Revision of a Form which is a Procedure Attachment
mitch_chel
Good day!
I am a DCC in a construction firm.
1. When I create a procedure, I fill-up the Document Control Notice then route it for review and approval. I only fill-up Document Control Notice whenever I create or revise a procedure, but I don't fill-up DCN whenever I create or revise a form because forms are attachments to my procedure. My procedure has several forms attached to it, I called it attachments. All my procedure has identification number (Doc. No. DCC-001) and all my forms has identification number (Doc. No. DCC-QF-001) also. Now, I want to revise a form, how do I do it? What form do I need to fill-up to revise a certain form?
2. Is it okay to create a form called Master List of Documents and Forms? That is my master list for all my Procedure (Internal Documents), all my Forms and all External Documents. All in one form. Then I'm going to put a column for Doc. Ref. No., Document Title, Revision No., Effectivity Date as well as retention time (active and inactive records) and its disposal method of the records. And also, can I include the distribution and retrieval in this form?
3. What form do I use to list all the Inactive/Archival records in DCC Archive Room? I have Retention Label Sheet to put in a box but how to determine if a certain records is due for disposal?
4. How to I retrieve a certain form in a department in case there is revision of that form? What form do I use?
5. Do i need Master List of Obsolete Documents/ Forms?
6. How to use Records Retention Matrix and when to use it?
Many thanks.
Marc
Fully vaccinated are you?
Q: Do you have a mature document control system, or are you defining a new one?
1. Your document control system should handle forms.
2. Yes.
3. You design such forms to suit your specific needs.
4. That depends upon how your document control system is designed. Is this electronic or paper? In the "old days" of paper systems, when a department had a paper document or form that was, for what ever reason, not centrally controlled, we required the department to have their own document control procedure which they would follow.
5. You design your document control system. If you don't require such a list, none is necessary.
6. We come back to this: Each company designs their own document control system(s). When you define a record (form), your should determine all requirements for that specific type of record. Some times regulatory requirements set record retention times for specific types of records. Other times legal aspects are part of defining how long a specif record is kept.
Do not over complicate your system. Example of a simple system: https://elsmar.com/pdf_files/Doc_Matrix.pdf
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
G Document Revisions - How do I track the Form Revision History/Approvals? Document Control Systems, Procedures, Forms and Templates 5
J Document Format vs Content Revision - Form changed from MS Word to MS Excel Document Control Systems, Procedures, Forms and Templates 7
A Is revision level required in the document / form? Document Control Systems, Procedures, Forms and Templates 7
M Reject Tags - red tag is a form and needs to have a part number and revision? Document Control Systems, Procedures, Forms and Templates 14
C Requirement for Revision of Standard in all Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Changing revision status of a reviewed document Manufacturing and Related Processes 11
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
G IATF Rules for COVID 5th revision - Re-certification audit timing IATF 16949 - Automotive Quality Systems Standard 3
B Revision 5 to IATF Coronavirus Pandemic (Covid -19) IATF 16949 - Automotive Quality Systems Standard 0
Q Version/Revision Control of CAD files Document Control Systems, Procedures, Forms and Templates 2
B New Release of CQI-12 Coatings Process (Revision 3- Release date- 7/2020) Customer and Company Specific Requirements 2
M Gap analysis on ISO 14971:2019 with previous revision ISO 14971 - Medical Device Risk Management 12
M Is There a Revision History or Change Log for Canadian Regulations? Canada Medical Device Regulations 3
C SOP unification. Revision No, Revision history Document Control Systems, Procedures, Forms and Templates 4
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
I Revision History Date - date of updates or date of release? ISO 13485:2016 - Medical Device Quality Management Systems 2
J ISO 14001 revision process ISO 14001:2015 Specific Discussions 1
B CQI-11 (Plating Audit) - New revision updates IATF 16949 - Automotive Quality Systems Standard 0
P Proposed revision of IEC 62304 - 2019 IEC 62304 - Medical Device Software Life Cycle Processes 6
I Tracking Protoype Changes; 8D or simple document revision? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A The latest revision number and changes in automotive core tools IATF 16949 - Automotive Quality Systems Standard 1
L Getting Notice of Revision and Accessing Public Draft Copies of ISO Standards Service Industry Specific Topics 2
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
M Informational ISO 14971 / ISO TR 24971 revision update – atualizações sobre a revisão Medical Device and FDA Regulations and Standards News 1
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
L VDA 1 Documented Information and Retention (new revision 4, August 2018) VDA Standards - Germany's Automotive Standards 0
M Informational ISO TC 210 JWG 1 meeting in São Paulo – Revision of ISO 14971 and ISO TR 24971 – Medical Device Risk Management Medical Device and FDA Regulations and Standards News 0
S IMS Manual Review and Revision Prior to Audit ISO 14001:2015 Specific Discussions 4
2 First Article Requirements for Revision Changes of Engineering AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
ScottK Question for Auditors on 7.1.4 in the ISO9001:2015 revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
R Clinical evaluation Meddev (2.7.1 revision 4) - Example or Template EU Medical Device Regulations 4
Paul Simpson Informational The role of Annex SL - High Level Structure of ISO MSS's - Revision Update February 2019 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
T ISO 9004:2018 Revision - Released April 2018 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Brizilla Knowledge of the upcoming ISO 17025 Revision ISO 17025 related Discussions 5
Q Change revision number in document when only codification was changed Document Control Systems, Procedures, Forms and Templates 8
Sam Lazzara Preferred Location for Revision History Section in Documents Document Control Systems, Procedures, Forms and Templates 16
Marc When will Revision 5 of the AIAG FMEA Manual be released? FMEA and Control Plans 93
S Pre-release version of the upcoming AIAG FMEA Revision 5 FMEA and Control Plans 1
J Is there a specification that provides directions on Drawing Revision Changes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
L Supplier Revision Confirmation of Received Engineering Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M ISO 14971 and ISO TR 24971 revision ISO 14971 - Medical Device Risk Management 32
Q AS9100 Re-certification Audit - Which Revision? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Proposed System: Revision = Modification Date; Approval = Access Permissions Document Control Systems, Procedures, Forms and Templates 1
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M ISO 14971:2007 Revision Approved - The Delft ISO TC 210 plenary meeting - Nov 2016 ISO 14971 - Medical Device Risk Management 2
N Transition Audits - AS9100 Revision D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
P Is the next revision of ISO 15378 following the High Level Structure? Other ISO and International Standards and European Regulations 5
M Future of ISO 14971 - Possible revision? ISO 14971 - Medical Device Risk Management 9
