RIPs should be labeled and not shipped. What are RIPs in ISO/TS 16949:2002?
dv802
I attended a power point "training" session for ISO/TS 16949 today and I am confused about an acronym that was used. In the section about "non-conformance parts" the presentation stated "RIPs should not be shipped" and "RIPs should be labeled". Nobody knows what this means... not even the Quality Manager. Does anybody here know what it means? I don't know if the company I work for created the presentation or if they purchased it. Also, if the QM doesn't know what it means how do I, as a machine operator, know if I'm meeting TS 16949 requirements? What does "RIP" refer to?
Thanks, Donna
Dave Johnson
Hello and Welcome!!
I can't find anything in the TS standard referring to RIP's, but this may concern a customer waiver. The standard says (in 8.3.4) that your company must obtain a "customer concession or deviation prior to further processing whenever the product or manufacturing process is different from that which is currently approved".
I'm just guessing, but could RIP be "Rework in Progress" or something like that?
"RIPs should not be shipped":
When a customer gives a concession or deviation, standard practice is that this is in writing. They will tell your management any special requirements they will have you do.
Depending on the part's function, appearance, criticality to the customer, etc., your company may not want to send out any reworks without your customer's permission. This may be spelled out in the contract or in the customer's supplier quality requirements manual.
"RIPs should be labeled":
The containers containing your reworked/deviated parts usually have to be marked in some way, such as a hi-lited "X" mark or with the customer's deviation number on the outside of the container.
As a machine operator, it's management's responsibility to let you know what is required in these cases.
Again, Ive never heard of RIP referenced with TS. I hope this helps.
daj
Wes Bucey
Prophet of Profit
Dave Johnson said:
Hello and Welcome!!
daj
There are only two possible solutions that I've heard of to this acronym which could conceivably fit:
Recoverable Item Program
Repair In Place
Even so, it is immaterial for the exact meaning, because I'm sure you don't have a program which even remotely covers these two terms or you or your Quality Manager would have made the connection already.
The only solution to this quandary is to have Quality Manager track it down - his responsibility is to assure all training is understood by students - this is an obvious gap in understanding.
Sorry - this illustrates the concept behind my frequent rants about folks who use acronyms without providing the referent and and without explaining them more fully.
Thanks, Donna
Of course, the first thing is welcome to the cove. :bigwave: It is great to have other folks here from the Great Lakes State!
I think others have answered this well. My guess is the organization that gave the class uses RIP as a common name for them. It is not a common name, as you can now see. However, looking at the context of the usage, I would assume that RIP is not a good thing, and we should take steps to ensure it does not get to the customer. We can safely say that all nonconforming product would fit into this category, as would anything "in process". Your best bet is to go back to the organization, and ask them. Then you can let us know!
Sounds like a deal to me. :thedeal:
dv802
Thanks for the help guys :D . I had a feeling that it meant "rework in progress" but when I suggested it in the meeting I was met with a bunch of blank stares. Our Continuous Improvement Team tracked it back to the plant that created the presentation and that's exactly what it meant.
Your replies were very informative, the 45 minute "training " I had just gave me very basic information. Thanks again
I IEC 60812 or ISO 14971 for PFMEA? What should we use? ISO 14971 - Medical Device Risk Management 3
qualprod Do sum of results of quality objectives should met a high level goal? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Should I perform several Gage R&R for every caliper to cover all specs range of use? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
E Opening meeting for Third-Party Audit--Who should say what? General Auditing Discussions 22
8 MSA--Should I Use Parts or Gage Pins? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Should I buy IEC 62304:2006, IEC 62304:2006/AMD 1:2015 or both? EU Medical Device Regulations 1
W "Accurate to ±2%" means "64% of measurements should be within 2% of the actual value"? US Medical Device Regulations 4
H Should we stop inspecting a part if its never been rejected? Reliability Analysis - Predictions, Testing and Standards 6
D What distributor requirement should we (manufacturer) require from the Distributor? EU Medical Device Regulations 0
M Should there be another column in the Optimization section (step 6) of AIAG-VDA DFMEA form? FMEA and Control Plans 1
C By when should harmonized standards be complied with? EU Medical Device Regulations 5
W Strategy for determining which components from a system should be "ME EQUIPMENT" -- home healthcare environment IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
B Documented information - Should be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Is engineering a process and should it have its own process turtle? IATF 16949 - Automotive Quality Systems Standard 7
P Which MDCG Document should I use for PMS Plan and PSUR? EU Medical Device Regulations 2
M Who should quality representative report to? ISO 13485:2016 - Medical Device Quality Management Systems 5
H When should the first PSUR be issued? EU Medical Device Regulations 5
I If i do not want to be an initial importer should i register with FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B UKRP to what level should you audit Class I Technical Documentation? UK Medical Device Regulations 0
C When should you quit programming? Job Openings, Consulting and Employment Opportunities 9
C Should resolution be included in uncertainty budget for digital caliper or micrometer calibration? Measurement Uncertainty (MU) 5
Ed Panek External Standards List - Should this document include previously revised standards? ISO 13485:2016 - Medical Device Quality Management Systems 4
T How should I approach REACH, CM, etc. as a job shop? RoHS, REACH, ELV, IMDS and Restricted Substances 18
A Should we assign the PRRC before the date of application of MDR (26 May 2021)? EU Medical Device Regulations 0
J UDI-DI how should we interpret Device version or model to determine if a new UDI-DI is needed? EU Medical Device Regulations 0
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
S Which Sampling Plan(s) Should I Use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 7
John Broomfield Should ISO 9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 70
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
M Should 510(k) Predicates be Actively Listed Devices? Other US Medical Device Regulations 12
H Who should be listed as the manufacturer/distributor on the box? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
