrective Action 2
R DCMA QAR Request Supplier Data AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
J When to Initiate a CAR (Corrective Action Request) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Scheduling a Crisis Management Audit? Reasonable Request? Internal Auditing 2
