Responsibilities for Record and Document Management, Development and Control
batman1056
Probably a little off target, but I have been managing doc and record controls for a while and developing a corporate standard (QA Officer), recent changes in the organisation with the introduction of sharepoint has changed this.
In your organisation, who are responsible for Record and Document managment and development? and Do you think this should be managed by IT?:bonk:
P
prototyper
Re: Record Controls - Responsibility
The answer is, it depends on your organisation and how well it fits the different functions.
I would imagine that in most organisations document control is managed by QA as they would have a better understanding of what should be a controlled document, revision control, records retention, etc. and would usually have more interaction with the document users. IT would be involved in maintaining the software for the document control, backups, etc.
Marc
Note: There is a difference between documents and records.
batman1056
Re: Responsibilities for Record and Document Managment, Development and Control
I think that is where things are going wrong:
Document Control - IT
Record Control - QA
P
prototyper
Record Control - QA
Who decides what should be a controlled document?
Answer this and you have probably answered who should have responsibility for this area.
qusys
ISO 9001 requires two procedures for this .
From QS point of view Documentation and Records control could be treated as a process with a process owner who has ownership of the objectives and results, these with functional managers of an organization that should be account for compliance in their own areas/depts.
However, the best solution depende on the largeness and the complexity of an organization.
IMHO, if there is the decision of separate the two processes, QA should be responsable to set criteria to manage documentation ( procedures, quality manual, check list, froms, drawing, documents of external origins like technical manual and so on), valid for the entire organization,while IT should set resources to retain records of an organization, based upon the requirements ( internal , external, law and regulatory compliance) as well the schedule and required procedure, which should reflect how the organization acts in this sense.
Generally speaking, I think that if an organization set robust process on Documents and Records control, it will gain so much as ROI in terms of simplification and effectiveness of the processes as well as in cost reduction ( did you ever calculate the cost to mantain data on server, rather than eliminate those ones that are not requestes?) , besides to avoid some findings in the audits.
JaneB
Usually if not mostly it's a distributed responsibility, as it should be, in my opinion. The manager of each department/division/section is responsible for controlling and storage of records & docs in their area. Sure, IT usually gets the responsibility for long term storage (aka archiving) and backups, but I'd hate to see them pick up the responsibility for everything. Different areas create/use/store different docs & records. Make them responsible. Make them keep a watch over docs posted to Sharepoint by their team. Make them ensure that records are identified, stored, kept, protected,etc.
Making IT responsible for everything 'because it's in Sharepoint & that's electronic'? Nope. Bad idea. :nope:
batman1056
Exactly my thoughts - I have a meeting with them later this week, its a corporate issue that needs corporate guidance but departmental management.
P
Peter West
We have recently introduced Sharepoint to our working operations. Although IT are primarily responsible for it's implementation, the design of the system has involved members of staff from all areas. Just as Jane has stated.
There are now sharepoint "champions" who manage the input onto the system for their team/area. IT still are in charge of making sure it runs smoothly and having necessary back ups done, but record and document management falls upon the shoulders of the document owners to ensure correct use through provision of the necessary guidelines.
Subject to the way your company chooses to go with it, I would make clear in the meeting that IT are responsible for the technical side but would not have a clue which of the documents and records were meant for where, why how....etc.
Raffy
Hi
In our end, its the QA Department responsible for the Document Management and Development. the main responsible of IT in our organization is that they are the one responsible in making electronic backups and maintaining the system, since some of our documents are avaliable on line. They continuously monitor the status of our servers and internet.
All Department has their own way in Record Management. Document and Records Control Personnel responsibilty is to safekeep all documents and records related to the organization's process (manufacturing Process).
Raffy :cool:
M Responsibilities of Importers / Distributors - MDR EU Medical Device Regulations 3
E Responsibilities opening new markets outside EU Medical Device and FDA Regulations and Standards News 0
S Study sign off question / responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 3
M Taking over Conflict Minerals responsibilities RoHS, REACH, ELV, IMDS and Restricted Substances 1
D 3 Companies - Medical device parts and substances - Responsibilities EU Medical Device Regulations 4
P Economic operator responsibilities - when the Importer is also Distributor - Article 13 EU Medical Device Regulations 1
Q Relabeler for patent expired product - design control responsibilities? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Z Economic Operators Responsibilities after DOA for legacy MDD devices EU Medical Device Regulations 2
C Quality Manager vs Warranty (service) Manager - Authorities & Responsibilities Customer Complaints 2
D Reorganizing responsibilities between management teams and Employees in them ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N ISO 9001:2015 - 5.3 - The roles and responsibilities matrix rears it's head ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D ISO13485:2016 7.5.6 Process Validation Responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 1
M Contract Manufacturers and MDF Responsibilities, ISO 13485:2016, Clause 4.2.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
W Scope of MRB (Material Review Board) Responsibilities Misc. Quality Assurance and Business Systems Related Topics 5
JoCam Distributors Responsibilities - Medical Device Recalls EU Medical Device Regulations 1
J What are a Taiwanese Medical device subcontractor's legal responsibilities with Taiwan regulations? Other Medical Device Regulations World-Wide 3
S Responsibilities between government owner and private subcontractor of a power plant seeking ISO 9001 certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
N Regulatory Responsibilities of an OEM and Private Label manufacturer Canada Medical Device Regulations 3
M Exemptions, Responsibilities, and Penalties (in Australia) Other Medical Device Regulations World-Wide 3
C Significant Organizational Changes - Documented Responsibilities Document Control Systems, Procedures, Forms and Templates 4
A VW Supplier Product Safety Representative (PSB) Responsibilities and Requirements VDA Standards - Germany's Automotive Standards 4
M Complaint Handling Responsibilities for a Design Partner - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 9
R Outsourced Plating Supplier Responsibilities Service Industry Specific Topics 8
M Quality Board Membership and Responsibilities Quality Manager and Management Related Issues 6
N Roles and Responsibilities with Suppliers for NC Parts Quality Manager and Management Related Issues 5
O Distributors and ISO 13485 - DHF and DMR Responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 7
J How to decide work-stream in scope of Quality - Roles and Responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 1
Jen Kirley Shared responsibilities in Responsible Care 14001 ISO 14001:2015 Specific Discussions 2
M Technical Oversight - Government Shipyard Quality Office Responsibilities Quality Manager and Management Related Issues 10
M Medical Device Private Labeler Responsibilities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A Medical Device Recall Responsibilities between different Company Groups ISO 13485:2016 - Medical Device Quality Management Systems 3
Q QA Manager Responsibilities Career and Occupation Discussions 9
D TS16949 & Design Responsibilities of a Contract Manufacturing Factory IATF 16949 - Automotive Quality Systems Standard 1
M Executive and Supervisor - Responsibilities and Differences Career and Occupation Discussions 3
J Responsibilities, Authorities and Relationships - What does Relationship mean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S R&D Documentation Manager Responsibilities Job Description Career and Occupation Discussions 1
x-files Responsibilities Highlighted on the First Page of a Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Responsibilities of Authorized Representative EU EU Medical Device Regulations 6
X Are defined roles and responsibilities mandatory for ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Escalation Process, Responsibilities and Matrix Document Control Systems, Procedures, Forms and Templates 8
T Dual Reporting Responsibilities in a Company Quality Manager and Management Related Issues 3
A Organisation Structure and Responsibilities - Clarification Misc. Quality Assurance and Business Systems Related Topics 6
J Responsibilities of a distributor in European market EU Medical Device Regulations 10
D MSDS Datasheet Retention Requirements and Responsibilities RoHS, REACH, ELV, IMDS and Restricted Substances 6
L Quality Mgr vs Business Development Admin. - Roles and Responsibilities Misc. Quality Assurance and Business Systems Related Topics 2
T Senior SQE (Supplier Quality Engineer) Specific Roles and Responsibilities Career and Occupation Discussions 5
Q Is an actual document for Roles and Responsibilities necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
E Responsibilities of a QA (Quality Assurance) Inspector Career and Occupation Discussions 5
T Duties and Responsibilities as a Direct Supervisor of a Pregnant Employee Occupational Health & Safety Management Standards 12
J Organization Chart and Job Descriptions - Responsibilities within a Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
