Risk Approach doesn't address External Issues (Auditor's Comment)
qualprod
#11
Sílex7
Merge is to combine or joint to obtain one part or unit.
I don't see the objective of the merge, could you share the example?
Or maybe you say that both issues are shown in one file, is that what you meant?
Although that is not a merge.
Regards
#12
The Auditor after discussing this part showed me a merged risk assessment model that has organization contexts and Interested parties together , and he told me that's a good example one
This is consulting and the (CB) auditor shouldn't be telling you what's a "good example". That's purely their opinion and I'd question their ability to know one when they see one! Any "risk assessment model" is far more than ISO 9001:2015 requires. Let's not overlook that this standard was written for all types of organizations all over the World. As such, an approach like you were shown may look nice, however, is it what the standard is asking for? No and what's more a far, far simpler approach is likely to be what IS actually required.
Big Jim
#13
Until things settle down you are going to see a lot of overthinking about risk simply because it is new. Don't fall into the trap. Pay attention to what the standard actually says, not what people are reading into it. Make sure you read what's in the front and back of the standard as well as what's in sections 4 through 10 before you attempt to determine your method of dealing with risk.
Risk may be new to the standard, but it is not new to business. They have been handling it forever. Much of what they already do may be enough.
The same thing happened when the 2000 version was released with the new topic of continual improvement. Once the dust settled people realized that all they needed to do was already in the standard.
You do not need a formal procedure for risk. Record keeping of how you handle risk is limited to discussing it in management review and including that discussion in the management review record.
Silex7
#14
Sílex7
Regards
Qualprod, what I meant, is rather to have risk plan for each clause, you could have something like this:
For each risk you define your interested party who could be facing this risk and his relation with your business context.
Silex7
#15
Andy, you're right that I might be getting farther than standard requirement, but I was thinking if I am getting to improve my organization's risk management, why not having a good one?
I've reading some debates about how some clauses requirements implementation could be somehow 'insufficient' or ineffectively implemented for instance , interested parties , it might be extra work to do I agree with that, but may be saving it from being inefficient.
#16
Silex7 - Have you had a look at what ISO/TS 9002 has to say on this topic? From what I recall - and what ISO 9001:2015 states - looking at risk and opportunity is at a much higher level, that is "strategic". It's not meant to be looking at FMEA or merging risk and opportunity with other parts of the context. TBH it's far, far simper than most believe. The context is trying to form an "anchor" for the quality management system, to enable a framework to be established rather than, as in the past, a bunch of random concepts: policy, objectives, procedures etc. The requirements of the context are to put some thought into what the organization needs to address for its QMS to be successful and then ensure suitability of the various parts of the QMS are aligned and support each other. It's really quite simple...
Eredhel
Quality Manager
#17
First, in 4.1 identify external and internal issues, the positive and negative.
Positive side are opportunities, negatives are risks.
Are you referring to how risks are supposed to be addressed in 6.1.1? Because 4.1 doesn't require a negative external or internal issue to be a risk. It says internal issues and external issues can be positive and negative, not that one has to be the other.:
"NOTE 1: Issues can include positive and negative factors or conditions for consideration."
qualprod
#18
As Andy Said, do it Easy, since the standard only require RBT.
On the other hand, ok , you could use a table/spreadsheet in order to manage risk easier, but remember the purpose in 4.1 is not that same in 4.2, so a real merge is not applicable in my criteria.
Hope this helps
qualprod
#19
Eredhel
Don't see any difference, what you say in note 1, is what I included in my comment.
Hope is clear
#20
the answer isn’t in the standard. Nor will you find the answer with shallow thinking.
I always recommend that people read “the failure of risk management and how to fix it” by Douglass Hubbard. Risk based thinking requires thinking to understand what is the best thing to do...
G Any good examples of CAPA forms that include a risk based approach? ISO 13485:2016 - Medical Device Quality Management Systems 8
D Validation of existing equipment - Risk based approach example ISO 13485:2016 - Medical Device Quality Management Systems 3
C Usability IEC 62366-1:2015 and MDR 2017/745 - Risk based approach IEC 62366 - Medical Device Usability Engineering 1
M Informational USFDA draft guidance – A Risk-Based Approach to Monitoring of Clinical Investigations Questions and Answers Guidance for Industry Medical Device and FDA Regulations and Standards News 0
Pmarszal ISO 19011:2018 - Risk Based Approach for planning, conducting and reporting of internal audits Internal Auditing 8
Q Questions about the Risk-based approach to QMS processes ISO 13485:2016 - Medical Device Quality Management Systems 17
S ISO 13485:2016 - Risk-based Approach ISO 13485:2016 - Medical Device Quality Management Systems 3
S Risk based approach - Procedures already take a risk-based approach to QMS processes ISO 13485:2016 - Medical Device Quality Management Systems 3
S ISO 13485:2016 - How I can integrate a risk management approach in our SOPs ISO 13485:2016 - Medical Device Quality Management Systems 1
S Risk Based Approach for ISO 13485:2016 Form/Procedure ISO 13485:2016 - Medical Device Quality Management Systems 23
alonFAI How to define a Risk Based Approach for Supplier Management per ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
B Risk Requirements to meet the explicit Risk Based Approach of ISO 13485:2016 Examples ISO 13485:2016 - Medical Device Quality Management Systems 21
A FTA-Top/Down approach to Risk Analysis ISO 14971 - Medical Device Risk Management 2
AnaMariaVR2 Structured Approach to Benefit-Risk Assessment in Drug Regulatory Decision-Making Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M Name for FMEA (Risk Analysis Approach) Program FMEA and Control Plans 1
V Evolving QA from 'Compliance-based' to 'Science/Risk-based' approach US Food and Drug Administration (FDA) 2
AnaMariaVR2 Risk Based Approach to Validation [article] Qualification and Validation (including 21 CFR Part 11) 3
T Best Risk Analysis Approach (ISO 14971) - Class IIa Medical Devices ISO 14971 - Medical Device Risk Management 16
C ISO/ PAS 28000 Implementation Guide - I'm interested in its risk based approach Other ISO and International Standards and European Regulations 4
Sidney Vianna Risk Based Audits - Will the industry change it's approach? Registrars and Notified Bodies 0
Scott Catron Any difference in FDA inspections since the risk-based approach was announced? US Food and Drug Administration (FDA) 6
T Biological Evaluation (10993) & Risk Management ISO 14971 - Medical Device Risk Management 7
D Cybersecurity and Risk Management: Loss of confidentiality IEC 62304 - Medical Device Software Life Cycle Processes 4
Q FMEA and Risk assessment in Microsoft Access FMEA and Control Plans 6
I Realization processes input into overall risk ISO 14971 - Medical Device Risk Management 2
thisby_ Post Market/Production Risk Assessment ISO 14971 - Medical Device Risk Management 0
S Risk Management Review ISO 14971 - Medical Device Risk Management 4
D Low risk IVD study in the UK, do I need MHRA approval? UK Medical Device Regulations 1
S Risk Management and other Files ISO 14971 - Medical Device Risk Management 8
silentmonkey Overall Benefit/Risk Analysis - Risk Management VS Clinical Evaluation ISO 14971 - Medical Device Risk Management 3
N ISO 27001 for Jumb Burger - Risk Assessment sheet IEC 27001 - Information Security Management Systems (ISMS) 11
C Risk Assessment Tools ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
qualprod Examples to mitigate risk from Covid ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Risk of stopping your customer's line IATF 16949 - Automotive Quality Systems Standard 4
C Risk Matrix vs FMEAs ISO 14971 - Medical Device Risk Management 11
S IVD risk class II devices for Brazil and MDSAP Other Medical Device Regulations World-Wide 0
M ISO 14971:2019: Criteria for overall residual risk ISO 14971 - Medical Device Risk Management 6
M ISO14971:2019 - Verification of implementation and effectiveness of risk control ISO 14971 - Medical Device Risk Management 3
Aymaneh Medical Device Cybersecurity Risk Management IEC 27001 - Information Security Management Systems (ISMS) 2
S Traceability of requirements to design and risk Design and Development of Products and Processes 3
R Risk control measures as per ISO 14971 ISO 14971 - Medical Device Risk Management 6
D Deciding whether or not pre-market clinical investigation is required for low risk device EU Medical Device Regulations 5
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
_robinsingh Security Risk Assessment Tool IEC 27001 - Information Security Management Systems (ISMS) 0
A 21 CFR 820 - Risk Management - Looking for some guidance US Food and Drug Administration (FDA) 3
bryan willemot Contract Review and risk managment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Sravan Manchikanti Software Risk Management & probability of occurrence as per IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
E Normal Condition Hazards in Risk Analysis ISO 14971 - Medical Device Risk Management 3
