Risk Analysis of a "Medical System" according to ISO 14971
cyril john
Hi all, I am new on this forum so I am eagerly waiting for your suggestions.
-Can some one help clarify how to do a risk analysis for a "medical System" (in this case, we have a dialysis machine, connected to non-medical devices like disposable blood lines, plastic connectors, an IT network)
-The risk analysis for each product ( dialysis machine , disposable blood lines) is done separately, that is by their respective producers.
-How can we do a risk analysis of the assembled MEDICAL SYSTEM, permits us to:
  • manage change (i.e to systematically analyse the effect of a change in one product on other products and on the entire system);
  • to avoid double assessment of the same hazards.
according to the norm ISO 14971 or En 60601-1
Thanks,
yodon
Well, I'll toss out something to maybe spur the discussion along...
I guess I'm having trouble understanding your issue. Are you saying that the "system" has different risks than the summation of risks of all components? What other kind of hazards / risks are there with the system? Clearly you'll need to have some system-level view of all the risks.
Would doing something like a use / application perspective risk analysis cover your concerns?
abigailt
We recently received training on ISO14971 and it became apparent that we were missing a trick in that the Annexes are very useful.
Annex C in particular can be used to ask the right questions based on the 'system' - it may then be relevant to reference the risks from a particular component or it may be necessary to analyse the risk of the system as a whole.
Annex D gives good guidance on Risk concepts and analysis, evaluation etc
cyril john
Hi all, thanks so far for your replies.
Annex C is really helpful in identifying risks which could arise in the system. Prior to this, I didn´t realize it could be used for "Systems".(thanks abigailt)
And as for the extra explanations requested, I have attached a photo which represents the "system".
Actually, all the possible hazards and risks are already known. And the corresponding risk control measures are also known. But this assessment has been done separately:
  • for the entire dialysis Machine, (by the producers of the dialysis machine)
  • for each of the other components (by the producers of each component).
Yet the real problem is the level of the interface. Having assembled the "Medical System" , We want to take each risk which exist at the interface
- verify the correct implementation of each risk control measure.
A model like that used in figure H.2, Annex H of IEC 60601-1 3rd Edition, could be very helpful. This model is however for a PEMS and not for "Medical Systems"
Hope this sheds more light on the problem:)
thanks
Pads38
Moderator
As many of the risks involved are related to the use of the system (incorrect connections, interface misunderstood, use errors, deliberate misuse etc etc) you may want to consider the usability standard IEC 62366.
It also has very useful informative annexes (E - H).
S The Severity of a Medical Device Hazard - Risk Analysis Clarification ISO 14971 - Medical Device Risk Management 6
FoGia Risk Analysis of a Medical Device Accessory ISO 14971 - Medical Device Risk Management 4
I Medical Device Software Risk Analysis ISO 14971 - Medical Device Risk Management 4
F Medical Device HACCP (Hazard Analysis and Critical Control Point) Risk Management ISO 14971 - Medical Device Risk Management 2
S Organizing Risk Analysis and Controls for a New Medical Device (ISO 14971) ISO 14971 - Medical Device Risk Management 4
T Risk Analysis help for CE Marking Class I Medical Device ISO 14971 - Medical Device Risk Management 10
V Medical Device Intended Use Document - Risk Analysis Documentation Requirements ISO 14971 - Medical Device Risk Management 12
W Software Tool for Medical Device Risk Analysis - Recommendations please ISO 14971 - Medical Device Risk Management 4
A An Example of a Risk Analysis Report for a Class II Medical Device (Oxygen Mask) ISO 14971 - Medical Device Risk Management 29
K Do you have to use RPN in Medical Device Risk Analysis? Identification of Hazards ISO 14971 - Medical Device Risk Management 6
A ISO 13485 Risk Analysis - Class II Medical Device Engineering Changes ISO 13485:2016 - Medical Device Quality Management Systems 9
T Best Risk Analysis Approach (ISO 14971) - Class IIa Medical Devices ISO 14971 - Medical Device Risk Management 16
R What is Risk Analysis certificate? Class III Medical Sutures ISO 13485:2016 - Medical Device Quality Management Systems 4
Ajit Basrur Is Risk analysis for plastic parts of medical devices required? ISO 13485:2016 - Medical Device Quality Management Systems 9
P Risk Analysis Requirements - Medical Devices Manufactured prior to 1998 ISO 13485:2016 - Medical Device Quality Management Systems 1
T Calculating Basic Risk/ Basic on Risk Analysis - Medical device MDD Class II and up ISO 13485:2016 - Medical Device Quality Management Systems 8
G Risk Analysis on Medical Device Instructions for Use? ISO 13485:2016 - Medical Device Quality Management Systems 12
J Medical Device Risk Analysis - FMEA vs ALARP (As Low As Reasonably Possible) FMEA and Control Plans 3
howste FMEA vs. Risk Analysis - What are the differences - Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 10
T Article 22 procedure pack risk analysis EU Medical Device Regulations 1
S Risk analysis on patient monitor ISO 14971 - Medical Device Risk Management 5
J Determination of software safety class (62304) prior to software risk analysis ISO 14971 - Medical Device Risk Management 3
G FDA requirements for risk analysis US Food and Drug Administration (FDA) 2
L HA vs risk analysis ISO 14971 - Medical Device Risk Management 2
K Help with ISO 14971: Benefit-Risk Analysis ISO 14971 - Medical Device Risk Management 3
L Risk analysis Manufacturing and Related Processes 4
J Risk Analysis for Proficiency Testing Reliability Analysis - Predictions, Testing and Standards 1
S What is your favorite Usability Risk Analysis tool? IEC 62366 - Medical Device Usability Engineering 5
H Risk Analysis and Probability of Occurrence ISO 14971 - Medical Device Risk Management 3
Booker Risk analysis for defective measuring or measuring equipment out of calibration General Measurement Device and Calibration Topics 2
P Benefit risk analysis on pFMEA ISO 14971 - Medical Device Risk Management 10
silentmonkey Overall Benefit/Risk Analysis - Risk Management VS Clinical Evaluation ISO 14971 - Medical Device Risk Management 3
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
E Normal Condition Hazards in Risk Analysis ISO 14971 - Medical Device Risk Management 3
M Risk Analysis Flow - Confusion between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
R ECG Risk Analysis Standards ISO 14971 - Medical Device Risk Management 2
adir88 Documenting Risk Control Option Analysis ISO 14971 - Medical Device Risk Management 8
M IATF 16949 (6.1.1 - Planning and Risk Analysis for a remote site) Process Maps, Process Mapping and Turtle Diagrams 5
Dobby1979 Risk Analysis & Technical File - What detail goes in the Risk Management Report ISO 14971 - Medical Device Risk Management 5
M An example of risk analysis of class I MD ISO 14971 - Medical Device Risk Management 36
T Risk analysis of QMS software - Validating software we use for QMS ISO 13485:2016 - Medical Device Quality Management Systems 7
B Grouping of Products for Risk Analysis ISO 14971 - Medical Device Risk Management 9
A Risk-benefit Analysis - Hazard Analysis (HA) and FMEAs ISO 14971 - Medical Device Risk Management 18
R The difference b/w FMEA & Risk analysis as per iso 14971 ISO 14971 - Medical Device Risk Management 8
K Risk Analysis Updates due to complaints ISO 14971 - Medical Device Risk Management 10
Ed Panek Transition to IEC 60601 4th Edition - Risk Analysis and test submissions CE Marking (Conformité Européene) / CB Scheme 2
S In a risk analysis, how can we tie mobile app security breach to ISO 14971? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Q Risk / benefit Analysis in Risk Management Report CE Marking (Conformité Européene) / CB Scheme 12
