Revision level requirements on CNC programs?
K
kcoryell
#11
Engineering Nonconformity: machine programs are not controlled. 4.2.3
This is a copy and paste from my audit report.
K
kcoryell
#13
Hi Paul, This is an exact copy and paste from my Audit report.
Engineering EH-6 Nonconformity: machine programs are not controlled. 4.2.3
K
kcoryell
#14
Here is a copy from my procedure:
Quality documents are identified by the following minimum requirements:
- title
- document number and/or revision number
- and date
For our SOP's and WI's we chose to give them a REV level along with the date. Our forms and programs we just use the document number and date. Blueprints of course are rev level, and technical papers may be either. I could keep on listing, but i am sure you get my jist.
Colin
#16
So, now that the 'brains trust' that is 'The Cove' has delivered its verdict - what will you do next?
I know that you said earlier your top management decided to take all of the NC's but you now have to either challenge the finding and explain that you do have control over the programs or put in a system which you don't need, knowing that this is a classic case of a system for systems sake which will probably fall into disuse because people know it has little value.
K
kcoryell
#17
I was given the job as the Champion for this CAR. The other members of the team are the Operations manager and the programmer. While I was waiting on everyones reply I just went and had a talk with these other two individuals. I believe that we have come to the same conclusion. All we are going to do is update our SOP to actually address CNC programs, not just documents. We have decided that we are controlling these programs, it is our system, we just need to defend it.
Paul Simpson
#19
Poor nonconformity. It should refer to the exact clause 4.2.3 (c) and state the requirement copied from ISO or your own QMS).
Reading between the lines, though she may have a valid NC (albeit v. minor) in that your machine programs may not be controlled in accordance with your documented procedure. :notme:
- title
- and date
So unless your machine programs (in whatever format) have a title, document number and / or revision number and date then a NC exists - even if it has been badly written! :mad:
Trae1170
#20
I agree with what everyone is saying also. Your programs should be controlled but the date you use is fine. ISO does not dictate what you use as a Revision level, you can use a number, a alphabetical letter, a date or any combination thereof.
Thanks,
R Medical Device Label Revision Level Requirements Other Medical Device and Orthopedic Related Topics 24
T 510(k) Revision Level History and Submission Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Referenced Documents Requirements - Pointing to a specific revision level Document Control Systems, Procedures, Forms and Templates 3
Paul Simpson Informational The role of Annex SL - High Level Structure of ISO MSS's - Revision Update February 2019 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
P Is the next revision of ISO 15378 following the High Level Structure? Other ISO and International Standards and European Regulations 5
T Is there a requirement in TS16949 that PO's show a revision level? IATF 16949 - Automotive Quality Systems Standard 3
C Documents sent to Suppliers - Document Revision Level Identification question Document Control Systems, Procedures, Forms and Templates 2
J Check your AS9100 Certificate Date and Revision Level AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
1 Revision Level of Print vs. PPAP Document Control Systems, Procedures, Forms and Templates 4
B Software QA - PROM revision level control - Boy am I out of my league!!! Software Quality Assurance 3
A Is revision level required in the document / form? Document Control Systems, Procedures, Forms and Templates 7
W Standards Updating Service? Current Revision Level of Standards Other ISO and International Standards and European Regulations 11
S Revision Levels on Documents - First Issue Revision Level Document Control Systems, Procedures, Forms and Templates 9
D TS 16949 Control Plan and Part Number Revision Change Level FMEA and Control Plans 1
O AIAG Manual Master List with Current Revision Level IATF 16949 - Automotive Quality Systems Standard 2
T When is a revision level changed on an FMEA? FMEA and Control Plans 1
H Current revision level of GM1927 - GM APQP Manual Customer and Company Specific Requirements 9
Douglas E. Purdy Tooling Procurement - No revision level of the tool on customer PO ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Technical Documentation Records - Customer drawing, Revision Level, PPAP, etc. Document Control Systems, Procedures, Forms and Templates 1
G Catalogue Part - Revision Level, Revision Dates, Design Record APQP and PPAP 5
H Control Plan - "Latest Change Level" vs. Print Revision Level FMEA and Control Plans 16
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
G IATF Rules for COVID 5th revision - Re-certification audit timing IATF 16949 - Automotive Quality Systems Standard 3
B Revision 5 to IATF Coronavirus Pandemic (Covid -19) IATF 16949 - Automotive Quality Systems Standard 0
Q Version/Revision Control of CAD files Document Control Systems, Procedures, Forms and Templates 2
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B New Release of CQI-12 Coatings Process (Revision 3- Release date- 7/2020) Customer and Company Specific Requirements 2
M Gap analysis on ISO 14971:2019 with previous revision ISO 14971 - Medical Device Risk Management 8
M Is There a Revision History or Change Log for Canadian Regulations? Canada Medical Device Regulations 3
C SOP unification. Revision No, Revision history Document Control Systems, Procedures, Forms and Templates 4
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
I Revision History Date - date of updates or date of release? ISO 13485:2016 - Medical Device Quality Management Systems 2
J ISO 14001 revision process ISO 14001:2015 Specific Discussions 1
B CQI-11 (Plating Audit) - New revision updates IATF 16949 - Automotive Quality Systems Standard 0
P Proposed revision of IEC 62304 - 2019 IEC 62304 - Medical Device Software Life Cycle Processes 6
I Tracking Protoype Changes; 8D or simple document revision? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A The latest revision number and changes in automotive core tools IATF 16949 - Automotive Quality Systems Standard 1
L Getting Notice of Revision and Accessing Public Draft Copies of ISO Standards Service Industry Specific Topics 2
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
M Informational ISO 14971 / ISO TR 24971 revision update – atualizações sobre a revisão Medical Device and FDA Regulations and Standards News 1
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
L VDA 1 Documented Information and Retention (new revision 4, August 2018) VDA Standards - Germany's Automotive Standards 0
M Informational ISO TC 210 JWG 1 meeting in São Paulo – Revision of ISO 14971 and ISO TR 24971 – Medical Device Risk Management Medical Device and FDA Regulations and Standards News 0
M Revision of a Form which is a Procedure Attachment Document Control Systems, Procedures, Forms and Templates 1
S IMS Manual Review and Revision Prior to Audit ISO 14001:2015 Specific Discussions 4
2 First Article Requirements for Revision Changes of Engineering AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
ScottK Question for Auditors on 7.1.4 in the ISO9001:2015 revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
R Clinical evaluation Meddev (2.7.1 revision 4) - Example or Template EU Medical Device Regulations 4
