While I think linking the quality manual, if you have one, to the clause numbers is helpful, there is no requirement. While doing so creates a bit more work when the standard being referenced changes, the extra work also forces you to look more closely at the revised standard and make sure you did not miss anything. We also reference key implementation documents in the quality manual. While not required, if you can't reference a process document, you are likely not compliant.
