Reviewing Effectiveness of Corrective Actions
sathishthantri
#11
A good discussion.
Corrrective actions are actions taken to eliminate the effects of causes.
It may so happen that there are some causes which were missed in the analysis or new causes come in picture (due to changes).
So, RCA changes with new additions, thereby triggering new actions.
Sidney Vianna
Post Responsibly
#12
A good discussion.
I believe that true corrective action eliminates the (root) causes of a problem, not the effects. The analogy is if a patient goes to see a doctor with a severe fever, the doctor has to diagnose the reason for the fever and not simply tell the patient to take cold showers in order to lower his body temperature.
Indeed, many times, there are contributing/multiple causes for a problem. That's why one of the "changes" in the 2008 edition of ISO 9001 is the word causes (plural) under 8.5.2.
The organization shall take action to eliminate the cause causes of nonconformities in order to prevent recurrence.
K
kgott
#13
In my previous organization, we did not typically close the CA until the review was complete, thus negating options (a) and (b). This would usually lead to (d), which was documented on the corrective action paperwork, so that we had the "lifecycle" of the issues, root cause analysis (even if wrong), actions taken, etc. It also showed how long the issue the remained truly open..
This raises the issue of how many opportunities should a CA be given to be proven to be either effective or ineffective?
Obviously; this can depend on factors such as how long it takes for the CA to be put to the test, how long the cycle takes etc but if the CA holds once is that enough to be considered to be effective?
If it holds 10 times but fails again on the 11th time is that a recurrence or is it a new event and is managed with a new CA.
Any thoughts on how to manage this aspect of the CA issue?
qusys
#14
You should investigate root cause of the last one, if it is an outlayer or it is aa sympthom of a new problem, where you should repeat the whole cycle of the corrective action activity.:bigwave:
John Broomfield
#16
John,
You seem to have posted your question twice.
I recommend option d) do something else.
That something else is to delay invoking the corrective action.
Your management system should separate correction from corrective action.
Two examples:
  1. Correct the product nonconformity using your documented procedure for control of nonconforming product (see 8.3).
  2. Correct your nonconforming process using your undocumented procedure for monitoring [and correcting] processes (see 8.2.3).
Invoke corrective action, to stop recurrence by removing the root causes, only after you (or your competent auditor) evaluates the benefit of investing in corrective action.
John
#17
Actually - Optimist 1 posted a correction to today's post by John in an older thread from the same person. teh threads are coincidentally 2 years apart...
normzone
#18
All of the above contains useful advice.
In my experience there are sometimes occasions where it is not possible to accurately assess the effectiveness of the corrective action - there may be issues where you would have to wait for an event pattern to play out again to verify that your precautions put in place were effective.
And if that event pattern only recurs once in a blue moon, or never, you can make reasonable assumptions about the effectiveness of your action but without a test case to verify you are only making assumptions.
Other times it is likely that you'll have a chance to experience the event again in a year or so. How valuable is it to keep the CA open and review it then? To me, that depends on how much resource you have dedicated to monitoring events and linking to open CAs.
Sometimes I will close CAs with the effectiveness noted as apparent, but contingent upon no further recurrences of this issue. We can split hairs all we like, but the value of me (an army of one, small company) maintaining a list of CAs open for years and feverishly monitoring them on the chance that I may find incontrovertible evidence of full effectiveness does not seem like an effective use of resources.
J Reviewing Corrective Action Effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
G Reviewing Process Effectiveness and Efficiency IATF 16949 - Automotive Quality Systems Standard 5
F Process Review - What is the ISO requirement for reviewing SOPs and quality documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K ISO 13485 section 5.3 Quality Policy - No framework for establishing and reviewing quality objectives ISO 13485:2016 - Medical Device Quality Management Systems 2
K Reviewing a supplier's ISO 9001 certificate issued for a future date Registrars and Notified Bodies 10
V Periodic review criteria for reviewing/updating SOPs US Food and Drug Administration (FDA) 1
H Extra checks to do when reviewing the batch records for release of products Records and Data - Quality, Legal and Other Evidence 2
T Process for Reviewing Internal Data Quality Manager and Management Related Issues 1
A Need help with a Kappa Study (MSA) - Reviewing x-ray Images Six Sigma 11
J Cpk & Ppk - Reviewing a PPAP Package - Some questions Statistical Analysis Tools, Techniques and SPC 8
A Reviewing All Incidents for Trends & Opportunities Preventive Action and Continuous Improvement 5
A Audit NC for not collecting/reviewing feedback from Internal Customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
A Reviewing Documents - FDA Time Requirements? Document Control Systems, Procedures, Forms and Templates 1
Douglas E. Purdy What does 8.5.2 & 8.5.3 "reviewing ... action taken" mean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
H Clause 4.2 (d) intent - Framework for setting and reviewing environmental objectives Miscellaneous Environmental Standards and EMS Related Discussions 7
M Reviewing Corrective Action Status for effective Management Review Management Review Meetings and related Processes 5
R Reviewing Documentation in preparation for an Audit General Auditing Discussions 5
Q Errors in the AIAG's SPC manual? Need help reviewing charts. Statistical Analysis Tools, Techniques and SPC 8
Crusader 7.2.1 "Determine Requirements" vs. 7.2.2 "Reviewing Requirements" - Differences? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S ISO/TC 176 SC2 is now reviewing some minor changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K Questions about defining/tracking/reviewing our goals/objectives - 8.4.1 IATF 16949 - Automotive Quality Systems Standard 8
B Reviewing corrective action - How to ensure that root cause analysis is correct Problem Solving, Root Cause Fault and Failure Analysis 5
C Current Receiving Inspection activities - Reviewing, revising and improving Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Methods of Reviewing Calibration Intervals Calibration Frequency (Interval) 2
D Hit for not reviewing System Suitability in Management Review Management Review Meetings and related Processes 6
H Effectiveness and efficiency indicators ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
M ISO14971:2019 - Verification of implementation and effectiveness of risk control ISO 14971 - Medical Device Risk Management 3
C Quality, efficiency and effectiveness of daily work routines Misc. Quality Assurance and Business Systems Related Topics 4
V CAPA effectiveness check Nonconformance and Corrective Action 3
N How to monitor the effectiveness of the CAPA system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
qualprod ISO 9001 5.1.1 - How to measure System effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
qualprod Add new action plans in CA, while waiting effectiveness - Same problem reappears ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C CMDR Essential (Safety & Effectiveness) Requirements Checklist? Canada Medical Device Regulations 9
J AQL for Effectiveness Check - What AQL tiers to use on this type of sampling? Nonconformance and Corrective Action 9
M Medical Device News FDA - Transformative new steps to modernize FDA’s 510(k) program to advance the review of the safety and effectiveness of medical devices Other US Medical Device Regulations 0
S Nonconformance to a Note in ISO13485 clause 6.2 Human Resources Effectiveness ISO 13485:2016 - Medical Device Quality Management Systems 13
J Recall Effectiveness - Accessory to Medical Devices shipped through Distributors Customer Complaints 3
qualprod To Evaluate Effectiveness in All Improvements? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Corrective Action Effectiveness Nonconformance and Corrective Action 5
Uriel Alejandro Evaluation of the effectiveness of correction actions General Auditing Discussions 15
L Verifying training effectiveness for procedure changes ISO 13485:2016 - Medical Device Quality Management Systems 4
T Hot dogs and process operation and control effectiveness? 4.1.3 a) ISO 13485:2016 - Medical Device Quality Management Systems 2
S ISO 9001:2015 4.4.1 (c) Process Effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
M Effectiveness Measuring and Efficiency Measuring In ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A IATF 16949 - Non-conformity on 5.1.1.2 Process effectiveness and efficiency IATF 16949 - Automotive Quality Systems Standard 5
S What are some ways to demonstrate Effectiveness of Training? ISO 13485:2016 - Medical Device Quality Management Systems 29
B IATF 16949 Cl. 7.3.2 - Documented Process (Effectiveness & Efficiency) IATF 16949 - Automotive Quality Systems Standard 7
R Documenting Self-Training and Effectiveness - ISO 13485:2016 Training - Internal, External, Online and Distance Learning 4
