Definition Rework vs. Repair - What's the practical difference?
alspread
#21
Rework is a repair that can be accomplished within the scope of the contract/drawing/specification, etc.
Machining is an easy example: If you are contracted to machine a component and you create a nonconformance that can be corrected by machining and you do not violate any controlled process requirements of the order/contract//spec, etc (i.e. remachining a hole that is too small) then that is rework.
A repair requires processing beyond the scope of the contract/drawing/spec, etc.
Again a machining example: If you are contracted to machine a component and you create a nonconformance that requires something or some process not permitted or specified on the contract/drawing/spec, etc (i.e. plug/sleeve/weld,etc an oversize hole is a repair and is typically authorized by the customer and/or design authority) then that is a repair.
Good luck
L
Lmyers
#22
I believe that it is more the opposite. A major change is more like a hole relocation which renders a part different in form or interchangeability and may require a repair (welding the hole closed and drilling a new hole in the new location). See ANSI Y14.5. The minor change would be the enlarging of a hole to meet a new larger diameter. The difference? When you fill a hole by welding it closed or using another filler material the alloy that is used as a filler cannot match the alloy of the existing material of the part, nor is the structure of the part the same of a part that is manufactured and not drilled and filled. The result is the repaired part can never completely meet the drawing while the reworked can.
John Broomfield
#26
I'm not sure if this is a dumb question, but :eek:
What's the practical difference between rework and repair? Are they different in a manufacturing enviroment.
AC
It matters because one action involves design change control per 7.3.7 the other does not.
Rework is work done to eliminate a nonconformity to make the product meet the original specification. For example, hole drilled too small, re-drill to correct size.
Repair is as design change because the work done needs an approved repair specification. For example, hole drilled too big, fill with weld material and re-drill to correct size.
Your car insurance policy probably gives the insurance company permission to use (cheaper) non-OEM parts so they have pre-approval for repair work on your damaged car. Rework would require use of OEM parts.
Customers cannot see evidence of rework but usually they can of repair.:2cents:
AdamP
#27
Interesting thread. It seems there are a couple "types" of answers here. One group follows the ISO, ASQ, etc. definitions, which are helpful for understanding the more practical side - which refer to specific industries, can leverage the definitions within an operational setting.
My experience with it is from aircraft MRO - maintenance, repair and overhaul. So in that context, I have to disagree with an earlier post that suggests both rework and repair have negative impact on the bottom line, since repairing turbine engine parts is often a better financial decision than buying new.
A painful expample on a difference: We were repairing a turbine part as customer contracted work in accordance with an FAA and OEM approved repair manual. A mistake was made during the repair, resulting in rework in order to bring the part into specification. The feature being repaired could only be repaired (modified) 4 times over the life of the part. The mistake and resultant rework affected that feature and therefore cost us 25% of the part's useful life.
One key point linking both types of answers though is the 'customer approved' bit.
W
whitey115
#28
In our opinion, If the item does not meet customer requirements and needs to be remade to customer requirements...is this considered the classic form of rework?:thanx:
#30
Not if the original part is scrapped off and disposed of. That's not rework at all, in my experience - it's replacement...
Rework means doing something to the out of spec part to bring it into spec, without materially changing the part. For example, drilling a hole larger than was originally produced. Bushing a hole which was drilled oversize is repair...
B Soldering Training (specific to Rework and Repair of PCBs) - Long Island Training - Internal, External, Online and Distance Learning 5
Q Dispositions In Claims and Complaints - "Use as is, Repair, Rework, etc" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Use As Is, Repair, Rework - Useful when categorizing? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q ISO 9001 Clause 8.3: Scrap, Rework, Repair, Why? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Definition Servicing circuit boards - Differences between Rework and Repair Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
B Overhaul vs. Repair vs. Rework - FAA Definitions Federal Aviation Administration (FAA) Standards and Requirements 7
T Definition Rework vs. Repair in ISO/AS9100 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 8
A Definition Rework vs. Repair - ISO 13485 definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
C Parts Rework / Repair SOP (Standard Operating Procedure) needed Document Control Systems, Procedures, Forms and Templates 6
B Generic procedure for repair / refurbishing / rework modifications to PCB components Document Control Systems, Procedures, Forms and Templates 3
J Rework or Recall 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
T ISO 13485 8.3 - Non-Conforming Materials - on-line rework or part of process? ISO 13485:2016 - Medical Device Quality Management Systems 11
G Rework, Reprocess, or Correction - A simple blurred letter on the legible etching ISO 13485:2016 - Medical Device Quality Management Systems 4
A AS9102 Delta FAI Require after Rework stock item from stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N Generic Rework/Reprocessing Procedure Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
L I need an example rework procedure/instruction for injected plastic parts Document Control Systems, Procedures, Forms and Templates 2
M IATF 16949 Cl. 8.7.1.4 - Risk analysis for decision making about rework IATF 16949 - Automotive Quality Systems Standard 2
T Is Sorting a kind of Rework? IATF 16949 - Automotive Quality Systems Standard 3
M IATF 16949 Clause 8.3 - Rework Records Requirements IATF 16949 - Automotive Quality Systems Standard 1
G Severity in Process FMEA for Rework Process FMEA and Control Plans 1
M What is the value of documenting in-process rework for easily-detectable issues? Quality Manager and Management Related Issues 4
G Rework requirement in ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 5
R How to document the Risk Management on Rework activities ? ISO 14971 - Medical Device Risk Management 6
S Regulatory Approval(s) for Rework Dispositions Nonconformance and Corrective Action 2
B Definition Sort vs. Rework - Differences and Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
B Form to use for Rework including Verification of Effectiveness of the Rework Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S How to establish a Sampling Plan from the Rework percentage? AQL - Acceptable Quality Level 6
A Nonconformances and Rework in a Machine Shop Nonconformance and Corrective Action 6
X Help with ISO 13485 Clause 8.3 "Rework" as applicable to Medical Device Servicing ISO 13485:2016 - Medical Device Quality Management Systems 39
D Rework Authorization Form example Manufacturing and Related Processes 5
R Medical Device Circuit Board Component Changes - Is this rework or not? ISO 13485:2016 - Medical Device Quality Management Systems 8
M Rework Devices placed on the market - IEC 60601-1 Requirements 3rd edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D Lean Management applied to Rework Zones Lean in Manufacturing and Service Industries 8
Q Documenting the Review of Adverse Effects from Rework ISO 13485:2016 - Medical Device Quality Management Systems 4
Q ISO 9001 Clause 8.3 Rework Verification - Re-verification to demonstrate conformity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Requirements for Approval of Rework Work Instructions ISO 13485:2016 - Medical Device Quality Management Systems 6
M Can sorted returns be returned to stock. Do they need a rework label? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Is Rework "Inspecting Quality In"? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
G Numbers that will help us understand what the Cost of Rework is Misc. Quality Assurance and Business Systems Related Topics 7
B Define "Rework" Under Medical Device Standards ISO 13485:2016 - Medical Device Quality Management Systems 10
P Rework Notification - Is it sufficient to show how we control rework process Manufacturing and Related Processes 1
T Rework Traceability System Manufacturing and Related Processes 8
A Scrap vs. Rework Classification - Scraping the resistor or reworking the PCB board? Quality Tools, Improvement and Analysis 10
L Quality Objectives Ideas - Currently we have Scrap & rework, OTD, survey results, etc Manufacturing and Related Processes 50
M Identifying Rework in Maintenance or Craftsman Operations Lean in Manufacturing and Service Industries 12
C How to document rework being completed at Suppliers on Medical Devices? ISO 13485:2016 - Medical Device Quality Management Systems 3
Z Rework Reduction Six Sigma Project - Need help Six Sigma 5
E Medical Device Software - Control of Nonconforming Product and Rework ISO 13485:2016 - Medical Device Quality Management Systems 4
C Calculate DPPM/PPM for second yield rework Quality Tools, Improvement and Analysis 1
E Calculating the MTBF for an assembly, Failure and Rework Prediction Reliability Analysis - Predictions, Testing and Standards 6
