Requirement to manufacture under a quality management system
Michael Ayers
I would really appreciate any advice on the following.
One of the key requirements of the new regulations is that the manufacture of a medical devices occurs under an appropriate quality management system (e.g. 13485).
Many hospitals manufacturer either custom devices, or devices used only in-house (therefore applying the Health Institution Exemption). However, it is likely that only part of the hospital will be registered to a suitable quality management system.
What is the specific meaning of the phrase “under an appropriate quality management system”?
Can a hospital department which is registered under a quality management system (e.g. Medical Physics), act on behalf of another department which is not registered under a quality management system (e.g. Ophthalmology) for the purpose of manufacturing devices for the non-registered department?
chris1price
For a custom-made device, you need to comply with Annex XIII. This does not require a Quality Management System, just that the device meet the Annex I, General Safety and Performance Requirements.
If its not a custom-made device, you will need to show evidence of a QMS as part of the CE Marking process. The requirements are laid out in Article 10. I would say Medical Physics could do this on behalf or Ophthalmology, however you would need to have agreements in place to ensure all the necessary elements of the MDR are in place. This would be akin to non-certified company subcontracting the processes to a certified contractor.
Michael Ayers
Many thanks for the response. With regards to custom-made devices, what makes such devices exempt from Article 10.9, which says
Manufacturers of devices, other than investigational devices, shall establish, document, implement, maintain, keep up to date and continually improve a quality management system that shall ensure compliance with this Regulation in the most effective manner and in a manner that is proportionate to the risk class and the type of device.
Custom-made devices are stated as being exempt from certain obligations in Article 10, but I cannot find where they are stated as being exempt from having a quality management system in place.
In the case of Medical Physics being subcontracted by another department to manufacturer a device, would this still be possible if that non-registered department were physically doing the manufacturing?
chris1price
The more you read the MDR, the less clear it becomes...… However this is my reasoning. Starting with Article 10-9. The paragraph starts
Manufacturers shall ensure that procedures are in place to keep series production in conformity with the requirements of this Regulation. (This is also in para 32 of the preamble). By definition, a custom made device is not "Series Production", they are one-offs.
When I look at conformity assessment procedures, the procedure for Custom Made Devices (Annex XIII) makes no mention of having a QMS. in contrast, the first line of Annex IX starts "The manufacturer shall establish, document and implement a quality management system as described in Article 10(9)".
That was my thinking, however, having read through a few times, I am not so sure and would welcome others to comment. My opinion could easily be changed.
twanmul
You're referring to the health institution exemption requirements within Article 5(5). The MHRA (I'm assuming you're in the UK) went out to consultation with this draft guidance last year here. Unfortunately there hasn't been a follow up issued to this draft guidance. Further to this, the sections on QMS and on custom made devices may not be helpful for your specific information but hopefully does give you a starter.
What is required for medical device manufacturers isn't by definition needed for exemption:
With the exception of the relevant general safety and performance requirements set out in Annex I, the requirements of this Regulation shall not apply to devices, manufactured and used only within health institutions established in the Union, provided that all of the following conditions are met...
As such, you can ignore the requirements of Article 10 providing you can meet the conditions of exemption (one of which is the appropriate QMS). It may be that you need to undertake a gap analysis of your existing QMS against those suggested within the draft guidance published by the MHRA.
D What is the acceptance criteria/requirement for Stability Study? General Measurement Device and Calibration Topics 2
L Water requirement for Non-sterile topical OTCs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
Y 510k requirement for bringing in gloves Medical Device and FDA Regulations and Standards News 0
S PSUR - MDR First Submission Requirement? EU Medical Device Regulations 2
J When PPAPs are not a contractual requirement APQP and PPAP 9
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Clinical Trial Requirement - No equivalent devices in the market CE Marking (Conformité Européene) / CB Scheme 3
J Requirement for Retention of Records of Withdrawn Documents of External Origin Document Control Systems, Procedures, Forms and Templates 3
T ISO 17025: Lockout/Tagout Requirement ISO 17025 related Discussions 1
A The requirement of the PMS plan--suitable indicators and threshold values EU Medical Device Regulations 0
S Battery powered device - electrical protection requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
K Regulatory requirement of SaMD with machine learning component IEC 62304 - Medical Device Software Life Cycle Processes 3
A ASL requirement when the supplier is certified for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
P Regulatory or registration requirement for disinfectant in ASEAN Registrars and Notified Bodies 1
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
D ISO 14971:2019 vs MDR Annex 1, Requirement #4 - "Manufacturers shall inform users of any residual risks" ISO 14971 - Medical Device Risk Management 5
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
J 21 CFR 821 Medical Device Tracking Requirement 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Is Device Tracking Card an actual requirement under FDA regulation? Other US Medical Device Regulations 0
W Misinterpretation of requirement acceptable as root cause? Problem Solving, Root Cause Fault and Failure Analysis 19
S ECG Cable Banana to Snap or Tab electrode Adapters -- ISO 10993 Requirement Other Medical Device Related Standards 0
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
L Stage 2 audit - Requirement for 3 months of records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Risk Number for each software requirement IEC 62304 - Medical Device Software Life Cycle Processes 7
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
I Laboratory Fridge / Freezer Inventory - Requirement(s) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Several sections of traditional 510(K) have the same or similar requirement of content. US Food and Drug Administration (FDA) 4
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
Q User Requirement Specification for HR (Human Resource Management System) Manufacturing and Related Processes 1
P Obstruction alarm requirement ISO 80601-2-12 Other Medical Device Related Standards 1
P Electrosurgical Device User Need: Cord Flexibility -> Requirement Other Medical Device and Orthopedic Related Topics 4
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
C ISO 13485 Requirement in Australia/NZ for class 1? ISO 13485:2016 - Medical Device Quality Management Systems 1
N Label Placement Requirement in MDD/MDR EU Medical Device Regulations 1
adir88 MDR requirement: Risk Management Plan for "each device" ISO 14971 - Medical Device Risk Management 5
S Article 61 - MDR Clinical Investigation Requirement EU Medical Device Regulations 5
V 3 PQ lots mentioned as requirement in PPAP. Is this necessary? APQP and PPAP 2
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
F AS9100D, raw material standards are a requirement for manufacturing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Clinical Evaluation - Is this an ISO 13485:2016 requirement? ISO 13485:2016 - Medical Device Quality Management Systems 4
S ISO17020 - Equipment calibration requirement General Measurement Device and Calibration Topics 3
A ISO 17025 Requirement 6.2 - Department Manager Testing Qualifications ISO 17025 related Discussions 1
