Revision & Versions! Definitive difference between a Version and a Revision?
Manix
Get Involved!!!
#11
Thanks to everyone who contributed! :thanks:
Sorry, too young to remember the typewriter days!
We are implemeneting a system of document control that is linked into our CAD.
It has a vault whereby all documents are checked in and out. When it is checked in for the first time, it becomes Version a.0. Then subsequent check outs result in a.1, a.2, a.3 etc.
You can then release the document and this updates the letter used to b, c d etc..
So Iw ill try and implement a system that is consistent, using this computer control program.
The program is very good as it provides complete tracability for both CAD models/drawings and general design and process documentation.
I will still welcome any other products though! CHEERS, from a FREEZING UK!! :eek:
Wes Bucey
#12
Your revision/version numbering system is confusing to me.
It seems you are confusing an "audit trail" of how often and by whom the document is accessed with a "revision history" how often and by whom the document is modified.
Perhaps you miswrote what actually happens, since in common usage, the revision/version number only changes when the document itself changes.
If so, or if there is another explanation, please update us.
Manix
Get Involved!!!
#13
Sorry,
Maybe it would seem slightly confusing.
The vault holds the documents:
1. Create a document.
2. This document can then be 'Checked In' to the vault, but this does not release the document. This document is a.0, but remains unreleased. This document is accesable in 'read only' at any time and this will not affect it's revision history.
3. You can then 'Check Out' the document, if you are going to edit it in any way. Checking it out updates the revision, thus - a.1. But, the tracability comes because a.0 still exists, but is marked as being 'Not the Latest Revsion'.
4. The document can go through an official release process that once complete, will effectively be, a (the first release). I know this may seem confusing with just an explanation, but I am very confident that this system provides complete tracability and as previously mentioned in this thread, works well along as it is implemented consistently.
X
xtrakbandit
#14
Revisions and Engineering CM
I'm dealing with a simlar problem.
We have the following process in place regarding Versions and Revisions.
A revision is a change to a part or related documents that does NOT affect the form, fit or function of the part to the point where different revisions are interchangeable. Revisions are alpha (A, B, C, D etc)
Any change that affects the form, fit or function requires a new VERSION. The versions is the last two digits of the part number, ie. 2223-02 means version 2. The revision level is not part of the part number because the idea is that 2223-02 rev A and 2223-03 rev B are interchangeable.
Now heres where my question comes in. When it comes to configuration management and managing the BOMs, do you automatically update every BOM with the latest revision of a part. For example if 2223-03 rev A is used in 12 different assemblies and I create a new revision 2223-03 rev B, should I automatically updated each of those 12 assemblies to reference the latest revisions or do the 12 assemblies need to go through a change process (ECN) that updates the BOM to use the latest revision of 2223-03?
Wow! that was a mouthful.... Hope someone can offer a little more insight.
Thanks,
xtrakbandit
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
G IATF Rules for COVID 5th revision - Re-certification audit timing IATF 16949 - Automotive Quality Systems Standard 3
B Revision 5 to IATF Coronavirus Pandemic (Covid -19) IATF 16949 - Automotive Quality Systems Standard 0
Q Version/Revision Control of CAD files Document Control Systems, Procedures, Forms and Templates 2
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B New Release of CQI-12 Coatings Process (Revision 3- Release date- 7/2020) Customer and Company Specific Requirements 2
M Gap analysis on ISO 14971:2019 with previous revision ISO 14971 - Medical Device Risk Management 8
M Is There a Revision History or Change Log for Canadian Regulations? Canada Medical Device Regulations 3
C SOP unification. Revision No, Revision history Document Control Systems, Procedures, Forms and Templates 4
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
I Revision History Date - date of updates or date of release? ISO 13485:2016 - Medical Device Quality Management Systems 2
J ISO 14001 revision process ISO 14001:2015 Specific Discussions 1
B CQI-11 (Plating Audit) - New revision updates IATF 16949 - Automotive Quality Systems Standard 0
P Proposed revision of IEC 62304 - 2019 IEC 62304 - Medical Device Software Life Cycle Processes 6
I Tracking Protoype Changes; 8D or simple document revision? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A The latest revision number and changes in automotive core tools IATF 16949 - Automotive Quality Systems Standard 1
L Getting Notice of Revision and Accessing Public Draft Copies of ISO Standards Service Industry Specific Topics 2
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
M Informational ISO 14971 / ISO TR 24971 revision update – atualizações sobre a revisão Medical Device and FDA Regulations and Standards News 1
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
L VDA 1 Documented Information and Retention (new revision 4, August 2018) VDA Standards - Germany's Automotive Standards 0
M Informational ISO TC 210 JWG 1 meeting in São Paulo – Revision of ISO 14971 and ISO TR 24971 – Medical Device Risk Management Medical Device and FDA Regulations and Standards News 0
M Revision of a Form which is a Procedure Attachment Document Control Systems, Procedures, Forms and Templates 1
S IMS Manual Review and Revision Prior to Audit ISO 14001:2015 Specific Discussions 4
2 First Article Requirements for Revision Changes of Engineering AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
ScottK Question for Auditors on 7.1.4 in the ISO9001:2015 revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
R Clinical evaluation Meddev (2.7.1 revision 4) - Example or Template EU Medical Device Regulations 4
Paul Simpson Informational The role of Annex SL - High Level Structure of ISO MSS's - Revision Update February 2019 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
T ISO 9004:2018 Revision - Released April 2018 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Brizilla Knowledge of the upcoming ISO 17025 Revision ISO 17025 related Discussions 5
Q Change revision number in document when only codification was changed Document Control Systems, Procedures, Forms and Templates 8
Sam Lazzara Preferred Location for Revision History Section in Documents Document Control Systems, Procedures, Forms and Templates 16
Marc When will Revision 5 of the AIAG FMEA Manual be released? FMEA and Control Plans 93
S Pre-release version of the upcoming AIAG FMEA Revision 5 FMEA and Control Plans 1
J Is there a specification that provides directions on Drawing Revision Changes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
L Supplier Revision Confirmation of Received Engineering Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M ISO 14971 and ISO TR 24971 revision ISO 14971 - Medical Device Risk Management 32
Q AS9100 Re-certification Audit - Which Revision? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Proposed System: Revision = Modification Date; Approval = Access Permissions Document Control Systems, Procedures, Forms and Templates 1
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M ISO 14971:2007 Revision Approved - The Delft ISO TC 210 plenary meeting - Nov 2016 ISO 14971 - Medical Device Risk Management 2
N Transition Audits - AS9100 Revision D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
P Is the next revision of ISO 15378 following the High Level Structure? Other ISO and International Standards and European Regulations 5
M Future of ISO 14971 - Possible revision? ISO 14971 - Medical Device Risk Management 9
L The ink is dry(ing) on the revision of ISO 14001:2015. “Is the payoff worth the price Imported Legacy Blogs 0
A Post-market Clinical Studies of Orthopaedic (Revision) Implants EU Medical Device Regulations 1
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
I Document Control - Document Revision History Question Document Control Systems, Procedures, Forms and Templates 16
