Requirements for distribution of Class I and Class IIa CE Marked Medical Devices
E
Embryo
The elsmar Cove forums are a great source of information, but I have not found the answer to this question (yet) so here goes...
I am working at a company that produces class I and class IIa medical devices (CE-marked, 510(k) cleared etc.). Currently we sell only our "own" products, we are not a distributor or contract manucaturer.
The users of the class IIa devices are (according to the User Manual)required to regularly validate the performance of the device before using it. We regularly service the devices (at the location where they were installed), using (calibrated) equipment that we have found adequate for the task. However, our customers are not so proficient in using the said equipment required for validating the performance of the device and would like another method for validating the performance.
We have now found a possible solution to the above issue. However, this suggestion involves using a (single use) medical device (not manufatured by us, we have no relation whatsoever with the manufacturer). Now here comes the question...
What are the concequences for and requirements on us, if we were to (re)sell a medical device, manufactured by another company? Please note that we, not in any way intend to modify the medical device and/or repackage or relabel it (we buy a box from the manufacturer and send it to our customers, as "simple" as that). Our intention is to make it more convenient for our customers, enabling them to buy our medical device from us and in addition, at the same time, another medical device (not manufactured by us) that they may use to validate the performance of our device, releaving them of the extra effort connected with buying the other medical device from another company.
Are there any requirements at all (if we sell medical devices manufactured by other companies) on us, if we no dot alter it and only sell it on markets where it is already available?
The idea is that we purchase a number of (single use) medical devices from a lot, test this lot together with our medical device, and if we are satisfied with the result, make the remaining medical devices that we purchased, of this lot, available to our customers for purchase.
Any thoughts on the above is much appreciated!
Best Regards
Ronen E
Problem Solver
Moderator
Best Regards
Regarding on-sale of non-modified medical devices manufactured by others (and only this aspect) - the requirements that apply to you are those applicable to medical devices distributors, full stop. Since you didn't specify the target market it's a bit difficult to be more specific.
Regarding the use of these devices for validating your own devices' performance, and the entire set-up you described - it's a new method, and as such it should be validated in itself, i.e. it must be well-substantiated that this method will consistently produce acceptable end-results, that is - your customers will always (including worst-case scenarios) get reliable results when they validate your device's performance through this method. This method validation should (among other factors) address the initial lot qualification you conduct, as well as account for the purchased validating device's inherent variability under worst-case circumstances, and - unless you have a written agreement with the manufacturer to address that - the possibility of un-notified associated change implemented by the manufacturer.
Cheers,
Ronen.
E
Embryo
Hi again,
Many thanks for the valuable feedback.
The issue has taken a new twist…:
What about changing the intended use of a medical device so that it is no longer considered a medical device? From what I can see, the new intended use (developed by our R&D department) results in that the medical device neither can be considered a medical device nor an accessory to a medical device.
Instinctively, it feels wrong to sell a product to a customer saying that you can/may use this product for this purpose, when this is not the same as on the label of the product. Or as R&D put it, if the medical device has intended use X, the new intended use Y is not in conflict with X; it may be considered as a subset/possible use considering the original intended use. Be that as it may, I feel uncomfortable reselling a product with a label that has not changed, i.e. with any text related to our suggested intended use.
How about selling medical devices as a non-medical device? What are the possibilities? Are there any possibilities, or is a medical device always a medical device, regardless of what you call it (If it looks like a duck, swims like a duck, and quacks like a duck, then it probably is a duck…)?
I follow the distributor requirement, but is this also valid if you sell it as something else (i.e. a product that you have determined to not be a medical device, considering the new intended use), and is it at all possible to sell a product as not being a medical device when it has a label (from the original manufacturer) with name, lot nr, exp. date, description, symbols (including the triangle with an “!”) and CE-mark. All of the information on the original label of course still applies (since we do not change the product); could you possibly argue that, for example information related to the manufacturer, is not relevant since it is no longer considered a medical device (by our company, if we resell it with another intended use in mind).
Ronen E
Problem Solver
Moderator
Hi again,
You could go down this side road (it's definitely not the highway), but you'd have to follow through with all the consequences. In my opinion the minimum would be relabelling, i.e. removing the original labelling (created under a medical device regulation-set) and applying your own, complying with any applicable rules and regulations for a product not considered a medical device. Further, because the device itself does not change (it's still a duck :)) you'd have to place ample indications (or warnings) that it's use at a "..." (whatever it initially was) is excluded. Better still, I would change it in a way that would preferably prevent (or at least make unlikely) its use as a medical device - make it a lame duck... I realise this may spoil the party, but I think if you don't do it, its use as a medical device (original intent) would be considered a foreseeable, probable misuse, even with the absence of the original labelling, and as such you'd be expected to address it to the regulator's satisfaction.
In short - you probably can do it but it's not that simple.
Cheers,
Ronen.
L MD State License Requirements for Medical Device Distribution Other US Medical Device Regulations 2
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 0
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J WAIVED ON Q1 - We Don't have to comply with FORDS customer specific requirements IATF 16949 - Automotive Quality Systems Standard 2
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
P Requirements for being an European Representative EU Medical Device Regulations 3
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
lanley liao How to understand correctly the requirements of API monogram products Oil and Gas Industry Standards and Regulations 0
A GPS Regulatory requirements? Manufacturing and Related Processes 6
J SSQR-01 Vision Requirements- Color Blindness AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
R Weld Penetration Standards and Requirements Manufacturing and Related Processes 2
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 0
L Requirements for Cables used for Low-Voltage DC Mains (12-36VDC) IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M AS9100D Registrar pre-audit requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
D LiPo battery minimum requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
V MDSAP Requirements for Device Designer Canada Medical Device Regulations 1
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
Le Chiffre Online training available for ISO/IEC 17021-1: Requirements for bodies providing audit and certification of management systems Training - Internal, External, Online and Distance Learning 3
S What are the International Forging Requirements for Nitrogen Strengthened Stainless Steel? EU Medical Device Regulations 3
R Components to a finished medical device, MDR requirements Other US Medical Device Regulations 1
S Distributor requirements in US 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K AS9100D 8.2.1 Review Requirements for Products and Services AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
F Environmental Requirements E-Lab General Measurement Device and Calibration Topics 0
T 21 CFR 820.20 - Quality Planning Requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Composites - Freezer sensor requirements Manufacturing and Related Processes 2
A Requirements for Contract Manufacturers Other Medical Device and Orthopedic Related Topics 3
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
M IEC 61010-1 requirements for motors Other Medical Device Related Standards 0
J Requirements for registering Alcohol Wipes (70% IPA) in Canada Medical Device and FDA Regulations and Standards News 4
Ed Panek IFU Contact Requirements - FDA and MDD/MDR US Food and Drug Administration (FDA) 1
N German National Requirements - Safety Officer/Authorised Rep Other Medical Device Regulations World-Wide 0
S Traceability of requirements to design and risk Design and Development of Products and Processes 3
F USB powered handheld medical device - Isolation requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Class I (exempt) testing requirements Other Medical Device Related Standards 0
J Saudi Arabia Technical File Requirements Other Medical Device Regulations World-Wide 1
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Test requirements for marketing in US when RATED values are not of US IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A Registration requirements for custom branded device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
A User interface Language Requirements - EU MDR EU Medical Device Regulations 1
A Which guidance do you use for guiding the requirements of IFU for 510(k) submission? Medical Device and FDA Regulations and Standards News 5
O IATF 16949 News Ford Motors Customer Specific Requirements Update - Nov 2020 IATF 16949 - Automotive Quality Systems Standard 5
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
