Requirement to write a Detailed Inspection Plan (DIP)
L
lorenambrose
Hey All,
I am starting a new project and we are implementing APQP / PPAP for the first time. We have a requirement to write a Detailed Inspection Plan (DIP). This sounds exactly like a FAI which we perform IAW AS9102 already.
I am lost as to the value of the DIP mostly because I do not understand the purpose. Am I being to required to inspect EVERY characteristic for EVERY build? 100% of 100%? That seems like a real show stopper for production. Is this a one time thing?
Can someone help explain when this DIP is performed and how often. How does a DIP differ from an FAI?
In case it helps we make avionic equipment in plain black sheet metal boxes.
Thanks,
LMA
K
kgott
Hey All,
Thanks,
LMA
I would like to help but IDNKWATAM :confused::)
BrownCity
It doesn't look like you received the answer you were looking for.
A DIP must be completed each time you run the part. If you run a lot of say 100 parts, you are required to inspect that lot. The inspection is usually done on a sample basis, not 100% of the parts.
You already comply with AS9102, so you should have a Sample Plan work instruction. If you don't, let me know and I will look to see if I have a copy of an old one.
Harold
WCHorn
Rubber, Too Glamorous?
In my experience, the Detailed Inspection Plan (DIP) was created by Honeywell Aerospace. It serves as evidence of final inspection acceptance. You use a bubbled drawing and put all the characteristics on the DIP, the sampling plan used, the requirements and the results. You may have attachments such as material certifications.
An AS9102 First Article Inspection Report (FAIR) is required for events as shown in AS9102. The DIP is a subset of the FAIR (similar to Page 3 of the FAIR). A FAIR is completed and submitted to the customer for their approval of a new or revised part (or part made using a revised process). The DIP is completed for each production lot.
The sampling plan is cited by the customer's requirements. If those requirements include critical characteristics that must be inspected on every piece, then you are required to report the results on the DIP.
If this was flowed down from Honeywell to you, you can get a thorough explanation on Honeywell Aerospace's portal on the Internet. You need a username and password to access it. If your customer has just adopted the form from Honeywell, then any questions you have should be directed to them.
L
lorenambrose
Your reply is a big help as it does shed light on it.
K ISO 22000 requirement to write a Food Safety Manual Food Safety - ISO 22000, HACCP (21 CFR 120) 2
Ed Panek Does this FDA Requirement Apply to international (not USA) distributors for USA based manufacturing companies? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
A MDR requirement where unit of use packaging is too small for UDI carrier EU Medical Device Regulations 1
C Requirement for Revision of Standard in all Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K ROHs compliance requirement REACH and RoHS Conversations 1
E Language requirement DoC EU Medical Device Regulations 3
I QMS monitoring, measurement, analysis and evaluation requirement - Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Requirement for Signature on Document Document Control Systems, Procedures, Forms and Templates 10
L Water requirement for Non-sterile topical OTCs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
Y 510k requirement for bringing in gloves Medical Device and FDA Regulations and Standards News 0
S PSUR - MDR First Submission Requirement? EU Medical Device Regulations 2
J When PPAPs are not a contractual requirement APQP and PPAP 9
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Clinical Trial Requirement - No equivalent devices in the market CE Marking (Conformité Européene) / CB Scheme 3
J Requirement for Retention of Records of Withdrawn Documents of External Origin Document Control Systems, Procedures, Forms and Templates 3
T ISO 17025: Lockout/Tagout Requirement ISO 17025 related Discussions 1
A The requirement of the PMS plan--suitable indicators and threshold values EU Medical Device Regulations 0
S Battery powered device - electrical protection requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
K Regulatory requirement of SaMD with machine learning component IEC 62304 - Medical Device Software Life Cycle Processes 3
A ASL requirement when the supplier is certified for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
P Regulatory or registration requirement for disinfectant in ASEAN Registrars and Notified Bodies 1
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
D ISO 14971:2019 vs MDR Annex 1, Requirement #4 - "Manufacturers shall inform users of any residual risks" ISO 14971 - Medical Device Risk Management 5
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
J 21 CFR 821 Medical Device Tracking Requirement 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Is Device Tracking Card an actual requirement under FDA regulation? Other US Medical Device Regulations 0
W Misinterpretation of requirement acceptable as root cause? Problem Solving, Root Cause Fault and Failure Analysis 19
S ECG Cable Banana to Snap or Tab electrode Adapters -- ISO 10993 Requirement Other Medical Device Related Standards 0
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
L Stage 2 audit - Requirement for 3 months of records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Requirement to manufacture under a quality management system EU Medical Device Regulations 4
A Risk Number for each software requirement IEC 62304 - Medical Device Software Life Cycle Processes 7
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
I Laboratory Fridge / Freezer Inventory - Requirement(s) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Several sections of traditional 510(K) have the same or similar requirement of content. US Food and Drug Administration (FDA) 4
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
Q User Requirement Specification for HR (Human Resource Management System) Manufacturing and Related Processes 1
P Obstruction alarm requirement ISO 80601-2-12 Other Medical Device Related Standards 2
P Electrosurgical Device User Need: Cord Flexibility -> Requirement Other Medical Device and Orthopedic Related Topics 4
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
C ISO 13485 Requirement in Australia/NZ for class 1? ISO 13485:2016 - Medical Device Quality Management Systems 1
N Label Placement Requirement in MDD/MDR EU Medical Device Regulations 3
