Risk Analysis & Technical File - What detail goes in the Risk Management Report
Dobby1979
Hi All.
I am hoping to submit our 510(k) early in the New Year and wondered if anyone had a Risk Management Report example that they could share? We have followed 14971 for the Risk Analysis, will produce a traceability report of the risks to testing. What detail goes in the RMR though? Is it simply a couple of pages details certain risks and an overall evaluation of the residual risks?
Ronen E
Problem Solver
Moderator
1. Why do you need to include a risk analysis (let alone a risk management report) in your 510(k)? Is it a Special 510(k)?
2. ISO 14971 has a dedicated section that tells you what a RMR should include.
Dobby1979
We are submitting a standard 510(k).
As we are following 14971, surely the FDA would expect to see the RA for our software device? I would also expect them to be looking for things like the risk management report, evaluation of overall risk etc....
Is this not required?
Tidge
For the 510(k) submissions I've been part of (including medical devices with software, and software only updates to medical devices, but no 'software as a medical device') we have submitted the overall system hazard analysis and the software hazard analysis, which in our system is a subordinate document to the system HA. I have a couple of areas to tread with caution, but nothing to be seriously worried about.
First: Strictly speaking, the risk management file ought to be supporting the device as marketed, but prior to the FDA's positive response to the submission you probably won't be marketing the device. Don't sweat this: you can use redlines and/or preliminary versions of risk files as long as they are complete enough to support the submission.
Second: For several systems that I have worked with, the overall system hazard analysis has had 'too much' information for the FDA reviewer(s) for some of the more focused 510(k) submissions. If appropriate, it is to your benefit to focus the review to the specific areas covered by the software submission. Those areas will be relatively obvious based on your use of the FDA's "Level of Concern" for the software. See next...
We have a Risk Management Report (as well as an overall RM Plan) but rather than submit that with the 510(k) we submit a standalone assessment of the "Level of Concern" which identifies the Minor/Moderate/Major level of concern and makes it clear we know what we evidence need to include within the submission. The Minor/Moderate/Major levels generally align with software safety class A/B/C from 62304, so you shouldn't have any surprises about what you need for the submission. We have constructed the Software Hazard Analysis such that it shows the elements required by 62304 (per the software system safety classification) for the individual elements of analysis which support the greater Hazard Analysis.
B ISO 14971 replaces EN 1441 - Risk Analysis and Technical Files/Device Master Files ISO 14971 - Medical Device Risk Management 17
L Risk analysis Manufacturing and Related Processes 4
J Risk Analysis for Proficiency Testing Reliability Analysis - Predictions, Testing and Standards 1
S What is your favorite Usability Risk Analysis tool? IEC 62366 - Medical Device Usability Engineering 5
H Risk Analysis and Probability of Occurrence ISO 14971 - Medical Device Risk Management 3
B Risk analysis for defective measuring or measuring equipment out of calibration General Measurement Device and Calibration Topics 2
P Benefit risk analysis on pFMEA ISO 14971 - Medical Device Risk Management 10
silentmonkey Overall Benefit/Risk Analysis - Risk Management VS Clinical Evaluation ISO 14971 - Medical Device Risk Management 3
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
E Normal Condition Hazards in Risk Analysis ISO 14971 - Medical Device Risk Management 3
M Risk Analysis Flow - Confusion between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
R ECG Risk Analysis Standards ISO 14971 - Medical Device Risk Management 2
adir88 Documenting Risk Control Option Analysis ISO 14971 - Medical Device Risk Management 8
M IATF 16949 (6.1.1 - Planning and Risk Analysis for a remote site) Process Maps, Process Mapping and Turtle Diagrams 5
M An example of risk analysis of class I MD ISO 14971 - Medical Device Risk Management 36
T Risk analysis of QMS software - Validating software we use for QMS ISO 13485:2016 - Medical Device Quality Management Systems 7
B Grouping of Products for Risk Analysis ISO 14971 - Medical Device Risk Management 9
A Risk-benefit Analysis - Hazard Analysis (HA) and FMEAs ISO 14971 - Medical Device Risk Management 18
R The difference b/w FMEA & Risk analysis as per iso 14971 ISO 14971 - Medical Device Risk Management 8
K Risk Analysis Updates due to complaints ISO 14971 - Medical Device Risk Management 10
S The Severity of a Medical Device Hazard - Risk Analysis Clarification ISO 14971 - Medical Device Risk Management 6
Ed Panek Transition to IEC 60601 4th Edition - Risk Analysis and test submissions CE Marking (Conformité Européene) / CB Scheme 2
S In a risk analysis, how can we tie mobile app security breach to ISO 14971? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Q Risk / benefit Analysis in Risk Management Report CE Marking (Conformité Européene) / CB Scheme 12
R IATF 16949 Clause 6.1.2.1 - Lessons Learned and Risk Analysis IATF 16949 - Automotive Quality Systems Standard 6
S Risk analysis 6.1 and contingency plans 6.1.2.3, are they related? IATF 16949 - Automotive Quality Systems Standard 26
B Software Class A - Lengthy further risk analysis IEC 62304 - Medical Device Software Life Cycle Processes 9
W Biocompatibility Risk Analysis for Clinical Practitioner 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
F Risk Analysis of a Medical Device Accessory ISO 14971 - Medical Device Risk Management 4
S How we can use risk analysis for suppliers IATF 16949 - Automotive Quality Systems Standard 6
I Medical Device Software Risk Analysis ISO 14971 - Medical Device Risk Management 4
Q Risk Analysis - Same Risk Treatment for Context and Interested Parties ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Risk Analysis for COTS/OTS Risk Management Principles and Generic Guidelines 4
M IATF 16949 Cl. 8.7.1.4 - Risk analysis for decision making about rework IATF 16949 - Automotive Quality Systems Standard 2
E Risk Analysis - Events which may cause to Data Loss ISO 14971 - Medical Device Risk Management 12
W Risk Benefit Analysis - ISO 14971:2012 Requirements ISO 14971 - Medical Device Risk Management 27
F Medical Device HACCP (Hazard Analysis and Critical Control Point) Risk Management ISO 14971 - Medical Device Risk Management 2
Q Risk Tools in ISO 31010 - Root Cause Analysis vs. Cause-and-effect Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Organizing Risk Analysis and Controls for a New Medical Device (ISO 14971) ISO 14971 - Medical Device Risk Management 4
S Please review my Risk Analysis Table ISO 14971 - Medical Device Risk Management 13
K Risk Analysis and "Information for Safety" / Labeling ISO 14971 - Medical Device Risk Management 10
M Risk analysis - ISO/TS 16949 clause 7.2.2.2 IATF 16949 - Automotive Quality Systems Standard 2
C Help with Risk/Benefit Analysis Self-help Device for Diabetics ISO 14971 - Medical Device Risk Management 3
A FTA-Top/Down approach to Risk Analysis ISO 14971 - Medical Device Risk Management 2
A Industry best practice about Post-Market Surveillance and Risk Analysis ISO 14971 - Medical Device Risk Management 6
T Risk Analysis help for CE Marking Class I Medical Device ISO 14971 - Medical Device Risk Management 10
T Risk Analysis for moving manufacturing equipment ISO 14971 - Medical Device Risk Management 17
D Different kinds of Risk Analysis for various Hazards ISO 14971 - Medical Device Risk Management 3
