Revision History in an MS Word document
  • Thread starter Polly Pure Bread
  • Start date
P
Polly Pure Bread
I am looking for a sample revision history in an MS Word document. I prefer to document all the changes in a separate document (not in the revised procedure itself). The changes that should reflect in the revision history are the deleted items only. Our QMR wants me to reflect the change as specific as it should be. Meaning if I deleted one word in the first paragraph, deleted two sentences in the second paragraph, and another five scattered words in the third paragraph – all those deleted items should reflect in the revision history.
Added items in a document, on the other hand, need not to reflect because we underlined the exact changes in the procedure itself.
I can't imagine how revision history will look like once so many deleted words or sentences are entered especially the scattered ones.
I would appreciate if anyone could share me a sample revision history.
Thanks in advance.
JaneB
Re: Revision History
Yikes - that's a lot of detail to track! (I hope there's a good reason for doing so)
If you're looking for an example, why not use the one from the latest version of ISO 9001 (Table B1 in the 2008 version) showing the differences?
dsheaffe
I am with Jane on this one - I can't really see any benefit for such an administrative overhead. While I would never recommend this approach - if you are forced down this path, the easiest solution may be to use Words track changes functionality. It will then show exactly what has changed - and you can change the view to see the changes - or hide the changes to just view the final document - or even show what it looked like before the changes were done.
Dave
ab001
Attaching the template of Change History - this is my favorite template :).
i second that. it should only be one or two lines. iff you need to know the exact changes, just compare the two docs.
what about using some kind of task manager to also keep track?
eg outlook tasks
sharepoint workflows
any expensive edms
something cheap like an isssue tracker.
Brunetta
There is a way to do this in MSWord for the level of detail you described.
If you have the old version in Word, and the new version in Word, you can use the merge function and it will show you every single change made. You can even go one step further, and print to Adobe PDF the list of changes. You have to select that from the drop down box when the print pop-up screen shows up.
It only takes a few seconds, but no one finds the information at this level of detail useful in our organization.
We have an executive summary of the changes at the end of the document. Caution though, this only works if the person updating the document remembers to include it in the first place. (It's a discipline thing :whip:)
ddunn
We use a simple format as below. The description field lists the Change Request (CO, ECO, DCO...). The Change Request lists the details of the change and the approvals.
Date Revision Description Author
02/26/09 1.0 CAIP_CodeCR188 T. Couger
baynoli
Hi Im new with ISO, i'm in charge of the documentation system. Just one of the quick observation though. Which is the right word to used in our procedure, "revision no. xx" or "version no. xx". Im confused of this words.
any opinion on this? thanks.
baynoli
harry
baynoli
Welcome to the forum.
Revision is commonly used. Version is more used in soft-wares.
JaneB
Either is absolutely fine.
It's a matter of your preference.
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
M Is There a Revision History or Change Log for Canadian Regulations? Canada Medical Device Regulations 3
C SOP unification. Revision No, Revision history Document Control Systems, Procedures, Forms and Templates 4
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
I Revision History Date - date of updates or date of release? ISO 13485:2016 - Medical Device Quality Management Systems 2
Sam Lazzara Preferred Location for Revision History Section in Documents Document Control Systems, Procedures, Forms and Templates 16
I Document Control - Document Revision History Question Document Control Systems, Procedures, Forms and Templates 16
K Revision History of Quality Manual Missing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
B Revision history for FDA's CFR 21 US Food and Drug Administration (FDA) 1
T 510(k) Revision Level History and Submission Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Advice on moving QMS Documents and Maintaining Revision History Quality Manager and Management Related Issues 9
G Document Revisions - How do I track the Form Revision History/Approvals? Document Control Systems, Procedures, Forms and Templates 5
J Drawing Revision History Question... Signature on EO or ECO Document Control Systems, Procedures, Forms and Templates 18
J Print (Drawing) Document Revision History Identification Indicators Document Control Systems, Procedures, Forms and Templates 5
C Revision History Page on Procedures Back/Front of Doc Document Control Systems, Procedures, Forms and Templates 10
C Revision History Page on Forms Document Control Systems, Procedures, Forms and Templates 3
L Should templates have a revision history? Document Control Systems, Procedures, Forms and Templates 4
D Documenting Revision History - Single ?Revision Record? Document Document Control Systems, Procedures, Forms and Templates 4
T Revision History in a Documentation Database - Necessary? Document Control Systems, Procedures, Forms and Templates 3
R Control of Documents - Change history question - Changes from previous revision OK? Document Control Systems, Procedures, Forms and Templates 11
C Guidelines on record retention of obsoleted calibration procedures (Revision History) Records and Data - Quality, Legal and Other Evidence 9
T Document Control Revision History in Manually Created BOM's (Bill of Materials) Document Control Systems, Procedures, Forms and Templates 6
M Quality Manual Change History - Can I eliminate the revision record from the manual? Quality Management System (QMS) Manuals 33
M Revision History - How Specific? Document Control Systems, Procedures, Forms and Templates 6
M Missing a Revision in a Document's Revision History Document Control Systems, Procedures, Forms and Templates 2
C Requirement for Revision of Standard in all Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Changing revision status of a reviewed document Manufacturing and Related Processes 11
G IATF Rules for COVID 5th revision - Re-certification audit timing IATF 16949 - Automotive Quality Systems Standard 3
B Revision 5 to IATF Coronavirus Pandemic (Covid -19) IATF 16949 - Automotive Quality Systems Standard 0
Q Version/Revision Control of CAD files Document Control Systems, Procedures, Forms and Templates 2
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B New Release of CQI-12 Coatings Process (Revision 3- Release date- 7/2020) Customer and Company Specific Requirements 2
M Gap analysis on ISO 14971:2019 with previous revision ISO 14971 - Medical Device Risk Management 12
J ISO 14001 revision process ISO 14001:2015 Specific Discussions 1
B CQI-11 (Plating Audit) - New revision updates IATF 16949 - Automotive Quality Systems Standard 0
P Proposed revision of IEC 62304 - 2019 IEC 62304 - Medical Device Software Life Cycle Processes 6
I Tracking Protoype Changes; 8D or simple document revision? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A The latest revision number and changes in automotive core tools IATF 16949 - Automotive Quality Systems Standard 1
L Getting Notice of Revision and Accessing Public Draft Copies of ISO Standards Service Industry Specific Topics 2
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
M Informational ISO 14971 / ISO TR 24971 revision update – atualizações sobre a revisão Medical Device and FDA Regulations and Standards News 1
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
L VDA 1 Documented Information and Retention (new revision 4, August 2018) VDA Standards - Germany's Automotive Standards 0
M Informational ISO TC 210 JWG 1 meeting in São Paulo – Revision of ISO 14971 and ISO TR 24971 – Medical Device Risk Management Medical Device and FDA Regulations and Standards News 0
M Revision of a Form which is a Procedure Attachment Document Control Systems, Procedures, Forms and Templates 1
S IMS Manual Review and Revision Prior to Audit ISO 14001:2015 Specific Discussions 4
2 First Article Requirements for Revision Changes of Engineering AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
ScottK Question for Auditors on 7.1.4 in the ISO9001:2015 revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
R Clinical evaluation Meddev (2.7.1 revision 4) - Example or Template EU Medical Device Regulations 4
