Requirement for Review and Re-Approval of Documents - ISO 9001 Clause 4.2.3
baynoli
hi don't know if this is already being asked in the forums. This is regarding 4.2.3 Control of documents letter b, "to review and update as necessary and re-approve documents," I just would like to know when "re-approved is used"?
thanks
baynoli
Stijloor
Re: Re-approve documents.
thanks
Noli Baylosis
"Re-approve" is required, for example, after a document has been changed.
Stijloor.
Ajit Basrur
thanks
Noli Baylosis
Hi Noli,
The re approval of the documents may ne necessitated due to internal audits, management reviews, change in process or change in requirements etc.
Moncia
This one I know
Each time you revise a document, lets say you changes procedure in Work Instruction. When you rewrite it, you have to change revision number. So the new, revised Work Instruction has to be authorized, and signed-either electronically or if you have hard copy, in pen by the process owner. Only then you can put it in the system.
I hope I did not confuse you more
al40
Also you should review critical procedures and process periodically to ensure they are current and accurate. i.e. I just finished an supplier audit and found document that had not been updated for seven years and the current process was different. So you should at least set up a certain time span to review procedures and processes critical to your quality system and products.
best regards,
Al40
H
Houcka
I understand when a document is revised it needs to be re-approved, but does Clause 4.2.3(b) also mean I should be getting documents re-approved when the review takes place but an update was NOT necessary?
No. It's only to ensure that if changed, documents are (re) approved. It's not required or necessary (IMHO) to be reviewing documents regularly. In some cases - Regulated organizations - have that requirement, it's understood, but in the case of ISO 9001 there's no requirement, since audits should tell you if the document needs revision if not already found in the course of planned changes/improvement.
suka_batang
As per my practice, re-approve only require when there are many/major changes that alter the way of the normal operation, impact to workprocess, the SOP scope changed.:)
F Process Review - What is the ISO requirement for reviewing SOPs and quality documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q Is there a regulatory requirement for clinician review for pFMEAs? ISO 14971 - Medical Device Risk Management 2
A How to satisfy the "Interested Party" Management Review Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q ISO 9001 Requirement(s) for the Review of Work Instructions Document Control Systems, Procedures, Forms and Templates 11
I Does ISO 13485 have a Periodic Document Review Requirement? ISO 13485:2016 - Medical Device Quality Management Systems 7
J Corrective Action Review - AS9100 Rev. C Requirement AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Requirement for a Documented Process for the Review and Release of Product For Sale ISO 13485:2016 - Medical Device Quality Management Systems 6
K Is there a requirement for Management Review Meeting under BRC? Management Review Meetings and related Processes 6
M How to satisfy the Management Review requirement without a meeting? Management Review Meetings and related Processes 29
J What to be reported on "New or Revised Regulatory Requirement" at Management Review? Management Review Meetings and related Processes 8
Q Computerized System Periodic Review Requirement - Pharma Company Qualification and Validation (including 21 CFR Part 11) 7
J Contract Review - Please help me define the requirement 7.2.2 Info needed Contract Review Process 9
H TS 16949 Cl 7.2.2 - Review the Requirement Related to the Product IATF 16949 - Automotive Quality Systems Standard 1
G Is there a requirement for Management Review Meeting Minutes? Management Review Meetings and related Processes 39
J Readiness review documentation - Every TS requirement has to be addressed in the QM? IATF 16949 - Automotive Quality Systems Standard 15
J ISO 9001 Requirement Review - Beverage delivery company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Water requirement for Non-sterile topical OTCs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
Y 510k requirement for bringing in gloves Medical Device and FDA Regulations and Standards News 0
S PSUR - MDR First Submission Requirement? EU Medical Device Regulations 2
J When PPAPs are not a contractual requirement APQP and PPAP 9
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Clinical Trial Requirement - No equivalent devices in the market CE Marking (Conformité Européene) / CB Scheme 3
J Requirement for Retention of Records of Withdrawn Documents of External Origin Document Control Systems, Procedures, Forms and Templates 3
T ISO 17025: Lockout/Tagout Requirement ISO 17025 related Discussions 1
A The requirement of the PMS plan--suitable indicators and threshold values EU Medical Device Regulations 0
S Battery powered device - electrical protection requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
K Regulatory requirement of SaMD with machine learning component IEC 62304 - Medical Device Software Life Cycle Processes 3
A ASL requirement when the supplier is certified for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
P Regulatory or registration requirement for disinfectant in ASEAN Registrars and Notified Bodies 1
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
D ISO 14971:2019 vs MDR Annex 1, Requirement #4 - "Manufacturers shall inform users of any residual risks" ISO 14971 - Medical Device Risk Management 5
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
J 21 CFR 821 Medical Device Tracking Requirement 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Is Device Tracking Card an actual requirement under FDA regulation? Other US Medical Device Regulations 0
W Misinterpretation of requirement acceptable as root cause? Problem Solving, Root Cause Fault and Failure Analysis 19
S ECG Cable Banana to Snap or Tab electrode Adapters -- ISO 10993 Requirement Other Medical Device Related Standards 0
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
L Stage 2 audit - Requirement for 3 months of records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Requirement to manufacture under a quality management system EU Medical Device Regulations 4
A Risk Number for each software requirement IEC 62304 - Medical Device Software Life Cycle Processes 7
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
I Laboratory Fridge / Freezer Inventory - Requirement(s) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Several sections of traditional 510(K) have the same or similar requirement of content. US Food and Drug Administration (FDA) 4
