AlbertPaglinawan
electrical measurements
I have questions and I would be very glad if anyone will help me in these.
ok, I have a current shunt (50A, 50mV) with a resistance of 1 milli ohm ± 0.01 milli ohm (rated resistance). The actual, based on the calibration certificate is 0.996 milli ohm. I tried to measure the shunt using our DMM with these specs:
accuracy = ±0.024515 milli ohm
readability/resolution = 0.0001 milli ohm
range is 10 ohm
After measuring the shunt, i read 0.0082402 ohms on my DMM.
My set-up is this;
I used 4 banana connectors (23-inch long), wrapped it with copper shielding foil, and then wrapped it still with knitted wire mesh tape (made from nickel-copper alloy). I connected one end to my DMM, then the other end, I shorted to set my zero offset, then connected it to my current shunt. Then I measure. <b>8.24 milli ohms</b>. What went wrong?
<b>note:</b> The certificate said they used 2 multimeters (HP 34401A and HP 3458A) and 1 current shunt (Leeds & Northup 7638). My DMM is Wavetek 1281.
I tried to make this as detailed as possible but if I missed something, please tell me.
another thing, is there another more accurate way of calibrating my shunt?
cheers!
range is 10 ohm
My set-up is this;
cheers!
