Ring Gauges P.D Formula using "Ball Rounded Teeth"
harry
#11
...................i could send the link if i get 10 posts... to the pic we use measurments with. ..............
I am sorry but this is quite an effective way to handle impatient spammers. Could you please type the address of the link (abc at xyz dot com) and we will activate it for you.
Darik
#14
:thanx:
the picture is 90 degrees off. i got this probe shown in it which i take to both sides of the ring [the machine in the backround helps me find the center of the length and higeht of the ring]. because the edge of the prob is not stright but "rounded" and because the edges of the rings arent stright i need to find a way to calculate the missing 0.050 - 0.100 m"m...:deadhorse:
can any one direct me to a link about somethin like this???:agree1:
:thanks:
J Using ring gauges General Measurement Device and Calibration Topics 2
S ISO 5356-1 - 22 mm ring gauges and test laboratories for an Anesthetic connector Other Medical Device Related Standards 1
V How to Calibrate Ring Force Gauges Service Industry Specific Topics 1
B Calibration of "Z" class ring gauges internally using a CMM General Measurement Device and Calibration Topics 5
G API REG Pin and Box Threading - Minimum Gages Needed - Thread, Plug and Ring gauges? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Calibration, should we.... Go-No-Go, thread, pin, and ring gauges QS-9000 - American Automotive Manufacturers Standard 2
D O Ring capability and measurement - What is the automotive 'norm' for capability studies on O Rings? General Measurement Device and Calibration Topics 3
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
S Poka Yoke Inspection Retaining Ring (C-Clip) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Interesting Discussion Threaded ring gage calibration and tendonitis in the elbows General Measurement Device and Calibration Topics 8
S Thread Ring Gauge verification General Measurement Device and Calibration Topics 6
M Calibration of Thread Plugs and Ring Gages - Various Thread Standards General Measurement Device and Calibration Topics 3
S Clarification of threaded ring gage calibration procedure/requirements General Measurement Device and Calibration Topics 2
S Looking for a Threaded Ring Gage Calibration Laboratory General Measurement Device and Calibration Topics 13
C O-Ring Groove Measurement Method in CNC Machined Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
Q Is it normal practice to lubricate Ring Gages before use? General Measurement Device and Calibration Topics 17
GURU SDI Leak Testing - O-ring installation in the groove of Bore ID Problem Solving, Root Cause Fault and Failure Analysis 4
C Manufacturing Thread Ring Gages Manufacturing and Related Processes 3
C Measuring Solid Thread Ring Gages General Measurement Device and Calibration Topics 17
P Best Method of Cleaning of Thread Ring Gages Calibration Frequency (Interval) 5
P No-go Ring Over the specifiaction limit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
kedarg6500 Availability of 5/8" 17.75 TPI Thread Ring Gauge & Die Nut Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
P How to add Voip features (ring group, virtual receptionist) into Cisco SIP PBX in C#? Medical Information Technology, Medical Software and Health Informatics 1
0 Is it possible to use a threaded ring gage to calibrate the M8 gage? Calibration and Metrology Software and Hardware 4
M Thread Ring Gauge Specifications General Measurement Device and Calibration Topics 3
K Calibration Requirements for Thread and Ring Gages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Thread Timing - Ring Gage Frustration General Measurement Device and Calibration Topics 11
C Test Uncertainty Ratio (TUR) for Ring Gage Calibration Measurement Uncertainty (MU) 7
Z Error of 30 microns checking a Ring Gauge on a CMM Machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
C Adjustable Thread Ring Gage Calibration General Measurement Device and Calibration Topics 8
J Measuring a shallow OD of a Machined Ring/Groove Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
D ISO/Metric Solid Thread Ring Calibration General Measurement Device and Calibration Topics 1
R Thread Measurement - Basics on Thread Plug and Ring Calibration General Measurement Device and Calibration Topics 5
J Thread Ring Gauge UNJ vs UN General Measurement Device and Calibration Topics 11
L Calibration of ring thread gauge with master gauge: How to calculate Uncertainty? General Measurement Device and Calibration Topics 1
N Measurement and Inspection of SAE J-1926 O-Ring Ports Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Q Question regarding O-ring application for water proofing a device Design and Development of Products and Processes 2
A Performing Ring Gage Calibration General Measurement Device and Calibration Topics 5
Z Ring Gage Calibration Sizes Shrunk with New External Vendor (supplier) General Measurement Device and Calibration Topics 16
T Calibration and Control - Need help with plug, ring, and thread plug gages General Measurement Device and Calibration Topics 12
M Calibration of ring gages with a CMM General Measurement Device and Calibration Topics 3
Q Tolerance Set Plugs to Calibrate Thread Ring Gage - Question General Measurement Device and Calibration Topics 4
A Ring Joint Gasket Defect Types and their Consequences Various Other Specifications, Standards, and related Requirements 13
ScottK Rubber O-Ring Inspection Standard - SAE J515? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
F Finding Reasonably Priced Ring Gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
K Suggestions for a Low Cost Accredited Calibration Laboratory - Ring Gages General Measurement Device and Calibration Topics 8
U Calibration House - Where I can get a PG 13.5 Gut thread ring gage calibrated? General Measurement Device and Calibration Topics 1
2 How to Check Dimensions of an O-Ring Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
