Retention Period of Dead Time Sheets
Anerol C
Hi to all;
I have been asked about the period of retention for the Dead time sheets; production personnel is recording any type of dead time, this information is collected and charted? Then analized during production meeting.
Any input on period of retention? :thanks:
Anerol C
This can be whatever time you specify. It can be as short as: "Retain until reviewed in production meeting".
For ISO, you should only retain records as long as they serve a useful purpose. This purpose may be to protect you in the event of litigation (such as design verification records), or to provide objective evidence that your QMS meets the requirements of the standard (such as internal audit records), or to comply with a customer requirement (such as inspection records). If the record no longer serves such a purpose, why retain it?
Recording of dead time would be an internal requirement, not an ISO requirement, so once it has served it purpose discard it.
Anerol C
Then, I would say one month of retention, just to wait until the information is analyzed and reviewed; Any way I will check with the manager of that area just to make sure that he is agree.
Thank you!
Wes Bucey
From a business point of view, it might be worthwhile to keep a log or running record for comparison of current with past periods to determine if there can be or has been improvement in reducing dead time due to changes in processes or procedure (conversely, whether there is a worsening.)
I see tracking this set of data as integral to creating a more efficient work process/environment and subsequently reducing dead time as removing one of the prime "wastes" which detract from increased profitability of the organization.
Anerol C
Does any body have a procedure/WI/Flow chart on how to handle dead time? I don't think it is necessary, but I'm being requested to provide this.
SteelMaiden
Anerol, what do you mean "handle dead time"? Are you talking about what the maintenance people are supposed to be doing to get the machinery back up? What production should do with their time when equipment is not running? I'm probably just overthinking your question, but I'm not sure that you don't need to question whomever has asked for this to define their requirements a little further. Does this add value for your company?
Wes Bucey
As I see the situation, "handling" dead time is like handling any process which, upon examination and evaluation, seems to offer an opportunity for increased efficiency and, therefore, increased profitability for the parties concerned.
Dead time can arise from a number of causes, so it is necessary to list the applicable causes and examine each for opportunities to increase efficiency.
Some examples of dead time might include the dead time resulting from
  1. no work available
  2. machine or process changeover from one product to another (big factor in job shops)
  3. unscheduled repair or maintenance
  4. stoppage in flow of materials (supply chain)
  5. absenteeism of operators for critical step in process
  6. strikes or other organized work stoppage
  7. sabotage (subtle - LOTS of reasons for sabotage, ranging from simple mischief to criminal intent (paid by competitors, desire to manipulate stock price, etc.)
A good manager pays attention to dead time, charts it like any other systemic-caused nonconformity, and seeks corrective/preventive solutions.
It might be a good topic for a new thread to discuss each possible "cause and cure" - certainly, many Lean advocates always put dead time in their crosshairs.
SteelMaiden
That makes sense, Wes. I was just brain-locked there thinking that if our folks needed to be told what to do when there was a breakdown, we'd be in trouble. "Fix it!" would be the policy, procedure and work instruction. Funny how a mind fixates on a path sometimes, isn't it?;)
Anerol C
Thanks Wes for your Input.
That's what we want to do, analize what is causing dead time and what actions need to be taken to reduce/eliminate it. Currently we are using a form that needs to be signed by the owner of the process causing the dead time but there is a kind of resistance to sign it off; so that is why I'm asking if you have a flow chart/work instruction to handle dead time.
Thansky
M Retention period of documents and records ISO 13485:2016 - Medical Device Quality Management Systems 1
N ISO 13485 Quality Record Retention Period ISO 13485:2016 - Medical Device Quality Management Systems 4
T MDR - Regarding the “Retention Period” of Documents and Records CE Marking (Conformité Européene) / CB Scheme 6
A Determining Retention Period for Medical Device QMS documents Document Control Systems, Procedures, Forms and Templates 5
x-files Control of Records - Retention Time vs. Retention Period Document Control Systems, Procedures, Forms and Templates 5
R Retention Period requirements for DMFs (Drug Master Files) US Food and Drug Administration (FDA) 4
R Verifying Documents have been removed or destroyed once the Retention Period expires ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
K Retention Period Requirements for all Documents in ISO9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Retention Period for IQA (Internal Audit) Records Internal Auditing 12
S Minimum Record Retention Period for ISO 14001 Records and Data - Quality, Legal and Other Evidence 2
M Confused about Control Plan and PFMEA Retention Period Document Control Systems, Procedures, Forms and Templates 2
D Can we destroy original paper files before retention period if we scan them? Records and Data - Quality, Legal and Other Evidence 17
P ANSI NCSL Z540.1 Calibration Record Retention Period General Measurement Device and Calibration Topics 3
L Customer Requirements related to Retention Documents and Records period Records and Data - Quality, Legal and Other Evidence 1
Ajit Basrur Sample Retention - Quantity, Retention Period, Storage ISO 13485:2016 - Medical Device Quality Management Systems 15
G Bombardier Aerospace Imposes Infinite Record Retention Period Records and Data - Quality, Legal and Other Evidence 2
S 25 Year Retention period - Records of destroyed or discarded controlled documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
E Record Retention - Raw Material (Steel Certs) Records and Data - Quality, Legal and Other Evidence 3
C Retention of QMS Plans and Reports ISO 13485:2016 - Medical Device Quality Management Systems 5
J Requirement for Retention of Records of Withdrawn Documents of External Origin Document Control Systems, Procedures, Forms and Templates 3
P PPAP samples retention time IATF 16949 - Automotive Quality Systems Standard 5
B Retention Samples when Customer Leaves Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
D IATF16949 7.5.3.2.1 Record Retention - Our Product or Customer Product? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
M Defining and Documenting Record Retention CE Marking (Conformité Européene) / CB Scheme 5
Q AS9120B flow down to external providers: Records Retention AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
WEAVER Retention of golden samples for GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
L VDA 1 Documented Information and Retention (new revision 4, August 2018) VDA Standards - Germany's Automotive Standards 0
Gman2 Quality Record Retention (Internal Audits, CA's) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S Mobile app data privacy - Length of record retention in a software app Medical Information Technology, Medical Software and Health Informatics 1
L Pest Control Log Retention Time Frame ISO 13485:2016 - Medical Device Quality Management Systems 5
S Record Retention - How long must a company keep the following records? Records and Data - Quality, Legal and Other Evidence 17
K Our local sterilizer is closing - Record Retention Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Record retention for defunct customers? ISO 13485:2016 - Medical Device Quality Management Systems 11
D Document Retention Policy IATF 16949 - Automotive Quality Systems Standard 5
B Interpretation of Customer Specific Requirements of Continental - Records Retention Customer and Company Specific Requirements 6
T Record Retention Requirements - IATF 16949 Clause 7.5.3.2.1 Records and Data - Quality, Legal and Other Evidence 15
D PMA A&P Document (i.e. Promotional Brochures, Flyers) Retention Requirements Other US Medical Device Regulations 10
J Retention Requirements of Complaint Medical Devices Customer Complaints 2
Pmarszal FDA Global UDI Database: Record Submission Retention Other US Medical Device Regulations 1
WCHorn Flowdown of Aerospace record retention requirements (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
L GMW15920-2010 Records Retention for GM Customer and Company Specific Requirements 3
S Retention time requirement for various for quality records Records and Data - Quality, Legal and Other Evidence 1
V Tie-wrap pull test to verify contact retention Manufacturing and Related Processes 6
P Records Retention and Disposition - ISO 9001:2008 Requirements Records and Data - Quality, Legal and Other Evidence 5
D Production Record Retention Requirements Records and Data - Quality, Legal and Other Evidence 9
V Inactive Gauge Retention Time - PPAP Section 6 Requirements APQP and PPAP 1
D Contact Retention Tools Question General Measurement Device and Calibration Topics 3
C Financial Records Retention Requirements for a Manufacturing Company Records and Data - Quality, Legal and Other Evidence 3
S Retention of Training Records question Training - Internal, External, Online and Distance Learning 2
