Requirement for Secondary Containment of Stored Chemicals
H
HSSE Auditor
#12
Hazardous materials storage in the workplace is primarily covered by OSHA under the Hazard Communication Standard under 29CFR 1910.1200.... http://www.osha.gov/pls/oshaweb/owadisp.show_document?p_table=STANDARDS&p_id=10099
The above quoted OSHA haz com standard does not apply in this case. There is an exclusion in 1910.1450 - Occupational exposure to hazardous chemicals in laboratories. http://www.osha.gov/pls/oshaweb/owad...RDS&p_id=10106
The following is wording in the above standard.
"Scope and application.
1910.1450(a)(1)
This section shall apply to all employers engaged in the laboratory use of hazardous chemicals as defined below.
1910.1450(a)(2)
Where this section applies, it shall supersede, for laboratories, the requirements of all other OSHA health standards in 29 CFR part 1910, subpart Z, except as follows:..."
Randy
#13
Yeah, I see where you're coming from .............. but you might want to read this stuff below and determine the applicability. 29CFR1910.1450 deals with the control of exposure to and not so much with the control of hazardours materials.
May 28, 1999
Ms. Maricela Carter
Baker Hughes; Baker Petrolite
Safety Programs
3900 Essex Lane
Houston, TX 77027
Dear Ms. Carter,
We have received your September 15, 1998 letter to Richard Fairfax, Director, Occupational Safety and Health Administration (OSHA) Directorate of Compliance Programs (DCP), in which you asked questions regarding the classification of your laboratory under the Hazard Communication Standard (HCS), 29 CFR 1910.1200, or the Chemical Hygiene Standard, 29 CFR 1910.1450. Your inquiry can be summarized into two questions, which are outlined below.
Do our laboratories (including quality assurance laboratories) fall under the Chemical Hygiene Standard (29 CFR 1910.1450) or the Hazard Communication Standard (29 CFR 1910.1200)?
The best way to approach this question is to provide you with further information to allow you to make this determination, as we are not familiar with your work processes. Laboratories considered quality control/quality assurance laboratories are classified as adjuncts of production operations and are not covered under the Laboratory Standard, but are covered under the HCS. For those laboratories covered under the Laboratory Standard, the requirements of the HCS are superseded, and the Laboratory Standard takes precedence. Laboratories covered under the Laboratory Standard are those which use or handle hazardous chemicals in which all of the following conditions are met:
Chemical manipulations are carried out on a "laboratory scale",
Multiple chemical procedures or chemicals are used,
The procedures involved are not part of a production process, nor in any way simulate a production process, and
Protective laboratory practices and equipment are available and in common use to minimize the potential for employee exposure to hazardous chemicals.
The Laboratory Standard does not apply to laboratory use of hazardous chemicals which provide no potential for employee exposure. Examples of these would be the use of test media such as "dip and read" tests or commercially prepared pregnancy tests.
Can Baker Petrolite supply its customers with a contact sheet or label stating formulation ID, date formulated, contact person, phone, address, storage and handling information, and warning information (instead of a formal MSDS)?
Baker Petrolite is directly responsible for providing MSDSs and labels which meet all the requirements of the HCS. Containers of chemicals which meet the definition of a hazardous chemical under the standard must be labeled with:
the identity of the chemical,
appropriate hazard warnings, including the target organ effects, and
the name and address of the chemical manufacturer, importer, or other responsible party.
MSDSs must contain all of the required information in paragraph (g) of the standard, 29 CFR 1910.1200, Material Data Safety Sheets. Although there is no required format for presenting hazard information, we have included a sample MSDS form which you might find helpful.
Thank you for your inquiry and we hope you find this information useful. If you require further assistance, please do not hesitate to call the Office of Health Compliance Assistance at (202) 693-2190.
Sincerely,
Richard Fairfax
Director
_____________________________________________________________________________
January 17, 1991
Mr. Thomas Ozimek
Industrial Hygiene Supervisor
BASF Corporation
1609 Biddle Avenue
Wyandotte, Michigan 48192
Dear Mr. Ozimek:
This is in response to your letter of October 17, 1990, to OSHA's Region V Office, requesting interpretations on the Laboratory Standard, 29 CFR 1910.1450. Your letter has been forwarded to the National Office for response. We apologize for the delay.
Your questions and our answers are as follows:
1. Does 29 CFR 1910.1450 cover quality control laboratories where these facilities support the production process through sample analysis? NOTE: See attached interpretation from Avenel area office.
The preamble to the standard indicates that most quality control (QC) laboratories are not expected to qualify for coverage under the Laboratory Standard, since they are usually adjuncts of production operations which typically perform repetitive procedures for the purpose for assuring reliability of a product or a process. This response does not contradict the letter from OSHA's Avenel Area Office.
2. If samples are taken during different phases of the production process to verify quality control of the process, would these labs be covered under 1910.1450 or under 29 CFR 1910.1200?
These labs assuring quality control of the production process would not be covered under 1910.1450 but would be covered under other general industry standards including 29 CFR 1910.1200.
3. Are environmental labs performing analysis on samples for compliance under EPA regulations covered by the Lab Standard?
Yes. Most if not all of these laboratories are not conducting quality control of production processes but are monitoring emissions for environmental control purposes; therefore, they are not exempted from the Laboratory Standard. Such operations would only be considered quality control of production if the result of the monitoring is used as a source of information for process control adjustment.
If making secondary standards is part of the quality control of a production process, the Laboratory Standard would not be applicable. If blending operations result in a product, they would be considered as production processes and not be within the scope of the Laboratory Standard.
4. Request specific clarifications of the following conditions defined under "laboratory use of hazardous chemicals," including: chemical manipulations, production versus non-production, and multiple use of chemicals.
Chemical manipulation simply means the use of chemicals. Production means an operation where a product is produced. Examples of production facilities are refineries, utility- generating companies, manufacturing plants. Multiple use of chemicals (the actual wording in the standard is "multiple chemical procedures or chemicals are used") means using chemicals in laboratory procedures.
Your letter also addressed a concern that QC labs have limited coverage under 29 CFR 1910.1200, and no coverage under the laboratory standard. We are enclosing pages A-3 and A-4 of the updated Hazard Communication directive, CPL 2-2.38C for your information. The coverage of laboratories is limited under the Hazard Communication Standard (HCS) because it was expected that most laboratories would be covered by the Laboratory Standard. However, the directive does state that QC laboratories would generally be covered by the HCS. Please note that in the previous directive, there was no reference to limited coverage of QC labs under HCS as you had inferred.
We hope we have adequately addressed your concerns. If we can be of further assistance, please do not hesitate to contact us.
Sincerely,
Patricia K. Clark, Director
E
elkel
#14
Secondary Containment Requirements
hello
i am new at this and do not know how to start a new post
but i have a audit coming up and need some guidance on secondary containment for 55 gallon drums
i went to the EPA and the DEQ and did not get a clear understanding of what is actually required
i under the understanding that you have to have secondary containment under a 55 gallon drum that can contain at least 10% of the 55 gallons is this a standarad guide or where can i find out about specific requirements
i am in michigan
thank you for any help
god bless
Elke
Randy
#15
Basically under EPA requirments chemicals in storage, like a single 55 gallon drum of potassium hydroxide, don't require secondary containment, but there are exceptions to most any rule.
For a more definitive answer go to your state DEQ and ask them (try their website and the EPA site as well). This is a pretty complicated issue and requires more than what can be given here.
If your system has not identified the legal requirements (4.3.2) you must meet...secondary containment being one of them.....fix it!
If you have legal requirements that must be met and nobody knows how, that's a competence issue under 4.4.2 ........... fix it!
It could also be a resource issue under 4.4.1 ..... fix it!
I QMS monitoring, measurement, analysis and evaluation requirement - Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Requirement for Signature on Document Document Control Systems, Procedures, Forms and Templates 4
L Water requirement for Non-sterile topical OTCs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
Y 510k requirement for bringing in gloves Medical Device and FDA Regulations and Standards News 0
S PSUR - MDR First Submission Requirement? EU Medical Device Regulations 2
J When PPAPs are not a contractual requirement APQP and PPAP 9
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Clinical Trial Requirement - No equivalent devices in the market CE Marking (Conformité Européene) / CB Scheme 3
J Requirement for Retention of Records of Withdrawn Documents of External Origin Document Control Systems, Procedures, Forms and Templates 3
T ISO 17025: Lockout/Tagout Requirement ISO 17025 related Discussions 1
A The requirement of the PMS plan--suitable indicators and threshold values EU Medical Device Regulations 0
S Battery powered device - electrical protection requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
K Regulatory requirement of SaMD with machine learning component IEC 62304 - Medical Device Software Life Cycle Processes 3
A ASL requirement when the supplier is certified for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
P Regulatory or registration requirement for disinfectant in ASEAN Registrars and Notified Bodies 1
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
D ISO 14971:2019 vs MDR Annex 1, Requirement #4 - "Manufacturers shall inform users of any residual risks" ISO 14971 - Medical Device Risk Management 5
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
J 21 CFR 821 Medical Device Tracking Requirement 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Is Device Tracking Card an actual requirement under FDA regulation? Other US Medical Device Regulations 0
W Misinterpretation of requirement acceptable as root cause? Problem Solving, Root Cause Fault and Failure Analysis 19
S ECG Cable Banana to Snap or Tab electrode Adapters -- ISO 10993 Requirement Other Medical Device Related Standards 0
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
L Stage 2 audit - Requirement for 3 months of records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Requirement to manufacture under a quality management system EU Medical Device Regulations 4
A Risk Number for each software requirement IEC 62304 - Medical Device Software Life Cycle Processes 7
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
I Laboratory Fridge / Freezer Inventory - Requirement(s) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Several sections of traditional 510(K) have the same or similar requirement of content. US Food and Drug Administration (FDA) 4
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
Q User Requirement Specification for HR (Human Resource Management System) Manufacturing and Related Processes 1
P Obstruction alarm requirement ISO 80601-2-12 Other Medical Device Related Standards 1
P Electrosurgical Device User Need: Cord Flexibility -> Requirement Other Medical Device and Orthopedic Related Topics 4
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
C ISO 13485 Requirement in Australia/NZ for class 1? ISO 13485:2016 - Medical Device Quality Management Systems 1
N Label Placement Requirement in MDD/MDR EU Medical Device Regulations 1
adir88 MDR requirement: Risk Management Plan for "each device" ISO 14971 - Medical Device Risk Management 5
S Article 61 - MDR Clinical Investigation Requirement EU Medical Device Regulations 5
V 3 PQ lots mentioned as requirement in PPAP. Is this necessary? APQP and PPAP 2
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
F AS9100D, raw material standards are a requirement for manufacturing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Clinical Evaluation - Is this an ISO 13485:2016 requirement? ISO 13485:2016 - Medical Device Quality Management Systems 4
