Responsibility Matrix - Showing managers what their Responsibilities are
W
wallyqc
I am having such a hard time showing these managers what thier responsibilities are within the 9000-2000 standard.
Who has an easy to understand matrix?
Wallyqc
RoxaneB
Here goes...
  • Responsibilities....detailed and explicit....are found in our documentation. If they're responsible to ensuring the coffee is made in the morning, it says so in the WI...and how to make the coffee, too, or what their role is (they may be simply responsible for activating the machine).
  • Job descriptions
  • Matrix - I have a matrix that shows all of the clauses/sub-clauses along one axis and all of our processes along the other. Using the letters D (direct), S (somewhat direct) and N (not applicable), I show which processes are impacted by which clauses/sub-clauses and to what degree.
Combine all of that, and it's pretty clear what their responsibilities are. Although, I have to ask...and I apologize if this sounds glib....but don't your managers know what their responsibilities are? And why would this change with ISO 9001:2000? :)
Marc
Back in the early days (ahemmmm), we took implementation clents through 'ISO 9001 training'. I say 'we' because it was very typical in implementations back in the 1990's. At Harley we filed everyone in York through a brief presentation / training about what ISO 9001 was, what it meant to them and how their roles and responsibilities were related. I remember a standard question by an auditor was "What does ISO 9001 mean to you?"
In the matrix I attached, it was how we made managers and such aware of what parts of ISO 9001 'applied' to them, how and why. We expected them to read and understand the sections of the standard that applied to them and be able to explain how their systems met applicable requirements.
This all went beyond just knowing one's responsibilities are within the company (their 'job'). Whether that level of indoctrination was necessary or not is debatable. I also want to remind that this was done during implementations.
P
pthareja
Wow!
My earlier awareness to a responsibility matrix was only in a X-Y format (clause Vs the Personnels). This one uploaded by Marc allows a great exposure to how detailed and well the responsibilities should be defined.
However this matrix was in the old 9001:1994 format, and it now needs to be translated into new standard, and perhaps drawing one's attention to safety and environmental responsibilities. To go into Cove's coveted resources.
p thareja
Re: Responsibility Matrix - Hard time showing managers what their responsibilities ar
if possible i would like to see your sample
along the one axis you mentioned you have all the processes- i assume you must consolidate the process owner
i am assisting a 1st time ISO- they have a complex product/service and the challenge is to consolidate ownership but they are very thin in the management area so i am finding multiple owners for the ISO sections
thank you in advance for your help
Al
Marc
Note that this thread is from 2005 (7 years ago) so you may not receive a response from pthareja. I don't know if a newer one has been uploaded or not.
John Broomfield
Wallyqc
Wallyqc,
Surely the responsibilities of managers come from your organization's management system?
These responsibilities will be much fuller than the minimum requirements specified in ISO 9001:2008.
For example, interviewing manager is responsible for ensuring proposed new hires have the necessary innate abilities. Or, top manager is responsible for providing a management system that helps employees to determine and fulfill customer requirements.
If you look closely enough at the management system that is used to run your organization you will find that most of the responsibilities specified in ISO 9001 are already delegated.
I would work from your current system and then check against the standard. Not the other way around.
John
John
I came to the same conclusion this morning when I complete the Responsibility Matrix
I just went with the current management structure. Based on this structure - a few of the core ISO requirements will have co-ownership/responsibility. What is your opinion of this co-ownership? It occurs in the 3 engineering disciplines (Mechanical/Applications/Controls) ? the organization has no engineering management function. All 3 engineering managers report to the President.
Thank You
Al
John Broomfield
rowley,
Being as all 3 Engineering Managers report to the President, the President is responsible for Engineering.
Co-ownership is problematic in many organizations. It means no one is really in charge of that part of the system.
One way to solve this is to dig into the differences. For example, you may find one manager is responsible for hardware engineering, another is responsible for software engineering and the third is responsible for process engineering.
Good luck,
John
Q ISO Responsibility Matrix in RACI Format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R APQP Responsibility Matrix APQP and PPAP 3
Peter Fraser RACI (Responsible/Accountable/Consulted/Informed) aka Responsibility matrix Process Maps, Process Mapping and Turtle Diagrams 8
R Has anyone developed an internal Ford Q1 responsibility matrix? Customer and Company Specific Requirements 3
RoxaneB Manual Rejected - Unable to find "shall" to support rejection - Responsibility Matrix Miscellaneous Environmental Standards and EMS Related Discussions 50
D ISO/TS Element Responsibility Matrix IATF 16949 - Automotive Quality Systems Standard 4
Q Private Labeler FURLS Responsibility-USA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
V UDI - OEM or OBL / Legal Manufacturer Responsibility CE Marking (Conformité Européene) / CB Scheme 0
T ISO 13485 - 5.5.1 Responsibility and authority - Small Company Independence ISO 13485:2016 - Medical Device Quality Management Systems 13
B Product Safety Responsibility - Job shop such as a machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
D DHF Responsibility after design handover Document Control Systems, Procedures, Forms and Templates 4
L Global distributor vigilance responsibility Medical Device and FDA Regulations and Standards News 14
S Responsibility of intercessor services provider about services's quality ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Main responsibility for Control Plans - creating and maintaining FMEA and Control Plans 15
M EU MDR - UDI requirements and responsibility guidance EU Medical Device Regulations 1
Mr Skeleton PV (Production Validation) test plan responsibility APQP and PPAP 21
S DFMEA when the supplier doesn't have design responsibility APQP and PPAP 15
W Organizational Responsibility for Environmental Compliance of Products REACH and RoHS Conversations 4
T Design responsibility for customized product per customer requirements Design and Development of Products and Processes 4
T Decontamination responsibility on customer complaint investigation Customer Complaints 4
lyobovnik Matters being audited, independence, participation and direct responsibility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
P Responsibility for Design Transfer - OEM vs. CM ISO 13485:2016 - Medical Device Quality Management Systems 6
M Where does our regulatory responsibility end? ISO 13485:2016 - Medical Device Quality Management Systems 11
S Contract Packager or Repackager? And can client assume responsibility? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
Q U.S. Agents - Responsibility for reporting adverse events to the FDA Other US Medical Device Regulations 10
Fender1 Customer specified Item Defect Corrective Action Responsibility Customer Complaints 18
G FAI (First Article Inspection) Responsibility - QC or Engineering? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Manufacturer's responsibility to notify the NB regarding Medical Device End-of-Life CE Marking (Conformité Européene) / CB Scheme 1
sutie What is Ethics Escalation (“Whistle-Blowing”) Policy - Corporate Responsibility IATF 16949 - Automotive Quality Systems Standard 7
A Leadership Responsibility in an ISO 9001:2015 Quality Management System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
W Shared Responsibility Between Spec Provider and Contract Manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
L What is the difference between Objectives and Responsibility ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L Responsibility for Labeling in Multi-Location Group Document Control Systems, Procedures, Forms and Templates 5
JoCam ATEX - Responsibility for a Declaration of Conformity Various Other Specifications, Standards, and related Requirements 7
E Manufacturer Responsibility (vs. User/Customer) for Preventive Maintenance/Repair 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Specification Verification Responsibility AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V VAG Customer Specific Requirements - Product Safety Responsibility Customer and Company Specific Requirements 1
G Application of RASI (Responsibility, Authority, Support, Information) Chart IATF 16949 - Automotive Quality Systems Standard 5
K Hardware and OS Responsibility in FDA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
Kronos147 Customer Request for Corrective Action - Responsibility AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Whose responsibility is it to issue Corrective Action Requests? Internal Auditing 8
D Requirements & Responsibility regarding Fire Foam in an Office Miscellaneous Environmental Standards and EMS Related Discussions 5
O Vendor (Supplier) Responsibility - Re: Quality Audits 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Does "Responsibility" need to be mentioned in the Corrective Actions ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 22
M What is our level of responsibility in the IQ, OQ, PQ processes? ISO 13485:2016 - Medical Device Quality Management Systems 1
Q How to meet Responsibility and Authority (Clause 5.5.1) Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
E Aging/Shelf-Life Testing Responsibility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
H Definition Executive Responsibility - Legal Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
E Post Machining Casting Defects with MIL-STD-2175 Requirements - Responsibility Manufacturing and Related Processes 9
