Requirement for Updating Medical Device Software (Firmware) in the Field
bjarket
Hello!
Are we allowed to update software on released medical devices in the field, or are we only allowed to ship the new software with the new devices from factory?
Thanks!
bjarket
Yes, it would be great with some advice on this...
We follow the obvious standards, 60601-1, 13485, 14971...
Thanks,
/B
Marc
Yes you can update in the field.
Could you possibly expand upon that a bit? Any standards which can be referenced/cited? Other "requirements"? I would personally appreciate it. I'm in "learning mode" myself. Any help in the Medical Device field is appreciated!
bjarket
From my point of view, a software update in the field should be considered as a replacement of a component, and therefore go through the same QA procedure as any other component (e.g. hardware). However, I have no data or real life experience of this to back it up...
Could anyone confirm this principle, or maybe not if special rules apply?
Thanks,
My feeling would be that this is (yet) another situation where risk analysis determines the acceptability of the upgrade.
FDA often quotes the fact that for devices being subject to recall, where software has played a part, 80% of these instances are caused by changes to the software after release. So, I would suggest, only an upgrade that has been very carefully validated and regression tested should go ahead. This is bearing in mind that testing the device in the field is likely to be rather less stringent than in the laboratory.
If you have a well tested update, tested on ALL possible field versions, then I would conduct a risk analysis on the difference between doing it in the field and doing it at the manufacturers site. What could go wrong? Is it possible a fault could be introduced that will not be obvious?
There is also the requirement for configuration management. How will you keep track of the software version in each device?
Q
QSMLauren
There are a couple of threads in this forum that have more information. If I knew how to link them I would. Search under "iec 62304" and "software validation" . The link inserted is an article from Quality Digest.
References: IEC 62304 - Medical Device Software, Software Development Lifecycle Procesess (SDLC)
Principles of Sofware Validation - Guidance for Industry.
http://www.qualitydigest.com/print/7640
Suggested Steps:
1. Identify the risk that the software has on the performance of the device. (Iso 14971 and IEC 62304).
2. The release of the update/fix is in the Maintenance phase of an SDLC, but it still needs to follow the product realization processes as someone suggested above. (21 CFR Part 820/iso 13485) A new version# or some other sort of identification # should be assigned.
3. For the field updates, keep track of the serial# of the device and the new version/or identifyer #. (21 CFR Part 820.160)
4. The user should document this change and retest the device in their environment before using, and documentating per their own change control and/or validation requirements.
Ronen E
Problem Solver
Moderator
Suggested Steps:
Reading this and other posts above, I have a disturbing feeling.
I'm trying to make an analogy with a mechanical hardware part. Let's assume a manufacturer identifies a deficiency (or opportunity for improvement), designs, makes and validates such a new replacement part, then introduces it to equipment already in service.
As far as I understand, this could fall (in the USA) under "servicing" of multi-use devices. This area's regulation hasn't been finalized by the FDA (AFAIK) for the last 10 years or so, and is probably only covered by an industry voluntary compliance plan. So, if I got it right, the FDA doesn't pose any formal requirements on the actual replacement, its documentation, config control etc.
I wonder why should software be treated different to a tangible part.
Cheers,
Ronen.
D What is the acceptance criteria/requirement for Stability Study? General Measurement Device and Calibration Topics 2
L Water requirement for Non-sterile topical OTCs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
Y 510k requirement for bringing in gloves Medical Device and FDA Regulations and Standards News 0
S PSUR - MDR First Submission Requirement? EU Medical Device Regulations 2
J When PPAPs are not a contractual requirement APQP and PPAP 9
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Clinical Trial Requirement - No equivalent devices in the market CE Marking (Conformité Européene) / CB Scheme 3
J Requirement for Retention of Records of Withdrawn Documents of External Origin Document Control Systems, Procedures, Forms and Templates 3
T ISO 17025: Lockout/Tagout Requirement ISO 17025 related Discussions 1
A The requirement of the PMS plan--suitable indicators and threshold values EU Medical Device Regulations 0
S Battery powered device - electrical protection requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
K Regulatory requirement of SaMD with machine learning component IEC 62304 - Medical Device Software Life Cycle Processes 3
A ASL requirement when the supplier is certified for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
P Regulatory or registration requirement for disinfectant in ASEAN Registrars and Notified Bodies 1
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
D ISO 14971:2019 vs MDR Annex 1, Requirement #4 - "Manufacturers shall inform users of any residual risks" ISO 14971 - Medical Device Risk Management 5
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
J 21 CFR 821 Medical Device Tracking Requirement 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Is Device Tracking Card an actual requirement under FDA regulation? Other US Medical Device Regulations 0
W Misinterpretation of requirement acceptable as root cause? Problem Solving, Root Cause Fault and Failure Analysis 19
S ECG Cable Banana to Snap or Tab electrode Adapters -- ISO 10993 Requirement Other Medical Device Related Standards 0
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
L Stage 2 audit - Requirement for 3 months of records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Requirement to manufacture under a quality management system EU Medical Device Regulations 4
A Risk Number for each software requirement IEC 62304 - Medical Device Software Life Cycle Processes 7
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
I Laboratory Fridge / Freezer Inventory - Requirement(s) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Several sections of traditional 510(K) have the same or similar requirement of content. US Food and Drug Administration (FDA) 4
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
Q User Requirement Specification for HR (Human Resource Management System) Manufacturing and Related Processes 1
P Obstruction alarm requirement ISO 80601-2-12 Other Medical Device Related Standards 1
P Electrosurgical Device User Need: Cord Flexibility -> Requirement Other Medical Device and Orthopedic Related Topics 4
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
C ISO 13485 Requirement in Australia/NZ for class 1? ISO 13485:2016 - Medical Device Quality Management Systems 1
N Label Placement Requirement in MDD/MDR EU Medical Device Regulations 1
adir88 MDR requirement: Risk Management Plan for "each device" ISO 14971 - Medical Device Risk Management 5
S Article 61 - MDR Clinical Investigation Requirement EU Medical Device Regulations 5
V 3 PQ lots mentioned as requirement in PPAP. Is this necessary? APQP and PPAP 2
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
F AS9100D, raw material standards are a requirement for manufacturing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Clinical Evaluation - Is this an ISO 13485:2016 requirement? ISO 13485:2016 - Medical Device Quality Management Systems 4
S ISO17020 - Equipment calibration requirement General Measurement Device and Calibration Topics 3
