Risk analysis 6.1 and contingency plans 6.1.2.3, are they related?
Johnson
#11
To meet IATF16949:2016 requirements on risk analysis, the generall accepted practice is:
- The organiation (supplier): add "risk analysis and opportunity" on each process turtle diagram, or/and maintain and control a "risk and opprtunity managtement work sheet" for all QMS processes.
- The CB: show risk analysis on 'audit check list" for each process.
#12
"To meet IATF16949:2016 requirements on risk analysis, the generally accepted practice is:
- The organization (supplier): add "risk analysis and opportunity" on each process turtle diagram, or/and maintain and control a "risk and opportunity management work sheet" for all QMS processes.
- The CB: show risk analysis on 'audit check list" for each process."
I'd suggest that a) this isn't "generally accepted practice" and b) is inaccurate to what is required.
qualprod
#13
In IATF 16949 clause 6.1, which is the same as in ISO 9001, we need to conduct a risk analysis and then plan actions to mitigate such risks.
Then the contingency plan clause 6.1.2.3, mentions the risks analysis and risk mitigation activity again.
What is the difference between 6.1 (6.1.1-6.1.2) and 6.1.2.3? From what I could understand, they are referring to the same requirement. I could be wrong however.
We already have contingency plans in place despite the fact that they where not explicitly mentioned in ISO9001.
Thanks for your help.
As I understand:
I think is somewhat different
When risk is detected, if want ti mitigate it, you define plans with due dates and responsibles but such activities
are planned for short medium and long term, but What it happens if risk exploded suddenly, lets say that
next day after it was evaluated. what are you going to do if your plans are not finished yet?
See next:
A contingency plan is a course of action designed to help an organization respond effectively to a significant future event or situation that may or may not happen. A contingency plan is sometimes referred to as "Plan B," because it can be also used as an alternative for action if expected results fail to materialize
Sebastian
#14
Risks and opportunities shall be determined for all processes of quality management system and this is 6.1.1.
Only one "waiver" is given in 6.1.2.2 b) where organization is authorised to decide whether implement or not preventive actions.
Expected here is good explanation for why not.
It would be nice to know names of those CB who accept lack of risk determination for all processes. in case of IATF 16949.
AMIT BALLAL
#15
Sebastian, there is no requirement to determine risks for processes. Risk has to be determined in line with 4.1 and 4.2. Actions against these risk assessment has to be implemented in QMS processes. 6.1.1 doesn't specify any shall requirement to determine process-wise risk.
Sebastian
#17
Amit I agree that literary not.
Let's take a look on it from opposite side. Is there any system process, which is not influenced by 4.1 and 4.2?
If yes, there are no risks, no opportunities.
AMIT BALLAL
#20
We cannot assume that 4.1 and 4.2 influences every process. It varies from organization to organization. That's the main intention of the standard to start with organization's context (4.1 & 4.2), so that system can be designed accordingly. In your organization, the context might be influencing all process, but context of every organization is not same.
Standard doesn't state such requirement that it should relate to every process. If you feel you should do risk analysis process-wise / attach context to every process, you can, but is not required by the standard.
silentmonkey Overall Benefit/Risk Analysis - Risk Management VS Clinical Evaluation ISO 14971 - Medical Device Risk Management 3
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
E Normal Condition Hazards in Risk Analysis ISO 14971 - Medical Device Risk Management 3
M Risk Analysis Flow - Confusion between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
R ECG Risk Analysis Standards ISO 14971 - Medical Device Risk Management 2
adir88 Documenting Risk Control Option Analysis ISO 14971 - Medical Device Risk Management 8
M IATF 16949 (6.1.1 - Planning and Risk Analysis for a remote site) Process Maps, Process Mapping and Turtle Diagrams 5
D Risk Analysis & Technical File - What detail goes in the Risk Management Report ISO 14971 - Medical Device Risk Management 5
M An example of risk analysis of class I MD ISO 14971 - Medical Device Risk Management 36
T Risk analysis of QMS software - Validating software we use for QMS ISO 13485:2016 - Medical Device Quality Management Systems 5
B Grouping of Products for Risk Analysis ISO 14971 - Medical Device Risk Management 9
A Risk-benefit Analysis - Hazard Analysis (HA) and FMEAs ISO 14971 - Medical Device Risk Management 18
R The difference b/w FMEA & Risk analysis as per iso 14971 ISO 14971 - Medical Device Risk Management 8
K Risk Analysis Updates due to complaints ISO 14971 - Medical Device Risk Management 10
S The Severity of a Medical Device Hazard - Risk Analysis Clarification ISO 14971 - Medical Device Risk Management 6
Ed Panek Transition to IEC 60601 4th Edition - Risk Analysis and test submissions CE Marking (Conformité Européene) / CB Scheme 2
S In a risk analysis, how can we tie mobile app security breach to ISO 14971? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Q Risk / benefit Analysis in Risk Management Report CE Marking (Conformité Européene) / CB Scheme 12
R IATF 16949 Clause 6.1.2.1 - Lessons Learned and Risk Analysis IATF 16949 - Automotive Quality Systems Standard 6
B Software Class A - Lengthy further risk analysis IEC 62304 - Medical Device Software Life Cycle Processes 9
W Biocompatibility Risk Analysis for Clinical Practitioner 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
F Risk Analysis of a Medical Device Accessory ISO 14971 - Medical Device Risk Management 4
S How we can use risk analysis for suppliers IATF 16949 - Automotive Quality Systems Standard 6
I Medical Device Software Risk Analysis ISO 14971 - Medical Device Risk Management 4
Q Risk Analysis - Same Risk Treatment for Context and Interested Parties ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Risk Analysis for COTS/OTS Risk Management Principles and Generic Guidelines 4
M IATF 16949 Cl. 8.7.1.4 - Risk analysis for decision making about rework IATF 16949 - Automotive Quality Systems Standard 2
E Risk Analysis - Events which may cause to Data Loss ISO 14971 - Medical Device Risk Management 12
W Risk Benefit Analysis - ISO 14971:2012 Requirements ISO 14971 - Medical Device Risk Management 27
F Medical Device HACCP (Hazard Analysis and Critical Control Point) Risk Management ISO 14971 - Medical Device Risk Management 2
Q Risk Tools in ISO 31010 - Root Cause Analysis vs. Cause-and-effect Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Organizing Risk Analysis and Controls for a New Medical Device (ISO 14971) ISO 14971 - Medical Device Risk Management 4
S Please review my Risk Analysis Table ISO 14971 - Medical Device Risk Management 13
K Risk Analysis and "Information for Safety" / Labeling ISO 14971 - Medical Device Risk Management 10
M Risk analysis - ISO/TS 16949 clause 7.2.2.2 IATF 16949 - Automotive Quality Systems Standard 2
C Help with Risk/Benefit Analysis Self-help Device for Diabetics ISO 14971 - Medical Device Risk Management 3
A FTA-Top/Down approach to Risk Analysis ISO 14971 - Medical Device Risk Management 2
A Industry best practice about Post-Market Surveillance and Risk Analysis ISO 14971 - Medical Device Risk Management 6
T Risk Analysis help for CE Marking Class I Medical Device ISO 14971 - Medical Device Risk Management 10
T Risk Analysis for moving manufacturing equipment ISO 14971 - Medical Device Risk Management 17
D Different kinds of Risk Analysis for various Hazards ISO 14971 - Medical Device Risk Management 3
L GHTF/SG3/N15R8 - Process Validation and Risk Analysis ISO 13485:2016 - Medical Device Quality Management Systems 4
R Risk Analysis of Class IIb Disinfectant ISO 14971 - Medical Device Risk Management 6
J Does anyone have an example of Risk-Benefit Analysis per ISO 14971? Other ISO and International Standards and European Regulations 2
P FMEA Risk Analysis Recommended Action Priority FMEA and Control Plans 2
N ISO 14971 Risk Analysis - Sections 4.2 and 4.3 ISO 14971 - Medical Device Risk Management 2
D ISO 14971 - Risk Analysis Best Practices ISO 14971 - Medical Device Risk Management 5
S Internal Audit Plan per Risk Analysis Internal Auditing 5
