Revision Number vs. Issue Number - Document Control in ISO 17025:2005
Z
Z.chamist
Hi all,
I am working on ISO 17025:2005 in my QAD Lab. Quality Manual, QSP, SOP and forms and formsts are completed. A debate is contnuing between me and my Quality Manager about Revision No and Issue No. Is any diffrence b/w both Terms?
TwoEds
The standard (ISO 17025:2005) requires that each authorized edition of a document has a unique identification. Your choice of name for that unique identifier (issue number, revision number, version number, etc.) is not restricted. If for some reason your identifier has multiple parts, one might be called the issue number and another the revision number. I wouldn't recommend going that route.
Richard Regalado
Hi all,
IMHO it's just semantics.
Bottomline is there should be a form of control to ensure that only the most current version is available for use.
Z
Z.chamist
Dear TwoEds,
Your post is helpfull but you did not define the both terms separately. furthermore Is there any standard our guidline document for Document Control?.
Warm Regards
kedarg6500
we consider Revision No for major revisions in the procedure, like many activities in the procedure are changed or the objectives of the activities are changed significantly,Revision No is changed .
We consider Issue No when minor changes are done in that revision.
When we change Revision No, Issue No will be 00
Hi all,
If you want to clearly identify documents with the same overall content when the are actually different, either term can be used - they mean the same usually. Some organizations split them to mean different things, but that's probably making it a bureaucracy, IMHO!
Sturmkind
I agree with the idea that Revision is a form, fit, or function change while Issue number is for minor changes like rewording for clarity, correction to a mis-spelling, add/deletion of who is copied, etc.
N Documents in different languages - Revision and Issue Number Document Control Systems, Procedures, Forms and Templates 7
A How to differentiate between the issue number & revision Document Control Systems, Procedures, Forms and Templates 19
A The latest revision number and changes in automotive core tools IATF 16949 - Automotive Quality Systems Standard 1
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
Q Change revision number in document when only codification was changed Document Control Systems, Procedures, Forms and Templates 8
drgnrider Pro's & Con's for revision number AND revision date? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
G Document issued with incorrect Revision Number Quality Manager and Management Related Issues 10
V What is the criteria for assigning the new-revision number for an FMEA? FMEA and Control Plans 6
G Revision number when changing over to ISO 9001 edition 2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L Quality Policy - Need to have the revision number on the copy of policy displayed? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
D TS 16949 Control Plan and Part Number Revision Change Level FMEA and Control Plans 1
K ECO (Engineering Change Order) Revision - Letter change or part number change? Manufacturing and Related Processes 13
L New Document Number for Every Revision? Document Control Systems, Procedures, Forms and Templates 16
L ISO 13485:2003 Quality Policy Controlled with a Revision date and number? ISO 13485:2016 - Medical Device Quality Management Systems 5
M Reject Tags - red tag is a form and needs to have a part number and revision? Document Control Systems, Procedures, Forms and Templates 14
A If document coding is change will there be a revision Document Control Systems, Procedures, Forms and Templates 1
R What to do when revision history is too long? Misc. Quality Assurance and Business Systems Related Topics 2
M Periodically verifying revision levels of published standards Other ISO and International Standards and European Regulations 4
S Issue No. & Revision No. Document Control Systems, Procedures, Forms and Templates 4
C Requirement for Revision of Standard in all Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Changing revision status of a reviewed document Manufacturing and Related Processes 12
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
G IATF Rules for COVID 5th revision - Re-certification audit timing IATF 16949 - Automotive Quality Systems Standard 3
B Revision 5 to IATF Coronavirus Pandemic (Covid -19) IATF 16949 - Automotive Quality Systems Standard 0
Q Version/Revision Control of CAD files Document Control Systems, Procedures, Forms and Templates 2
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B New Release of CQI-12 Coatings Process (Revision 3- Release date- 7/2020) Customer and Company Specific Requirements 2
M Gap analysis on ISO 14971:2019 with previous revision ISO 14971 - Medical Device Risk Management 12
M Is There a Revision History or Change Log for Canadian Regulations? Canada Medical Device Regulations 3
C SOP unification. Revision No, Revision history Document Control Systems, Procedures, Forms and Templates 4
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
I Revision History Date - date of updates or date of release? ISO 13485:2016 - Medical Device Quality Management Systems 2
J ISO 14001 revision process ISO 14001:2015 Specific Discussions 1
B CQI-11 (Plating Audit) - New revision updates IATF 16949 - Automotive Quality Systems Standard 0
P Proposed revision of IEC 62304 - 2019 IEC 62304 - Medical Device Software Life Cycle Processes 6
Sidney Vianna Interesting Discussion ISO 9001:2024 - What should be changed in the next Edition of ISO 9001? - REVISION CANCELLED May 2021 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 172
I Tracking Protoype Changes; 8D or simple document revision? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L Getting Notice of Revision and Accessing Public Draft Copies of ISO Standards Service Industry Specific Topics 2
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
M Informational ISO 14971 / ISO TR 24971 revision update – atualizações sobre a revisão Medical Device and FDA Regulations and Standards News 1
L VDA 1 Documented Information and Retention (new revision 4, August 2018) VDA Standards - Germany's Automotive Standards 0
M Informational ISO TC 210 JWG 1 meeting in São Paulo – Revision of ISO 14971 and ISO TR 24971 – Medical Device Risk Management Medical Device and FDA Regulations and Standards News 0
M Revision of a Form which is a Procedure Attachment Document Control Systems, Procedures, Forms and Templates 1
S IMS Manual Review and Revision Prior to Audit ISO 14001:2015 Specific Discussions 4
2 First Article Requirements for Revision Changes of Engineering AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
ScottK Question for Auditors on 7.1.4 in the ISO9001:2015 revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
R Clinical evaluation Meddev (2.7.1 revision 4) - Example or Template EU Medical Device Regulations 4
Paul Simpson Informational The role of Annex SL - High Level Structure of ISO MSS's - Revision Update February 2019 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
T ISO 9004:2018 Revision - Released April 2018 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
