Resistance Welder Settings for cold rolled and galvanized steel
K
keithm696 - 2008
Hi All,
Need some help finding a chart or reference to suggested welder settings for cold rolled and galvanized steel. I know there are a ton of variations due to the material(s) being welded but looking for something to get in the ballpark. Any suggestions or ideas of where to look are appreciated in advance. Thanks!
Keith
Al Rosen
Re: Resistance Welder Settings
keithm696 said:
Hi All,
Keith
I'm no expert, but have you looked at either
ISO 18278-1:2004, Resistance welding - Weldability - Part 1: Assessment of weldability for resistance spot, seam and projection welding of metallic materials
or
ISO 14327:2004, Resistance welding - Procedures for determining the weldability lobe for resistance spot, projection and seam welding.
F
fabricator
SAE-AMS-W-6858 has a chart that offers a baseline. Dont remember the page # offhand. The standard is a bit convoluted and lengthy, but I've found the parameters to be a valid starting point.
Keep in mind that nugget size is critical to any RW process but neither the visual verification of a "good" weld nor the actual measurement of the nugget size replace actual destructive pull testing.
H IEC 61010-1 Clause No. 10.5 Resistance to Heat - Sub Clause 10.5.3 Insulating Material CE Marking (Conformité Européene) / CB Scheme 6
E 60950-1 resistance to abnormal heat test Various Other Specifications, Standards, and related Requirements 1
G Resistance to solve Issues Customer Complaints 8
A ISO 11135:2014, B.1.4, BI resistance x product bioburden ISO 13485:2016 - Medical Device Quality Management Systems 6
R Laminate ESD Mats - Low resistance (RTT) readings Manufacturing and Related Processes 6
T Tests IEC 60601-1 - Grounding Resistance, Leakage Current and Dielectric Rigidity in an automated way IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
L Standard platinum resistance thermometers - sources? General Measurement Device and Calibration Topics 2
J IEC 60601-1 Electrical Safety testing - Class 1 ME externally powered - Earth resistance testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Electrical contact resistance testing in MIL-DTL-5541 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V Regarding Corrosion resistance test Manufacturing and Related Processes 9
A Wire Holder for Resistance Measurement of Stranded Aluminum Wire Manufacturing and Related Processes 2
0 How to deal with resistance to GDP Document Control Discipline Document Control Systems, Procedures, Forms and Templates 7
M Kaye Instrument 373 RTD Monitor Resistance Curve General Measurement Device and Calibration Topics 2
L How to deal with resistance from auditee(s) Internal Auditing 20
C Japan Regulations - Resistance of Medical Gloves to Permeation Japan Medical Device Regulations 1
H Resistance Temperature Detectors (RTD) Manufacturer's Specifications General Measurement Device and Calibration Topics 3
M Calculating Coefficients for an RTD (Resistance Temperature Detector) Probe General Measurement Device and Calibration Topics 3
J Resistance to Change as a Master Thesis in Quality Assurance Professional Certifications and Degrees 7
A Contact Resistance issue - Gold plating on PCB Manufacturing and Related Processes 3
D Gage R&R on a Load Cell fixture that tests the resistance of a Headrest Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G OEM resistance to Supplier / PPAP Change APQP and PPAP 5
C Testing for Chemotherapy Drugs Resistance ISO 13485:2016 - Medical Device Quality Management Systems 2
A Resistance Welding Customer Complaints - Cracking and Pitting Root Causes Customer Complaints 4
C Experience with Electronic Resistance Simulation? General Measurement Device and Calibration Topics 2
M Implementation of Quality Circle Proposals? Teams are getting resistance Misc. Quality Assurance and Business Systems Related Topics 1
Jerry Eldred Guildline 9975 DC Comparator Resistance Bridge Manual Needed (Obsolete) General Measurement Device and Calibration Topics 2
M Latest standard for thermocouples & iprt (industrial platinum resistance thermometer) General Measurement Device and Calibration Topics 5
somashekar Optical epoxy for LED having good thermal shock resistance. Manufacturing and Related Processes 2
P Test equipment for resistance welded wire/rebar Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
L Looking for resistance welding FMEA examples FMEA and Control Plans 10
Antonio Vieira PFMEA for Resistance Welding, Winding and Soldering processes FMEA and Control Plans 3
C Resistance Static Testing of Stampings - M.O.ESS.F1B.F185 Various Other Specifications, Standards, and related Requirements 4
S Testing Laboratory For Fire Resistance Test Reliability Analysis - Predictions, Testing and Standards 3
K Resistance welding process - Cold rolled and some zinc plated welding Various Other Specifications, Standards, and related Requirements 2
J Megger Resistance Tester - How would you control for recalibration? Low Use General Measurement Device and Calibration Topics 2
R Seek Corrosion-resistance Data for Galvanized and Galvannealed steel Manufacturing and Related Processes 1
B How have you overcome resistance to quality? Misc. Quality Assurance and Business Systems Related Topics 5
J What is the Effect of Temperature on OHM (resistance) test? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
D Calibration Standard N24: PFM NO 1841 - Ultrasonic Inspection of Resistance Spot Weld Document Control Systems, Procedures, Forms and Templates 1
J Need Help With Electrical Resistance Problem Manufacturing and Related Processes 6
A Resistance (ohm) Electrical Measurements with a DMM - Verify Shunt? General Measurement Device and Calibration Topics 14
R VisualSPC: Anyone else using this software? Resistance from experienced operators Statistical Analysis Tools, Techniques and SPC 14
I Calibration by correlated parameter - Equipment to measure resistance General Measurement Device and Calibration Topics 3
P Manufacturing equipment (e.g.: Dental Welder): medical device or not? US Food and Drug Administration (FDA) 5
L Un-Qualified Welder who Welds Quality Manager and Management Related Issues 6
F Can a certified welder certify other welders? Training - Internal, External, Online and Distance Learning 8
F Welder Recertification to AWS 17.1 Groove Weld AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Approval of an Outside "vendor" (a welder) working in-line at our facility Misc. Quality Assurance and Business Systems Related Topics 3
B Mig Welding WPS (Welding Procedure Specification) and Welder Qualification Procedure Manufacturing and Related Processes 5
Q Welder's Continuity Log example needed Manufacturing and Related Processes 1
