Requirements for Process Chemical Storage in a Warehouse
Randy
#11
I think you are referring to a record. OSHA requires retention of MSDS 30 years after the last use of the chemical at the facility. So that once the chemical is not used there, the MSDS is retained as a record of the type of chemical used at the facility.
No I'm not, I'm talking about the MSDS itself. Unless there has been a change in the chemical or something else an MSDS 30 years old can be valid and in date.
H
HSSE Auditor
#12
An MSDS is good for infinite years as long as, as you say, there is no change in the chemical. Once the chemical is changed or not used anymore, the MSDS becomes a record and is required by OSHA to be kept for 30 years as a record of us of the chemical use at the facility..
#13
Although I'm not sure that the distinction is really germane to the discussion, I think the HSSE's point was that an MSDS for a substance in current use has a different system status from one that's maintained (under the rules) after a substance is no longer used. The information in the MSDS might be "current" 100 years after it's issued, but it might not have the same "right to know" status as one for a currrently used substance. Or something like that. :D
Ajit Basrur
#14
According to http://www.ilpi.com/msds/osha/I19871001.html ,employers may discard a material safety data sheet for a mixture, if the new data sheet includes the same hazardous chemicals as the original formulation. If the formulation is different then the employer must maintain both data sheets for at least 30 years. OSHA standard, 29 CFR 1910.1020, Access to employee Exposure and Medical Records defines "employee exposure records" to include material safety data sheets. The standard requires all employee exposure records to be maintained for at least 30 years.
An alternative to keeping both data sheets, however, is provided for in 29 CFR 1910.1020. Under paragraph (d)(1)(ii)(B) of this standard employers may discard material safety data sheets if some record identifying the substances used, where it was used and when it was used is retained for at least 30 years. Therefore, an employer may discard the original data sheet and retain only the new data sheet if a record on the original formulation is maintained.
Bill Pflanz
#15
MSDS has been around for a long time now and most chemicals have been around a long time also. Although new information can be discovered about chemical safety, they do not change much anymore and probably not in a significant way. The only issue could be a new chemical not previously available for industrial use but its use would include sending of an MSDS.
Regardless, the original question was how the chemicals should be stored in a warehouse. Except for some flammable and explosive warnings, the MSDS would generally not address the storage of a specific chemical with other chemicals. There have already been suggestions on fire prevention, leaking containers etc. which are good business practices in handling chemicals. I would bet you are using basic commodity chemicals and their handling requirements are well known. Since it does not sound like there are many chemicals in question and you have probably been safely handling them, the only additional precaution that could be made is to contact the suppliers and ask some questions. Don't be surprised if the suppliers provide only common sense instructions.
Bill Pflanz
BS Chemical Engineering
Randy
#16
Whatever...this should have been an up-front and not after-the-fact exercise anyway.
Randy Daily
BS Occupational Health & Safety
Certified Utility Safety Administrator
#17
MSDS is not a "static" document; it is dynamic for quite a few substances. As more and more information becomes available they get added to the MSDS. One of the major points that I always check is the TLV (or an equivalent National standard like MAC..values vary from country to country in quite a few cases)- at least I have seen the TLV (TWA) values changing for trichloroethylene, mercury etc., in the last twenty years. Another case in point is CFCs (Ozone depletion..disposal aspects). If one is maintaining an ISO-14001, I would suggest a review of the MSDS relevant to the organization at least once a year (one can, then, be ahead of legislation with respect to issues arising out of theses substances). No doubt, most of the times one would not add any new data to the MSDS. But to ensure that there has been no change in the data (or identifying a change well in advance) is an aspect of risk reduction covered under ISO-14001 (or any other appropriate management system).
Ramakrishnan
clara
#18
Apart from the good reference thread provided above, you may want to look at some good practices such as - ventilation, possibility of chemicals reacting with each other, etc upon spilling.
Therefore, you need to note that not all chemicals can simply be stored together. There has to be some systems such as separate area for incompatible chemicals, between liquid and other forms such as powder.
Hi everybody,
Thank you for your reply.
We are constructing a new warehouse for chemicals.
Please advice me if there are any regulations or requirements for this facility, eg : the thickness of the walls, the material of the door, location of exhaust fans and switches ...
Looking forward to hearing from you soon.
Best regards,
Clara
harry
#19
Hi everybody,
Best regards,
Clara
To the best of my knowledge, there isn't such regulations in my country, unless you are storing highly explosive chemical. Things could be different in other advance countries.
We pretty much follow common sense and use/adapt the relevant EPA (US) documents as guidelines. For chemical that need to be stored in isolation or separately, we compartmentalized part of the storage area. For containment purposes, we play around with floor levels and built bunds where necessary.
This link should give you a general idea (although it's meant for a lab).
Mustang
#20
Hi everybody,
Best regards,
Clara
Clara, A good resource will be your local building department and fire department. They will have any regulations that may apply in your area.
P Managing How PPAP Requirements are Communicated in the Manufacturing Process and to Suppliers APQP and PPAP 5
M Description of the requirements of clause 9.2.2.3 manufacturing process audit- needs your feedback IATF 16949 - Automotive Quality Systems Standard 0
J Requirements for Layered Process Audits including Maintenance, Shipping, Receiving IATF 16949 - Automotive Quality Systems Standard 4
G QMS requirements for legal manufacturer when outsourcing manufacturing process Other Medical Device Regulations World-Wide 25
R Supplier related drawings and verification of process requirements - Source Inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B Machine process sheet requirements for pill bottling operation Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
J Manufacturing Process Auditor Requirements - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 9
I ISO 10993 Biocompatibility Requirements - manufacturing process chemicals Other Medical Device Related Standards 8
qualprod ISO 9001:2015 8.5.1 f - Scope with customer special process requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Sidney Vianna AS9100 News PPAP in the Aerospace Sector - What is it? AS9145 - Requirements for Advanced Product Quality Planning and Production Part Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M IATF 16949 Clause 8.3.5.2 sub-clause (l) - Process maintainability requirements IATF 16949 - Automotive Quality Systems Standard 15
D IATF 16949 Process Measurement and Efficiency Measures Requirements IATF 16949 - Automotive Quality Systems Standard 2
M AS9100D Process Map Requirements - PEAR Forms AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
K AS9100D production process scheduling requirements Internal Auditing 14
Q IATF 16949 Cl 5.1.1.3 - Requirements related to the Process Owner IATF 16949 - Automotive Quality Systems Standard 1
T TS16949 Process Design Requirements IATF 16949 - Automotive Quality Systems Standard 2
S Process Documentation Formatting - Requirements Document Control Systems, Procedures, Forms and Templates 3
M Process Records requirements for TS16949 standard IATF 16949 - Automotive Quality Systems Standard 6
K What are the minimum requirements for Process Validation (Software)? ISO 13485:2016 - Medical Device Quality Management Systems 5
R TS 16949 Process Re-Validation Frequency Requirements IATF 16949 - Automotive Quality Systems Standard 3
L ISO 9001 Operation Process Control Requirements ("Carta de Control de Proceso") ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T "Special Process" Validation Requirements (21 CFR Part 820) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
P Customer Validated Special Process Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
G ISO 14001 & Product Design Process Environmental Aspect Review Requirements ISO 14001:2015 Specific Discussions 7
Q PEAR (Process Effectiveness Assessment Report) Requirements for AS9100 Registration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S TS 16949 Outside Process Control Requirements IATF 16949 - Automotive Quality Systems Standard 3
R Process Development Requirements for a Contract Manufacturer with no Design Design and Development of Products and Processes 5
J Process Changes - Customer Notification Requirements APQP and PPAP 12
Raffy Process Requirements vs. Process Performance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
P MSA requirements for Systems that Measure Process Parameters Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D 21 CFR 820.80 In-Process Acceptance Criteria requirements for IVDs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J PPAP (Production Part Approval Process) Requirements for Annual Revalidations APQP and PPAP 1
J CQI-9 Table E, 4.1 - Heat Treating Process Requirements Other ISO and International Standards and European Regulations 2
D Can we have one Key Process? AS 9100c Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
V Plating Supplier PPAP Revalidation Requirements - A-Coat GM 9984132 Plating Process APQP and PPAP 1
G AS9100 Clause 7.5.1.1 Production Process Verification Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
R Specific Special Process requirements in TS 16949 for MIG Welding IATF 16949 - Automotive Quality Systems Standard 1
J Assembly Traveler Process Information Requirements Manufacturing and Related Processes 3
X General Motors' initial process study requirements APQP and PPAP 1
M ISO 17025 and Design/Process Control Requirements ISO 17025 related Discussions 2
B AS9100 Process Sampling Plan Basics and Requirements Document Control Systems, Procedures, Forms and Templates 3
K Supplier Performance and Supplier Rating Process - AS9100 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
P Approved Suppliers - ISO 13485 Normal Supplier Qualification Process Requirements ISO 13485:2016 - Medical Device Quality Management Systems 9
L Request for Quote - Process and Requirements IATF 16949 - Automotive Quality Systems Standard 2
M CSR (Customer Specific Requirements) linkage to IQA process IATF 16949 - Automotive Quality Systems Standard 6
Q TS 16949 Process Capability Requirements - Cpk ≥ 1.67 on All Key Parameters? IATF 16949 - Automotive Quality Systems Standard 8
S No Process Defined to Capture the Special Requirements of Customers Problem Solving, Root Cause Fault and Failure Analysis 10
Q ISO 13485, ISO 9001 QMS and FDA Requirements - Process vs. Compliance Approach? ISO 13485:2016 - Medical Device Quality Management Systems 4
D Verification Requirements in a Machining Process Qualification and Validation (including 21 CFR Part 11) 6
Q Supplier Special Process System Assessments - CSR Requirements Customer and Company Specific Requirements 2
