Revision & Versions! Definitive difference between a Version and a Revision?
Manix
Get Involved!!!
Excuse my ignorance, but it has always bugged me!
What the **** is the definative difference between a Version and a Revision?
I believed that a version was the affectively the release, and the revision was that version revised. So a.1 is Version a, revision 1!
But this is not how some work and it becomes mighty confusing. Somone please give me a definative answer or I will go around the bend! :frust:
Another intersting point with this system, i s when does something warrant a new release or simply a new version.
I am YOUNG and RELATIVELY inexperienced.
Mr BS7799
Revisions vs Versions vs Issues vs Builds
IMHO they are one and the same.
I use the word "revision" though cuz its the term used in the standard (ISO 9001:2000).
Some organizations ive seen use a two-tier system. They assign a revision number for the "whole" document and an issue number for single "pages". Change done in single pages does NOT change the revision number of the whole document. If the number of pages to be changed exceeds 50% of the total number of pages on the document, then thats the time they change the revision number for the "whole" document.
Do not go around the bend YET Manix. There are lots of experienced people in this forum where you can turn to for assistance.
Cheers from Manila!!!
Jonathon Haddow
Version is variation of an earlier or original type: normally major change.
Revision is used for small changes.
Change the revision level of a procedure undergoing a minor change ie change in someones title ( hr manager - personelll director if they are the same person carrying out the same role in the procedure)
Change the version level if the change is to move the role to a completely different department where the emphasis may be different.
Mr BS7799
What if there was a change in the color of the nonconforming product tray from red to orange?
What if the "Final Inspection Record" was changed to "Outgoing Inspection Record"?
Would this merit a revision or a version change if these processes are documented? :argue:
Strict rules must be established for consistency and objectivity when using a two-tier system.
Ron Rompen
Not a good example (since the colors are so close to one another), but if for example, it was changed from black to white, I would call this a VERSION change (i.e. the entire concept of the standard has changed).
This would, to me, constitute a REVISION change (i.e. a document name has been changed, without changing the body of the document, or the information that is contained therein)
These are the guidelines that I work by, and so far they have convinced/fooled any auditor that has asked me.
Manix
Get Involved!!!
SO really what I get from you guys is that there seems to be no definative answer! It's depends upon the system you implement and as long as you use it consistantly and evryone within the organisation understands the system then this seems OK?
As with many things in our area of work, plenty of standards exist to try and get everyone working to a common(ish) system of work, but we all end up working to different variation!
Thanks for the guidance. If anyone else has any ideas or suggestions please feel free to post!
:thanks: to Ron, Mr BS and Jonathon for your contributions!
Hello Manix,
Yes, that's my view too, and I'd like to add that I try to make life as simple as possible even in this respect. I couldn't care less wether the change is big or small, so I use but one single expression when a document is updated: Issue.
Our controlled documents used to have revisions and issues. If we reached issue 5 it was mandatory that the next update would be a new revision, and blah, blah, and so on. That procedure had it's origins in the first issue (there we go again) :rolleyes: of ISO 9002. I killed it and wrote a new one. One thing less to worry about. Why do we always have to complicate matters?
/Claes
Caster
An Early Cover
Old School
My thinking is this is a relic of typewriter days and the steno pool.
A typwritten document was released (remember Mimeographs?) as Revision 2 for example. Then it collected handwritten notes (versions) until someone took the time to retype it with the changes as Revision 3.
With the advent of word processing and "re-engineering" of the clerical workforce this distinction is dead.
When we fix even a single typo we increase the revision by 1.
People often rail about the stupidity of this, until they suffer an expensive revision conflict in their own area. Only then do they see the benefit.
I don't think there are many pure paper systems still alive out there. And if there are, don't ever let me audit them for effectiveness.
Sorry, just re read this - it sounds more preachy & severe than I meant it to be.
Does anyone still run a pure paper system? Is it effective? Efficient? How do you know?
CarolX
Hi Manix and welcom to the Cove,
I don't even use the term "version". I use "revision" when I make a change to a document. I use "edition" when the whole system is revised, i.e. my Quality Manual went from edition 1 to edition 2 with the change from 9001:1994 to 9K2K.
Caster,
Why increase the revision to correct a typo? I have a "disclaimer" in my top level document that says typo corrections do not require rev level increases. Never had a finding on that one.
I think you may find there are a LOT of paper systems still out there. Think of the thousands of small job shops that can't afford a paperless system. I, for one, work for one of those. Effective...you bet....efficient...absolutely!!!
JMHO
Wes Bucey
JMHO
I used hard copy systems for 25 years. I still recommend it for operations which have few documents under control and who revise those documents less than four times/year.
I agree about minor typos and other changes which have nothing to do with dimensions of products or changes in processes. For as long as I can remember (back when I was reading Gutenberg's stuff first hand:rolleyes: ), publishers have resorted to an "errata" page between new printings to incorporate both MAJOR and MINOR changes to their books. In most organizations dealing with engineering drawings, the document control/management process makes provision for "red lining" a drawing or associated document with an interim change until such time as the organization goes through its normal change management process to generate a new revision to the document and to any affected Associated Documents. (Checking whether Associated Documents need changing is part of Configuration Management.)
Every customer's auditor and third pary auditor I have ever known has accepted such "interim documentation" when the organization has a process in place to assure the "obsolete" document is sequestered and all affected parties receive the "interim update" (note, not EVERYONE who normally receives the document needs the interim update - only those who need the document to produce or check or use the affected product or process.)
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
G IATF Rules for COVID 5th revision - Re-certification audit timing IATF 16949 - Automotive Quality Systems Standard 3
B Revision 5 to IATF Coronavirus Pandemic (Covid -19) IATF 16949 - Automotive Quality Systems Standard 0
Q Version/Revision Control of CAD files Document Control Systems, Procedures, Forms and Templates 2
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B New Release of CQI-12 Coatings Process (Revision 3- Release date- 7/2020) Customer and Company Specific Requirements 2
M Gap analysis on ISO 14971:2019 with previous revision ISO 14971 - Medical Device Risk Management 8
M Is There a Revision History or Change Log for Canadian Regulations? Canada Medical Device Regulations 3
C SOP unification. Revision No, Revision history Document Control Systems, Procedures, Forms and Templates 4
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
I Revision History Date - date of updates or date of release? ISO 13485:2016 - Medical Device Quality Management Systems 2
J ISO 14001 revision process ISO 14001:2015 Specific Discussions 1
B CQI-11 (Plating Audit) - New revision updates IATF 16949 - Automotive Quality Systems Standard 0
P Proposed revision of IEC 62304 - 2019 IEC 62304 - Medical Device Software Life Cycle Processes 6
I Tracking Protoype Changes; 8D or simple document revision? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A The latest revision number and changes in automotive core tools IATF 16949 - Automotive Quality Systems Standard 1
L Getting Notice of Revision and Accessing Public Draft Copies of ISO Standards Service Industry Specific Topics 2
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
M Informational ISO 14971 / ISO TR 24971 revision update – atualizações sobre a revisão Medical Device and FDA Regulations and Standards News 1
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
L VDA 1 Documented Information and Retention (new revision 4, August 2018) VDA Standards - Germany's Automotive Standards 0
M Informational ISO TC 210 JWG 1 meeting in São Paulo – Revision of ISO 14971 and ISO TR 24971 – Medical Device Risk Management Medical Device and FDA Regulations and Standards News 0
M Revision of a Form which is a Procedure Attachment Document Control Systems, Procedures, Forms and Templates 1
S IMS Manual Review and Revision Prior to Audit ISO 14001:2015 Specific Discussions 4
2 First Article Requirements for Revision Changes of Engineering AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
ScottK Question for Auditors on 7.1.4 in the ISO9001:2015 revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
R Clinical evaluation Meddev (2.7.1 revision 4) - Example or Template EU Medical Device Regulations 4
Paul Simpson Informational The role of Annex SL - High Level Structure of ISO MSS's - Revision Update February 2019 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
T ISO 9004:2018 Revision - Released April 2018 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Brizilla Knowledge of the upcoming ISO 17025 Revision ISO 17025 related Discussions 5
Q Change revision number in document when only codification was changed Document Control Systems, Procedures, Forms and Templates 8
Sam Lazzara Preferred Location for Revision History Section in Documents Document Control Systems, Procedures, Forms and Templates 16
Marc When will Revision 5 of the AIAG FMEA Manual be released? FMEA and Control Plans 93
S Pre-release version of the upcoming AIAG FMEA Revision 5 FMEA and Control Plans 1
J Is there a specification that provides directions on Drawing Revision Changes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
L Supplier Revision Confirmation of Received Engineering Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M ISO 14971 and ISO TR 24971 revision ISO 14971 - Medical Device Risk Management 32
Q AS9100 Re-certification Audit - Which Revision? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Proposed System: Revision = Modification Date; Approval = Access Permissions Document Control Systems, Procedures, Forms and Templates 1
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M ISO 14971:2007 Revision Approved - The Delft ISO TC 210 plenary meeting - Nov 2016 ISO 14971 - Medical Device Risk Management 2
N Transition Audits - AS9100 Revision D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
P Is the next revision of ISO 15378 following the High Level Structure? Other ISO and International Standards and European Regulations 5
M Future of ISO 14971 - Possible revision? ISO 14971 - Medical Device Risk Management 9
L The ink is dry(ing) on the revision of ISO 14001:2015. “Is the payoff worth the price Imported Legacy Blogs 0
A Post-market Clinical Studies of Orthopaedic (Revision) Implants EU Medical Device Regulations 1
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
I Document Control - Document Revision History Question Document Control Systems, Procedures, Forms and Templates 16
