Requirements under OHSAS 18001 for the Control of Risks
O
OzDave
Hi there good folk. This site is a trully amazing site, so many people sharing their knowledge and experience - great to see.
I've trolled through the site trying to find an answer to what is probably a pretty simple question about 18001.
Clause 4.3.1 requires the identification of hazards, assessment of risks and determination of controls.
Clause 4.4.6 require the identification of operational controls.
As both of these clauses require the identification of controls, what's the difference between them (assuming there is a difference)?
Dave
Jen Kirley
Quality and Auditing Expert
Re: Requirements under 18001 for the control of risks
Welcome to the Cove! :bigwave: You are among friends.
In the simplest of terms, 4.3.1 asks us to identify the hazards, and 4.4.6 asks us to define the controls to address the risks we identified as per 4.3.1.
Does this help?
O
OzDave
Thanks Jennifer, I could understand the requirements if the standard said what you have suggested. Where I'm having some difficulty is that 4.3.1 doesn't just require the identification of hazards it also requires risk assessment and, more importantly to me at the moment, risk controls to be identified which appears to duplicate the requirements of 4.4.6.
The way I can rationalise it inside my own confused mind is that 4.3.1 requires the need for a control and the nature of the control (based on the hierarchy of controls) to be identified and 4.4.6 requires the details of the controls to be specified. Does that make sense to anyone else and would that be a correct interpretation of the standard?
Randy
You've stumbled across why it is called a "System", one element helps to meet the requirments of another and or others
There is nothing confusing here...Identify hazards, determine risks associated with them, develop controls to manage the risks...
In the good old US of A quite a bit has already been done for ya by OSHA and it's free. Examples:
Use chemicals in the workplace?...Hazcom Program - 29CFR1910.1200
Hazardous waste handling?....Hazwoper - 29CFR 1910.120
Forklifts?.....Powered Industrial Trucks - 29CFR1910.170
so on and so forth....
Just follow the yellow brick road or this link..http://www.osha.gov/law-regs.html
The OSHA regs will tell you exactly what needs to be in your "controls" and OSHA even provides downloadable "controls" that you can freely adapt to your use
Nothing mystical here or complicated until you get a bunch of non-safety professionals providing advice
somashekar
Yaa....4.3.1 is your planning and 4.4.6 is your implementation and operation of that planning .
You are going in the right order of the PDCA.
O
OzDave
Thanks for the replies.
Somashekar, thanks for the confirmation I am going down the right track.
Randy, you're going to have to try a little harder if condescension is your aim.
Regards
Dave
Paul Simpson
<snip>Randy, you're going to have to try a little harder if condescension is your aim.</snip>
Now, Dave you're just going to have to get used to l'il old Randy. :D His bark is worse than his bite but he just forgets that not everyone recognizes his 'tell it like it is' style and some may find it a bit condescending. :notme:
In his post there were a couple of gems that should help in your investigation.
  • Randy mentioned the fact we are talking about systems. Now this is often difficult to describe in a standard but is totally appropriate when discussing O H & S and how an organization manages its risks.
  • There are lots of interrelationship of elements (clauses) of a standard. So the purpose of going through a process of identifying hazards is to assess risks and identify controls to be implemented through a management system. So 4.3.1 has to link through to Objectives and programmes (4.3.3), Roles and responsibilities (4.4.1), Training needs (4.4.2), Communication (4.4.3), Documentation (4.4.4), Operational Control (4.4.6), Emergency response (4.4.7) etc.
  • This results in a little duplication across the standard but reduced risks of people missing key requirements if they focus just on operational control (for example)
Hope this helps. :)
O
OzDave
Thanks Paul, I am no stranger to H&S management systems having developed, implemented, monitored and maintained them in one form or another for more than 25 years. This, however, is the first time I have used the 2007 version of 18001 and I struggled and am still struggling with the duplication of requirements across different clauses and particularly those described in the initial post.
So just to clarify, I know what a HSMS is, how to develop one, how to integrate one, how to maintain one. I know how performance standards work having used a number of them. I am just a little confused over some asepects of this one (18001) because of the duplicated requirements.
Regards
Dave
Randy
Regards
Dave
Didn't really change from the 1999 revision or BS 8800 for that matter
Within your Australian regs you'll find stuff just like our OSHA (even better in some cases)
Didn't realize you weren't from the states... My Aussie mates from the '69-71 era were laid back
P MDR Reporting Requirements for Devices Already covered in a correction under 21 CFR 806 US Food and Drug Administration (FDA) 0
J Bioburden requirements for Procedure Packs under Article 22? EU Medical Device Regulations 3
D Direct-Marking Requirements under MDR 2017/745 EU Medical Device Regulations 3
C Requirements for distributors under MDR: translation EU Medical Device Regulations 0
JoCam Software Translation under MDR requirements EU Medical Device Regulations 11
D CE Marking Requirements MDD & MDR - new product development covered under same scope EU Medical Device Regulations 1
L Label Content Requirements under MDR regulation EU Medical Device Regulations 5
J UDI Requirements - Products that all fall under the same family 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T Oversight of Distributors - Supply chain requirements under the MDR EU Medical Device Regulations 9
S CE Marking requirements - A Medical device with different config sold under same name EU Medical Device Regulations 0
Y Liability Insurance Requirements under the MDR - p. 15 (item 31) EU Medical Device Regulations 1
I Requirements for shipping items that fall under the Cartagena Protocol Various Other Specifications, Standards, and related Requirements 4
F Traceability Requirements for Computer Hardware Equipment under ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 2
A Do we need to the requirements listed under the heading NOTE General Measurement Device and Calibration Topics 4
M Definition Contingency Plan - What is the meaning under ISO/TS requirements Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 17
T How to implement Customer Requirements into your QMS under TS IATF 16949 - Automotive Quality Systems Standard 1
B Calibration 'Requirements' under ISO? Design and Development Laboratory M&TE Design and Development of Products and Processes 10
R Regarding safety requirements of the Lid latch mechanism CE Marking (Conformité Européene) / CB Scheme 1
H CZ - Common Zone requirements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S What is the relation between EU Annex 1 and ISO 14644 requirements? Manufacturing and Related Processes 2
T Clarity on requirements for indirect suppliers per AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J US based company no longer selling in the EU: Clinical Evaluation Report and PMS requirements EU Medical Device Regulations 1
T Mandatory requirements for design verification sample 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
R IVDR software requirements CE Marking (Conformité Européene) / CB Scheme 2
B FDA Requirements for medical device to be used for training purposes only US Food and Drug Administration (FDA) 9
T Clarification on requirements IATF 16949 - Automotive Quality Systems Standard 3
Q ISO 13485 Contract Manufacturer Controls and Quality System Requirements ISO 13485:2016 - Medical Device Quality Management Systems 4
J Document Control Requirements within Oracle System Document Control Systems, Procedures, Forms and Templates 1
G FDA requirements for risk analysis US Food and Drug Administration (FDA) 2
Q IATF / AIAG: Control Plans and CC / SC requirements FMEA and Control Plans 4
LincolnQA AS9100D, Clause 8.4.1.1d - actions to take when external providers do not meet requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
N White Label Vs Private Label Requirements Canada Medical Device Regulations 0
T SaMD labeling requirements - MDR IEC 62304 - Medical Device Software Life Cycle Processes 3
R Licensing Requirements for Third Party Logistics Providers Japan Medical Device Regulations 1
L Meeting training requirements for IATF Manufacturing and Related Processes 4
D Swiss Documentation Requirements for Class 1 Medical Device Other Medical Device Related Standards 0
M Medical Devices Regulations and labelling requirements UAE Other Medical Device Regulations World-Wide 0
J Forging - Cracks requirements Manufacturing and Related Processes 17
O MDR language requirements EU Medical Device Regulations 12
R Does anyone know how ASQ exam requirements are verified? Professional Certifications and Degrees 3
Sidney Vianna Informational Being developed ISO 30201 Human Resource Management System — Requirements Other ISO and International Standards and European Regulations 6
D PRRC requirements EU Medical Device Regulations 6
Q MSA requirements for IATF IATF 16949 - Automotive Quality Systems Standard 12
B AS9100 Certification Audit Accounting for Additional Customer QMS Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
P IEC 60601-2-25 requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
K Device part of combination product certification requirements Medical Device and FDA Regulations and Standards News 3
L "to be treated as APPLIED PART": is shopping in requirements allowed? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
W Incoming Certification Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Ed Panek ISO 13485 Reporting Requirements ISO 13485:2016 - Medical Device Quality Management Systems 4
D 8.3.2.1 Review of the Requirements for Products and Services. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
