Required platform for scales (a weighty matter?)
Asherlee
We are about to commence peformance and accuracy testing of the experimental protoypes of our infusion pumps. The applicable standard is IEC 60601-2-24.
We have purchased sensitive, calibrated electronic scales in order to carry out the above testing.
Question: Is there any requirement (in a standard) concerning the table or basis on which the scale is located in order to ensure that the scale is standing 100% horizontal and straight?
For example, maybe the top of table must be made of granite or marble in order to ensure that the surface is “solid” and does not move, or will not vibrate if the table is accidentally pushed.
Thanks for the input.
Asherlee
W
W. de Jong
Hi Asherlee,
I can't think of such a standard, most likely to me seems that the working environment should enable a valid result of the calibration.
Why don't you contact the supplier of the scale?
Kind regards
Asherlee
Like W. DeJong, I don't know of any standard. The things you're concerned about (vibration, squareness to the supporting surface, etc.) are potential contributors to uncertainty and error, and as such must be determined individually in each application. You can design an experiment to test the scales under different conditions to determine how supporting the scales might affect test results.
Craig H.
The answers so far are good. You mentioned using marble or granite. There is another alternative if you decide to go that route. If you contact a cement mixing company in your area, you might find that they make concrete table tops, often out of the concrete left over after a run. The ones I have seen are about 6" thick. Supported at each end by stacked cinder blocks they are rock solid, and should be much cheaper than natural stone. Of course if the floor they are sitting on vibrates, well, good luck.
Hershal
Metrologist-Auditor
No requirement that I am aware of either.....
Granite is a good choice, though I suggest making sure it is a AA as opposed to A or B.....that is because of the use that you suggest it will receive.
You may also consider one of the manufactured tables made from aluminum or similar.....one company I know that produces them is Newport www.newport.com
Hope that helps.
Hershal
K
Kevin H
Asherlee, I'd tend to disagree a bit with the prior comments. I'm not familiar with the standard you mentioned, or the required or inherent accuracy of the scales in question. I am somewhat familiar with weighing requirements, including those for some precise laboratory measurements. Depending on your requirements mounting may be critical - smooth level surface (as Hershal suggests via the granite mounting plate. Ensuring freedom from vibration may be critical as well, I've seen lab scales fluctuate depending on which way a fan or air conditioner was blowing. I'd contact the manufacturer of your scales and check what their recommendation is and follow it to ensure the maximum accuracy. Good luck with your project.
Suggestions thus far:
1) Contact the manufacturer
2) Experiment to determine specialized needs
3) Concrete might be a cheaper alternative
4) AA granite plate or manufactured table
Which do you disagree with?
Asherlee
To all those who replied,
Thanks a lot for your input and for sharing your ideas.
The manufacturer requires the scales to be horizontal and free of vibration, but leaves it to you to implement this as you see fit.
As we all live in the "real world", we know that budget also plays a role in the choices that we make, hopefully not at the expense of quality. My first choice is a granite table.
Regards,
Asher
O AIAG VDA DFMEA Template Required FMEA and Control Plans 2
B PMA Supplement Required? US Food and Drug Administration (FDA) 3
F UDI-PI required on packaging (MDR) EU Medical Device Regulations 2
S Required tests for Surgical gown US Food and Drug Administration (FDA) 1
R Is a FAIR required on parts that we design? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B NIOSH Approval for Surgical N95 Respirators - Required testing US Food and Drug Administration (FDA) 2
A 8.6 Release of products and services, 8.3 Design and development - evidence required ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D Deciding whether or not pre-market clinical investigation is required for low risk device EU Medical Device Regulations 5
R Green dot required on packaging? Medical Device and FDA Regulations and Standards News 2
M Indian Medical Device Rules - Manufacturing and Wholesale Lic. Required? Other Medical Device Regulations World-Wide 12
B Where to acquire EN 868-5 required dye (Amaranth red)? Other Medical Device Related Standards 2
Marcel DS How do I know if my product is required be RoHS certified? REACH and RoHS Conversations 6
K When is Bioburden Testing Required? Other Medical Device Related Standards 4
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
D Device functionality over service life - Objective evidence required? Design and Development of Products and Processes 10
M Quality management certification required by Health Canada Canada Medical Device Regulations 3
N Usability testing required for FDA IDE (investigational device exemption)? Human Factors and Ergonomics in Engineering 8
R Shall a new UDI-DI be required when stand-alone software device's version is updated? EU Medical Device Regulations 1
A Question on ISO 14001:2015 - Are annual audits required? ISO 14001:2015 Specific Discussions 11
M Is Validation of Plating Processes required and who is responsible? Qualification and Validation (including 21 CFR Part 11) 11
MDD_QNA Medical Device Software - Is a Help Button required? IEC 62304 - Medical Device Software Life Cycle Processes 1
O ISO 13485 - Is management review required before stage 1? ISO 13485:2016 - Medical Device Quality Management Systems 6
D Recent changes to ISO 14971 - SOP required for managing standard revisions ISO 13485:2016 - Medical Device Quality Management Systems 1
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
V Manufacturing requirements for respiratory ventilators - clean room required? Medical Device and FDA Regulations and Standards News 6
A When there is a 2 year lapse in production, is a full FAI required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Is it required to put"Rx only" on the home page of an app? Medical Device and FDA Regulations and Standards News 4
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
R Is it required to have an SOP for external audits? Medical Device and FDA Regulations and Standards News 7
M MDR - Is a formal GSPR Procedure required? EU Medical Device Regulations 20
M When is FAI required? AS9100 8.5.1.3 and 8.4.3 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
B IATF 16949 - Is a Deviation required for sample components in a prototype build? IATF 16949 - Automotive Quality Systems Standard 13
J MDD to MDR transition - Time required for the implementation of the MDR EU Medical Device Regulations 7
Robert Stanley Required Documentation Templates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M ISO 9001:2015 8.2.1 Contingency Plan required for small Business? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M MDR - Under what circumstances is a PMCF not required? EU Medical Device Regulations 1
B AIAG-VDA FMEA - When the new format will be required FMEA and Control Plans 5
MrTetris Are GLP required for testing cytotoxicity and soil remaining after sterilization of MD? Other Medical Device Related Standards 8
Z EN 868-8 "required tests" - Rigid sterilization containers Other Medical Device Related Standards 0
D Design Verification - Is testing required? Design and Development of Products and Processes 5
M User manual / instructions for use for class II device always required? Medical Device and FDA Regulations and Standards News 3
A Calibration required by OEM General Measurement Device and Calibration Topics 2
S How many mandays required for the below mentioned standards IEC 27001 - Information Security Management Systems (ISMS) 3
S Examples of software changes that required a 510k US Food and Drug Administration (FDA) 2
D Required Checklist Showing Compliance to IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 11
